Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > UST Pro II
Old 10-18-2008, 11:39   #1 (permalink)
Member: 862130
Thanks Meter: 186
Unhappy installation problem is this a hardware box problem or what???
Please team USTpro2, I got my box yesterday 10-17-08 from my reseller skystartrade.com and installed the ustpro_V8.02.exe and went fine on installation but after I open the ustpro interface a pop-up windows saying " box error :032 ustpro device calibration, please calibrate your box! "
then I press the ok button and press calibration then I tried to choose the right LED that blink but every time I got to that point the pop-up window calibration will be out within 2-3 second so I cannot do anything at all, It won't let me press the right LED light to check it, and I do the procedure again and it will do the same thing over and over again. I did uninstall, restart the computer and reinstalled it again,but same thing over and over again what I stated. It won't let me do the calibration. I seek help from my other co-tech that has ustpro and said that the problem is my box already not the installation process. we use the theme viewer so they can see and help me to reinstall my ustpro but no luck. Please can USTpro team verify this matter coz I hate to return it because I have 5 samsung to try out right now thats why I want to work on it fast.
Old 10-18-2008, 12:31   #2 (permalink)
Member: 281494
Thanks Meter: 6
Are the Com ports set to below 12 ?
Old 10-19-2008, 15:55   #3 (permalink)
Member: 621698
Thanks Meter: 378
Yes, how come any of the support team haven't answer my question
Old 10-19-2008, 16:21   #4 (permalink)
SiRoYa's Avatar
Member: 16107
Sonork: 100.58402
Thanks Meter: 26,408
check comports!!
make sure ther number are less then 12
The Following User Says Thank You to SiRoYa For This Useful Post:
Old 10-19-2008, 16:21   #5 (permalink)
SiRoYa's Avatar
Member: 16107
Sonork: 100.58402
check comports!!
Old 10-19-2008, 19:29   #6 (permalink)
Member: 621698
Thanks Meter: 378
Originally Posted by SiRoYa View Post
check comports!!
I got it working now, but now my problem is how to update the software? because the newest version came out already. whats the procedure?
I tried to go to support at ustpro2.org and I did registered my ustpro2 but still USTpro2 team haven't send me a login password yet so I cannot do any update for my box
Old 10-19-2008, 23:32   #7 (permalink)
SiRoYa's Avatar
Member: 16107
Sonork: 100.58402
no need to update anything simply download new version from support page and install it
u can go support area by pressing go to support botton from ust software
Old 10-20-2008, 07:57   #8 (permalink)
Member: 621698
Thanks Meter: 378
even the flash files too? I can go without login in?
Old 10-22-2008, 04:20   #9 (permalink)
Member: 862130
Thanks Meter: 186
How come my ustrpo2 doesn't have any features that you can press " INFO" and see the info of the cellphone, coz I want to check many cellphone that I want to unlock first, before do unlocking if the phone will let me check the info first
Old 10-24-2008, 01:50   #10 (permalink)
Member: 621698
Thanks Meter: 378
Team USTpro2, I'm new with your box is there any way you can tell me how to check the info of any cellphone I plug from USTpro, please thank you. because I cannot see any features of "INFO" button on interface. Is this how really the USTPro2 is? because this is my new box
Old 10-24-2008, 19:00   #11 (permalink)
Member: 577243
How did you fix this problem please as it is happening to me
Old 10-24-2008, 22:32   #12 (permalink)
Member: 621698
Thanks Meter: 378
What problem? login to support or you cannot use the box because it crashed on you when you do the calibration?
Old 10-24-2008, 23:10   #13 (permalink)
fonekrazy's Avatar
Member: 884199
Thanks Meter: 65
every time i start up it asks to calibrate box maybe two or three times sometime the program just closes down. the lights on the front are constantly flashing even when program not running
Old 10-25-2008, 22:02   #14 (permalink)
Member: 621698
Thanks Meter: 378
For that issue is not the same as mine, so please call your supplier where you bought your USTpro2.
is this a hardware problem??!! mansi DreamBox 3 07-28-2008 17:28
is this a kind of jock or what? not even one unlock gose right karouk Smart-Clip 2 12-30-2006 10:38
is this a damaged box or im doing something wrong ASHIF UST Pro II 2 06-17-2006 10:19
Is this fault by wrong unlocking or hardware? sjakie Various 2 09-08-2004 09:30
Page generated in 0.44110 seconds with 8 queries
