Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > UST Pro II
Old 07-18-2008, 05:59   #1 (permalink)
Member: 173915
the perfect way to solve most problems with ust
i saw that most software problems are not solving by flashing, even i
used perfect flash files and eeproms,
this is a common problem found in d900i,e250,e250d,d600,d500,etc.
after that i found a perfect way to solve the software problems with
ust pro, its so easy to do,
here i am going to tell all my friends a perfect way to solve the problems.
1-select the model
2-select flash files + eeprom
3-check the erase box that is in top
4-check erase mcu+eeprom
5-press flash\make jobs
after process your phone will be ok
100% solution, tested with ustpro.
your brother,
muhammad atique ashrafi.
The Following 2 Users Say Thank You to ashrafi580 For This Useful Post:
Old 07-18-2008, 14:49   #2 (permalink)
zullu2004's Avatar
Member: 146635
thx friend, your are right
Old 07-19-2008, 05:19   #3 (permalink)
pallumobile's Avatar
Member: 659890
Thanks for the wonderful information bro
~~~*~~~ The Perfect Solution To Solve "Insert SIM" In Nokia 6610 & 7210 ~~~*~~~ sallupat Nokia Hardware & Hardware-Repair Area 20 11-05-2009 14:10
is there any way to solve this problem posted many time !!!! nizoudj Nokia Hardware & Hardware-Repair Area 8 09-20-2008 20:12
How to solve this problem with MSP GoLL@B x4x, x5x Flashpatching 5 12-24-2005 10:38
The easiest way to solve K500 blinking problem kaisar UFS2 + UFS3-Tornadoflasher 2 10-08-2005 22:02
Page generated in 0.19767 seconds with 11 queries
