Samsung E1150 Unlocked Successfully Just Select e1125 medel and do erase eeprom phone will be unlocked succf http://img704.imageshack.us/img704/9...2010175512.jpg |
and then direct unlock? anyone tried it? |
And what's this DIRECT UNLOCK button for ? |
dont do that ur imei will be 000000000000000 |
hello >> This program you can open Receivers Sting IR-200 ??? Or Not ? |
Remember to uncheck "Bypass in TAT Mode". Tested by me. |
how to fix this imei problem , can u explain it |
make read code with simcard and ust give you code , tested by me all ok . |
friend i tried but the code given is error |
I also tried. Readed code is wrong. Unlocked by erasing eep and rebuilding IMEI!! |
testet by me and work thanx |
THANKS, test ok on 15 units!!! Before rebuild imei, and after erase eeprom, power on mobile for init. |
works perfect with read codes with sim inside and 1125 selected |
