Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > UST Pro II
Old 01-01-2011, 10:46   #46 (permalink)
Crazy Poster
Member: 925605
rebuilding IMEI!! use new algorithm normal
Old 01-01-2011, 11:35   #47 (permalink)
Crazy Poster
Member: 925605
remove bypass in TmT mode
Old 02-14-2011, 04:21   #48 (permalink)
Member: 201429
thanks alot baru keep it up
Old 02-15-2011, 07:27   #49 (permalink)
taoujdate's Avatar
Member: 510826
it's Easy
Originally Posted by prabue View Post
how to fix this imei problem , can u explain it
It's Easy
Old 03-07-2011, 15:08   #50 (permalink)
vrepair's Avatar
Member: 46125
can any one give me arabic farsi language firmware for samsung E1150?
will be paid no problem
Old 03-12-2011, 10:41   #51 (permalink)
Registered User
Member: 651119
Sonork: 100.1603096
salect model 1125 erese epprom then write org imei unchek bypaee n tat mode your problem solved tested work phone ok
Old 03-12-2011, 14:49   #52 (permalink)
vrepair's Avatar
Member: 46125
samsung E1150i
wbr
Old 04-05-2011, 14:30   #53 (permalink)
Member: 253310
Thanx all !! This solution works >
1. Read E1150 as E1125
2. Turn off TAT Mode
3. Erase eeprom - phone is now unlocked - tested
4. Rebulid Imei - Use New Algorithm in Normal mode (TAT mode still off )
5. Check the phone - work and unlock
Be sure, that baterry is in very good condition, because is still inside the phone !!
Cable used E210 for UST Pro II
Best Regards from Slovakia
Old 04-13-2011, 16:06   #54 (permalink)
Member: 425693
gooooooooood djob thankssssssssssssss for allllllllllllll
Old 04-13-2011, 16:08   #55 (permalink)
gsmpioneer's Avatar
Member: 1548968
Sonork: 100.1603660
1 year,///////////////
Old 11-05-2011, 08:02   #56 (permalink)
Member: 1115410
Sonork: 100.1608126
Successfully changed imei by selecting model E1125
and now fone signal is also ok
Old 11-08-2011, 16:49   #57 (permalink)
laltu10's Avatar
Member: 1315514
Good job thankss ----------------------
Old 11-24-2011, 16:27   #58 (permalink)
RamSon83's Avatar
Member: 500637
erased ok
rebuild imei ok by
unchek bypass+use new algorithm normale
logs
Reading data from box...
Power ON phone...
Phone detected!
Loading Preloader...
Preloader OK!
Setting 921600 bps...
Baudrate set OK!
Loading second loader...
2nd boot OK!
Flash Chip ID : 0x00AB
Flash Chip Name : M36W0R6050UL0
Reading EEPROM...
Security block calculated OK!
Rebuilding IMEI...
Operation successful.
Elapsed Time (00:23)
Old 03-17-2012, 16:09   #59 (permalink)
Member: 467312
unlock cabel for E1050 is E210 ?
Old 03-18-2012, 19:10   #60 (permalink)
orangade's Avatar
Member: 521955
yes, connect only rj45.
FAQ about unlock n0kia man0n Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 11-29-2010 18:06
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 07-09-1999 22:08
Page generated in 0.33334 seconds with 12 queries
