samsung E250 show only SAMSUNG E250 e250 only show samsung e250,flash with ust pro same probleam please help me |
How did you Flash phone? Maybe its E250D. |
e250 hang on samsung e250))))))))))) Brother just change power ic 10000000000000% solved i have tested many sets LISTEN purchase a new ic from market not manage with other dead or any on board just replace with new ic your problem will b solved (DONT FORGET TO SAY THANKS);) |
why do you wont to change power IC ??? it is standard error with bad software - flash it again - if you cant repair with UST box , write full flash with HWK box and it will work , if would not work write e2p file with HWK and it will work . UST have many errors , it is OK box but too many times make problems with many phones HWK don have spport but phones that support work very nice If you need e2p file contact me i will send you |
e250 hang on samsung e250))))))))))) Quote:
Brother i tested on many sets its 100% power ic prob and this prob come as charger some time charger gave bad volts to phone so set freeze on startup because power ic not served to other components voltages so beleive me and say me thanks ;) |
yes you can upload EEPROM and post results B:R |
brother check with eprom if not so change power ic |
Some one said to flash it some one to replace the power ic. which is the proper solution? I am confused |
its hardwaer...................... |
