12-17-2009, 16:58 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: Location: Location:
Member: 751758 Status: Offline Thanks Meter: 113 | Samsung GT-E1080 - unlock failed Reading data from box... [In case of problem, Uncheck 'Bypass in TAT MODE' and try again] Power ON phone... Phone detected! Setting sysol test mode... Sysol test mode ok! Waiting for TAT init... IMEI : 356249-xx-xxxxxx Model : E1080MFIH1 MSL Addr : RVZS972232 Crypted MSL : 44E1A4138EFFAC7FA22BDCF20014C25288CD046E Calculating security,Please wait... ERROR : Failed to decrypt security data! Elapsed Time (00:32) Already tried to uncheck "bypass in TAT mode (NEW)" but with no result. |
01-09-2010, 16:15 | #5 (permalink) |
No Life Poster Join Date: Mar 2003 Location: paris Age: 44
Member: 24284 Status: Offline Thanks Meter: 56 | c270 with "old algo' selected and "bypass" unchecked.and read code. all will be ok. if you check new algo you will get this Reading data from box... [In case of problem, Uncheck 'Bypass in TAT MODE' and try again] Power ON phone... Phone detected! Setting sysol test mode... Sysol test mode ok! Waiting for TAT init... IMEI : xxxxxx-xx-xxxxxx Model : E1080MFIH1 MSL Addr : RVZS972232 Crypted MSL : 44E1A4138EFFAC7FA22BDCF20014C25288CD046E if you chose old algo you get 2 loader like this with correct codes "services code " is the last one. Reading data from box... Power ON phone... Phone detected! Loading Preloader... Preloader OK! Setting 921600 bps... Baudrate set OK! Loading second loader... 2nd boot OK! Flash Chip ID : 0x00AB Flash Chip Name : M36W0R6050UL0 Reading phone data... Code : 81330356 Code : 84295820 Code : 30308790 Code : 95054120 Operation successful. Elapsed Time (00:13) Preloader OK! |
The Following 2 Users Say Thank You to street For This Useful Post: |
02-09-2010, 22:02 | #6 (permalink) |
Junior Member Join Date: Dec 2008
Member: 921470 Status: Offline Sonork: 121 Thanks Meter: 1 | i have tried this but my phone have accept the net code and this time my phone will the PROVIDER CODE ?? HELP i have HWK Box |
The Following User Says Thank You to SixToes For This Useful Post: |
02-10-2010, 16:06 | #10 (permalink) |
Member: 921470 Status: Offline Sonork: 121 Thanks Meter: 1 | Connect Cable to Switched Off Mobile (with battery) Software: E1080APIL1 Hardware: MP 0.500 Regions : AP Release : 2009 December Rev: 1 S/N : RV5Z117578 IMEI: 358698-03-138XXXX-X MSL Active Model : E1080 Cable : E210 by the model C270 i got this error Connect Cable to Switched Off Mobile (with battery) Error in Versions Info |
02-12-2010, 08:48 | #13 (permalink) | |
Freak Poster Join Date: Jan 2005 Age: 53
Member: 103635 Status: Offline Thanks Meter: 86 | bro use latest ust-pro version 11.2.1 Quote:
Uncheck 'Bypass in TAT MODE' and try again] press read codes connect cable to phone, then insert battery. don't forget the thanx buttom!!! | |
The Following User Says Thank You to herbie_ma For This Useful Post: |
02-12-2010, 12:05 | #14 (permalink) | |
Member: 921470 Status: Offline Sonork: 121 Thanks Meter: 1 | Quote:
i dont have a UST BOX i have (for this phone) Polar box 2 HWK (Sarasoft Powerflasher Master) | |
02-12-2010, 15:01 | #15 (permalink) |
Member: 24284 Status: Offline Thanks Meter: 56 | wrong section man this is ust section go hwk section and ask hwk's usrs and suport!!!! here https://forum.gsmhosting.com/vbb/f311/ |
The Following User Says Thank You to street For This Useful Post: |
Code for samsung GT-E1080 | dadapoulo | VLSI, Conexant, Skyworks and Old Models | 0 | 03-09-2010 10:01 |
unlock samsung GT-E1080 .... [GOOD WORK THX] | lusomaco | PolarBox 3 | 17 | 02-13-2010 22:09 |
GT-B3210 unlock failed | ericnite101 | UST Pro II | 5 | 02-08-2010 22:00 |
GT-B3310 unlock fail. PLS, HELP! | ockiya | UST Pro II | 9 | 12-04-2009 17:55 |
GT - S5600 unlock failed all the time! | .:GSM International:. | HWK | 10 | 11-26-2009 10:03 |
