Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > UST Pro II
Old 09-27-2009, 06:48   #1 (permalink)
baig65's Avatar
Member: 569388
samsung T..MOBILE T239 UNLOCK PROBLEM.
Reading data from box...
Power ON phone...
Phone detected!
Loading Preloader...
Preloader OK!
Setting 921600 bps...
Baudrate set OK!
Loading second loader...
2nd boot OK!
Flash Chip ID : 0x00AB
Flash Chip Name : M36W0R6050UL0
Reading phone data...
Error : No codes found.
Operation successful.
Elapsed Time (00:14)
Old 09-27-2009, 07:52   #2 (permalink)
Member: 180833
Sonork: 100.1578281
@ baig65
Brother try with latest soft v9.9.5.4.
Is It Country Lock??
When u enter the sim card to phone then what it shows?
Old 09-27-2009, 08:45   #3 (permalink)
baig65's Avatar
Member: 569388
Brother i used latest update v9.9.5.4.
but same not working.
Old 09-27-2009, 11:45   #4 (permalink)
Member: 180833
Sonork: 100.1578281
just try with this brother........
Full reset *2767*3855#
*7465625*638*00000000*00000000#
#7465625*638*00000000#
and insert *#7565625# all locks is ok
The Following User Says Thank You to sanjoychy For This Useful Post:
Old 09-27-2009, 12:23   #5 (permalink)
Member: 180833
Sonork: 100.1578281
@ baig65
Brother, another option for u.
writing eeprom from support page.
after eeprom done write your original imei.
may be ur problem ill be solve. but try it at ur own risk.
personally i have unlocked that phone by NSPro.
Old 10-08-2009, 06:56   #6 (permalink)
Member: 542009
Originally Posted by sanjoychy View Post
@ baig65
what cable did you use to unlock t239,with Baterry or without?
Thanks
try here but can't get code
The Following User Says Thank You to 7777 For This Useful Post:
Old 09-10-2010, 09:38   #7 (permalink)
Member: 1383327
Sonork: muskaan85
Hi
Hi
can u pls help me to unlock a samsung T239 T-mobile
Old 09-10-2010, 19:17   #8 (permalink)
sweetboy's Avatar
Member: 146939
Hi
bro use nspro ust can not unlock t239
Old 09-11-2010, 23:52   #9 (permalink)
Member: 311690
Try use c180 cable, select E2120 model, then perform read code. I think it should work.
T239 unlock problem sr8787 Z3X-Team Products 7 05-18-2010 09:28
T239 unlocking problem astana2007 NSPRO 1 11-19-2009 06:12
samsung T..MOBILE T239. baig65 Z3X-Team Products 4 09-27-2009 23:33
T239 unlock problem "Help" pagerdude NSPRO 6 08-03-2009 18:56
T-mobile 2610b unlock problem chenflash MT-BOX 0 09-23-2007 04:35
Page generated in 0.51595 seconds with 11 queries
