10-18-2007, 10:29 | #1 (permalink) |
Crazy Poster Join Date: May 2007 Location: karachi. city of Darks :( Age: 39
Member: 501440 Status: Offline Thanks Meter: 9 | U600 Optiflash safe procedure? thanks Yousaf Ali |
12-09-2007, 20:39 | #3 (permalink) | |
Registered User Join Date: Sep 2007 Location: palestine Age: 41
Member: 592201 Status: Offline Sonork: 100.114536 Thanks Meter: 160 | Quote:
http:///vbb/showth...57#post2933457 you can convert file flash by ust-pro to work on ust-pro | |
The Following 2 Users Say Thank You to khalid059 For This Useful Post: |
04-16-2008, 15:02 | #4 (permalink) |
Freak Poster Join Date: Jun 2007 Location: Out Of ...
Member: 528781 Status: Offline Thanks Meter: 33 | Samsung SGH-U600 flashing instructions 1. Type *#1234# into your handset to see your existing firmware. If it is a U600 firmware then use U600 Optiflash and a Samsung SGH-U600 flash file, if it is a U600B firmware use U600B Optiflash and a Samsung SGH-U600B flash file. Make also sure you have the original samsung USB cable that came with the phone. 2. Install the USB driver for the cable. 3. Launch Optiflash and click on "Options > Settings > Generic" - Select "Customer T: D830/D840/D910/X840/ECLAIR TFS16(USB)" - Set "Flash Erase Passes" to "1" - Set "Operation Passes" to "Default" - Uncheck all checkboxes except "Differences Only", "Erase All Unused Regions" and "Extended Protection". 4. Select the tab "Read" and make sure that under the "Read Ranges" there is "0x20000000 - 0x21ffffff" because if it isn't, it may wipe your imei. You can check your imei by typing *#06#. 5. Select the tab "Flash and Verify" - Browse to and select your *.s3 firmware file 6. Select the tab "Default Contents" If you have a file *.cts with the firmware *.s3: - Select radio button "S-Record with Contents" - Browse to and select your *.cts file If you do not have the file *.cts: - Click on "S-Record only" - Click "OK" 7. Connect the phone to the computer via the USB cable. In the phone click "connect to pc studio". 8. Remove your SIM, your microSD card and the battery from the phone which will turn the phone off. Leave the USB cable in. You will see leds on. 9. Whilst holding down the * key on the phone, briefly press the ON button. Your computer will recognise the device as Samsung USB Mobile. 10. Return to Optiflash, click on "Options > Settings > COM Port" - Select the COM port your phone uses. If you are not sure, you can find out by: Control Panel > System > Hardware > Device Manager > Ports (COM and LTP). - Select "921600". - In Second COM Port select "none" - Click "OK" Lastly, click "Flash" The flash procedure takes approximately 15 minutes and will be finished when the message "All is Well" appears above the green progression bar. A full reset should not be necessary once the firmware is upgraded, however, if you want to do it type *2767*3855# then wait one full minute before you restart your phone. To check your existing firmware type *#1234# into your handset. If your phone restarts in a different language follow the language selection process: MENU (left touch button) > SETTINGS (bottom right icon) > PHONE SETTINGS (2nd option) > LANGUAGE (1st option) |
The Following 7 Users Say Thank You to outlandier For This Useful Post: |
04-16-2008, 15:14 | #5 (permalink) | |
Member: 501440 Status: Offline Thanks Meter: 9 | Quote:
thanks Yousaf Ali | |
The Following User Says Thank You to Yousaf Ali For This Useful Post: |
12-10-2008, 17:29 | #11 (permalink) |
Junior Member Join Date: Sep 2007
Member: 599251 Status: Offline Thanks Meter: 0 | Help flashed my u600b using optiflash u600b and flash u600bxxgk2. the phone was tied to t-mobile but i got it unlocked and was using a vodaphone/asda sim it worked fine. now after flashing it says "invalid sim card". how do i fix this ? or can i roll it back to the old settings ? thanks, |
12-10-2008, 20:02 | #12 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: E G Y P T Age: 37
Member: 527884 Status: Offline Sonork: 100.1583794 Thanks Meter: 850 | Quote:
02-04-2009, 17:16 | #13 (permalink) | |
Freak Poster Join Date: Nov 2008 Location: toronto, canada
Member: 900685 Status: Offline Thanks Meter: 7 | U600 optiflash Quote:
F300 and U600 optiflash here. | winVISTA | Samsung Flashers, Software, Firmware. | 33 | 10-19-2009 23:18 |
U600 telcel unlock procedure | foo_men | HWK | 2 | 07-22-2009 09:52 |
s853 unlocking with safe procedure | wincel | TSMbox+ | 1 | 09-05-2007 18:32 |
