08-12-2008, 21:20 | #1 (permalink) |
Insane Poster Join Date: Aug 2007
Member: 572230 Status: Offline Thanks Meter: 5 | U700 full signal but no calls the SW version shows U700DXGK1 I read many post but couldn't find the solution. some say if flash with U700BUGL2 firmware will solve the problem. But it is a vodafone firmware. I am looking for a debrand solution Is it a software problem? Is there a solution?? Thanks all for the help. |
08-12-2008, 21:29 | #3 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Germany/Niederlande/Turkey
Member: 811992 Status: Offline Sonork: 100.1584257 Thanks Meter: 162 | Hello That is correct that some Vodafone mobile phone of problems has with another offerer, but whom you original software flash dan would have these errors to be repaired!Whom did I understand the correct you have uST pro box? Whom dan you can download the Flash file under support! |
08-13-2008, 04:20 | #4 (permalink) |
Member: 572230 Status: Offline Thanks Meter: 5 | I believe that U700DXGK1 is the original firmware, the phone was working before and now it can't make or receive calls but signal bar is full. This phone is not a Vodafone phone, so do you think that flash with vodafone firmware will solve this problem? one last thing, how do i check if phone is black listed? and how to tell the different of U700v, U700 and U700b? Thank you all for the help!!!!!! |
08-13-2008, 15:04 | #5 (permalink) |
No Life Poster Join Date: Oct 2002 Age: 39
Member: 16107 Status: Offline Sonork: 100.58402 Thanks Meter: 26,411 | do this write boot files using U700 multidownloader ------> u can get this from support page in U700 folder after writing boot files flash again with format ffs |
08-19-2008, 06:49 | #9 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Lithuania Age: 40
Member: 19265 Status: Offline Thanks Meter: 92 | This issue is not only with U700, as we got some phones like this. and usually phone looses network after reset (*2767*3855#), would be great if any of developers could investigate this. Maybe any bulletin exists or something. p.s. IMEI ok, as we tried to make few nokia with same IMEI as samsung, and they worked perfectly. B.R. Alkapone |
U700b full signal but , no calls | carlos barrera | NSPRO | 5 | 09-02-2009 01:02 |
v3i with signal but no call after Drop | yurais | Motorola Hardware Repair | 3 | 04-20-2009 16:08 |
SPVc600 with Vodafone, full signal but no calls | png19 | HTC & PDA WM( With Touchscreen) | 0 | 12-12-2007 10:57 |
t100 samsung full signal but can't call | Black-Axe | VLSI, Conexant, Skyworks and Old Models | 4 | 05-21-2004 09:19 |
8210 full signal but no in-outcoming call | infogsm | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 11-22-2002 17:25 |
