Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > UST Pro II
Old 05-08-2007, 14:01   #1 (permalink)
Member: 224881
Unlock LG U880 by flash successful but still SIM locked
Hi , i tryed today to unlock LG U880 by flashing patched file, i flashed all 3
( Code, Media , Module ) the process was successfully done but when i put another SIM card in the phone it says SIM locked, i tryed to factory reset with 142358#*# , it done but still it is locked.
PLEASE HELP WHAT SHOULD I DO?????????
the ******* wantsthe phone now quickly!!!
Thans
br
Old 05-08-2007, 14:32   #2 (permalink)
damabib's Avatar
Member: 106026
Sonork: 100.77890
reads threads all temp unlock ..try sos key or enter ur code
Old 05-08-2007, 15:19   #3 (permalink)
CONCORDIA GSM's Avatar
Member: 209722
Try With Corect Files It Should Be Unlock
Old 05-08-2007, 17:13   #4 (permalink)
Member: 224881
Thank you for reply
Mr. Damabib which code you mean?? and how to use SOS .i have searched all the threads but there is nothing like this.can you explane more please.
Brother Asif, I am from Austria and i select thesee Files because they locate DE ( for Germany)
Code : U880-CODE-MUSEDR-V10-OCT-.....BIN
MEDIA : U880-MEDIA-V10a-OCT-27-....BIN
MODULE : U880-MODULE-V10a-OCT-27.....BIN
These are the files which are avialable in support area.I flash with out tick the Format FFS.
but when it finished flashing, i got unavialable Media file message,then i flashed only Media with this File : U880-MEDIA-V10b-Austria which i got it from searching in the forum.
What is wrong with this Procedure????????shall i try another time with flashing.? can anyone give me the correct files
Thanks
Old 05-08-2007, 19:08   #5 (permalink)
MFC
MFC's Avatar
Member: 83741
Sonork: 100.1624702
To Naseerjako,
Now that you have flashed the phone, you have to insert incorrect sim and then enter 142358#*#, this code will reboot the phone and will work ok.
WBR
Old 05-08-2007, 19:21   #6 (permalink)
Member: 224881
Mr. MFC thanks to your reply, beleave me i did that several times but it didnt reboot, i got only the test mode menu 1-version info 2-device test 3-port seting.........etc......8-Factory default.
i press factory default it reset it but nothing happend, the same sim lock appears.
Old 06-17-2007, 10:26   #7 (permalink)
Member: 23072
2 pieces u880 and the same problem ! Please help me !!!
Unlock LG U300 by flash FAILED at-kom VygisToolbox 1 02-13-2010 22:49
nk5800 unlock success but still sim card not valid ahmad5175 Nokia Base Band 5 ( BB-5 ) 16 05-22-2009 10:44
Nokia 8600d flashed successful but still dead abcchoier Nokia Hardware & Hardware-Repair Area 7 04-02-2009 05:52
<<~D600 Flashed Successfully But Still Restart ~>> Faisal_Computer UST Pro II 16 08-11-2008 12:05
Page generated in 1.49055 seconds with 11 queries
