10-23-2009, 10:12 | #1 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 43
Member: 57806 Status: Offline Thanks Meter: 4 | What should I change on UST Cable for S5230? I would like to know, if there is any "understandable" schematic for the cable. |
10-23-2009, 12:42 | #3 (permalink) |
Freak Poster Join Date: Jun 2003 Location: Denmark Age: 56
Member: 31243 Status: Offline Thanks Meter: 13 | S5230 unlocked with 10.0.0 Sorry I dont have screenshot, but I got i work yesterday (after some tries) Annoying that UST dont tell you when to chang cable, hopefully in next update ?? -disconnect all usb boxes/dongles -uninstall all previous UST versions -uninstall all previous Samsung drivers -reboot -install 10.0.0 -install new drivers -run 10.0.0 with orig samsung cable to box -let UST detect phone usb port (press direct unlock) -change cable to E210 (both rj45 and usb) and press ok -change cale to orig usb when it says "calculating" -all OK !! BR /Insight |
10-23-2009, 15:07 | #4 (permalink) |
No Life Poster Join Date: May 2005 Location: Timisoara Age: 43
Member: 146635 Status: Offline Sonork: 100.1651273 Thanks Meter: 261 | unlock S5230 Before I forget all the steps I will post here Here we go start ust-pro2 ver 10.0.0 select S5230 You must have prepared one e210 combo cable ( for ust) and one original usb cable power on phone with no sim card connect rj45 cable on box connect original usb cable on usb (other then box) connect phone to usb cable press DIRECT UNLOCK from here on now you must be pretty quick when software says : "NAND > Waiting for phone power ON..." REMOVE phone from usb cable, and REMOVE battery from phone put back battery to phone connect phone to rj45 cable and press power, until phone it's in boot loader mode ( yellow writing) when software says : "NAND > Calculating data, PLEASE WAIT..." REMOVE phone from rj45 cable, and REMOVE battery from phone put back battery to phone and POWER ON connect phone to usb cable ( don't wait for phone to fully power on) PHONE UNLOCK maybe you won't get it from first try PRESS THANKS IF THIS HELP YOU ! |
The Following 7 Users Say Thank You to zullu2004 For This Useful Post: |
10-23-2009, 17:53 | #6 (permalink) |
No Life Poster Join Date: Mar 2009 Location: Europe Wienna
Member: 984046 Status: Offline Thanks Meter: 255 | Check your cable conn. S5230 NEEDS ALL GROUND pins to be connected (in a E210 cable) I struglled two weeks with everything, until cable connector dismantle-ing. 3 side pins were dissconected (cold joined - Cellphone side/charging conn) and/altough cable (RJ45 part) was FULLY functonal with J700, C3050 etc, etc. SO... CHECK YOUR CABLE !!! - I CANT STRESS THIS ENOUGH BR Haltec |
What can i do fix my cables for resistor in BSI line modification | kennyDaktyl | Universalbox | 1 | 01-08-2010 13:31 |
what are two swiches on the box for? | snowtown | VygisToolbox | 2 | 10-21-2008 15:40 |
What Are The Buttons On F/box For | nokia_dan | FuriouS II | 4 | 01-27-2006 10:51 |
somebody, pls send me picture/schema of what should be change tofix "boxnotconected" | ashvin | Redbox | 0 | 01-17-2006 07:54 |
What should I use on c25 v61 and not kill it??? | pigo | x1x to x45/x50 | 0 | 05-24-2001 20:24 |
