04-08-2008, 14:54 | #1 (permalink) |
Insane Poster Join Date: Jan 2008
Member: 691182 Status: Offline Thanks Meter: 0 | X550 Flashing problems ...... At first was loked .... tryed to unlock but it gave a error reading codes conserning to eproom ....... Flashed at first try and Freese in samsung ....... Downloaded another flash files and now no power ..... Tryed more than 4 flash files and while writing FFS it allways stops at 95% .... Here are the diagnostics ... : Power ON phone... Phone detected! Loading flash applet... Getting Flash ID... Flash chip type : SPANSION S29WS256N Number of sectors : 134 Setting 460800 bps... Loading second loader... 2nd boot OK! Programming flash... Flash programming OK! Programming EEPROM... EEPROM programming OK! Formatting FFS... FFS Format OK! Creating directories ... Dir create OK! Uploading files to FFS... It gets stuck at 95% : /java/_suite_8.png ............... Need help please the phone was working and now this problem ..... Last edited by metalcharm; 04-08-2008 at 15:02. |
04-09-2008, 09:33 | #2 (permalink) |
Member: 691182 Status: Offline Thanks Meter: 0 | At first when I Tryed to read the codes that was the problem : Reading data from box... Power ON phone... Phone detected! Loading flash applet... Getting Flash ID... Flash chip type : SPANSION S29WS256N Number of sectors : 134 Setting 460800 bps... Loading second loader... 2nd boot OK! Bypassing MSL security... MSL security bypass failed! Possible damaged eeprom data, Try again or write new eeprom. Elapsed Time (01:15) Someone plz help .... The phone now freeses in "Samsung" ....... it was working .... |
04-09-2008, 11:15 | #5 (permalink) |
Member: 691182 Status: Offline Thanks Meter: 0 | How do I convert the X550 EEprom_unlocked ..... cause it doesnt recognise with the program ...... thanks for your reply .... I unpacked it ... do I need to add .sep in the end ...... thanks |
04-09-2008, 11:31 | #6 (permalink) |
Member: 691182 Status: Offline Thanks Meter: 0 | thanks but still same problem Wrote eeprom but the real problem is while flashing ffs it stops at 95% : Power ON phone... Phone detected! Loading flash applet... Getting Flash ID... Flash chip type : SPANSION S29WS256N Number of sectors : 134 Setting 460800 bps... Loading second loader... 2nd boot OK! Formatting FFS... FFS Format OK! Creating directories ... Dir create OK! Uploading files to FFS... /java/_suite_8.png It doesnt write these file ...... Thanks if could anyone help me ...... |
05-28-2008, 16:54 | #7 (permalink) | |
Freak Poster Join Date: May 2004 Age: 49
Member: 65351 Status: Offline Thanks Meter: 16 | Quote:
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 | rafik2533 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-04-2010 20:38 |
X550 Unlock Problem | ahmedksal | UST Pro II | 5 | 10-05-2008 15:53 |
x550 charging problem | bagii | Samsung Hardware Repair | 0 | 04-15-2008 11:49 |
X550 dead. Problem to flash | UnlockBR | NSPRO | 11 | 11-29-2007 13:55 |
x550 flashing problem | ..:::Gsm india:::.. | UST Pro II | 0 | 09-10-2007 14:53 |
