Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Martech Products > Martech CLIP / Box / Key
Old 01-14-2006, 20:29   #1 (permalink)
samirsana's Avatar
Member: 77845
Thanks Meter: 348
help s65 Martech lite
UNLOCK ALL LOCKS
ERROR (03.04)
Not correct SP-Blocks in EEprom.
Probably EEprom area is damaged.
Please check phone. If doesn't work:
1) Upload correct EEprom...
2) Use "Repair IMEI" funct
WIRIT EEPROM ARERA
ERROR (49.02)
[ERASE_FLASH_02](5B)
At address: 00220000
Old 01-15-2006, 00:36   #2 (permalink)
MARTECH's Avatar
Member: 78421
Thanks Meter: 987
Probably your USB port is too weak for powering box+adapter+phone...
1) please connect external power supply (about 3.9/4V) in place of phone's battery (+ and - pins)
and try again...
- write new eeprom
- make "IMEI Repair"
If you'll still have problems, please contact [email protected]
and describe everything step by step...
Regards!
Old 01-15-2006, 08:28   #3 (permalink)
Member: 133415
Thanks Meter: 46
i have the same problem
and try again...
- write new eeprom
Regards!
I use box+adapter+phone but the test point in the picture sotware of martech not funcion with my s65 ,after i use this in the picture and the phone is conected but cant find the phone model (error) i select dont check phone type for repayr and i flash it with eprom in finish the phone cant did repayr and is dead.any solution martech
Old 01-17-2006, 12:30   #4 (permalink)
samirsana's Avatar
Member: 77845
Thanks Meter: 348
MARTECH is goooooooooooooooooooooooooooooooooooooood
3 s65 dead is flash ok good work martech
Old 01-25-2006, 10:12   #5 (permalink)
Member: 25852
Thanks Meter: 31
i made many s 65 and no problems im using martech clip never killed phone and many was repaired
Old 05-08-2006, 12:21   #6 (permalink)
Registered User
Member: 59351
Red face s65 unlocking
i have problem for unlocking, i use tp3 and convert cable, but showing not connected,anybody know how to solve the problem
Old 05-16-2006, 10:01   #7 (permalink)
alfamobilTEAM's Avatar
Member: 22553
Thanks Meter: 7
Are you sure you have connected the adaptor for X65 series? Please post here wich erorr you get exactly.
Regards!
Old 05-16-2006, 20:15   #8 (permalink)
Member: 198489
Power again connect A after pont.
Old 05-16-2006, 20:23   #9 (permalink)
Member: 22553
Thanks Meter: 7
Did you try in "MANUAL MODE" ?
Regards!
please hellp, register for martech lite inmobil Martech CLIP / Box / Key 2 04-04-2006 05:46
help.. About martech lite and martech Plus josemi21 SIEM Service Tools 1 12-22-2005 21:09
Martech Lite - HELP ME!!!!!! rtcaus SIEM Service Tools 4 10-28-2005 18:57
Help!!! S65 is dead!! superzeif S-Gold Based Phones 1 02-07-2005 19:12
Help! s65 unlock! zao S-Gold Based Phones 1 01-31-2005 15:46
Page generated in 0.21890 seconds with 10 queries
