Can windows XP be installed on iMac apple G5?? I have got an apple iMac G5 and was wondering if i could load xp on it?? It has tiger 10.4.7 i think at the moment. |
Yes you can, install virtual PC and enjoy BR |
yeh but does it have to be intel based or apple based? My machine is apple chip and do u have any links where i can get more info from? |
Virtual PC 7.0 for MAC download this torrent and you must have torrent client like for exemple Azureus http://thepiratebay.org/details.php?id=3433533 |
it's for apple machine PPC ( power pc) |
Does not matter Intel or PPC CPU, That software (Virtual PC) is very very slow, I dont think you can work with unlocking softs with it, but simply running simple exe`s is possible :) Mac OS X Leopard (10.5), will have possibilities to run Windows apps as well as Mac apps as Steve Jobs announced :) Regards, B |
I doubt e.g. execryptor or themida would partner with VPC :) anyway, if you have iMac, it means you should have Intel CPU, thus maybe you can install XP natively on the machine (you might encounter problems when gathering drivers though) |
Virtual PC is not the same thing as dual booting XP and mac OS. Virtual PC is an emulator. it uses software to create a virtual x86 machine and runs windows in that. As BB-gsm said it's very slow, it's like having windows xp installed on a pentium II, but it's an alternative solution to allow you using "windows programs". And about Mac OS X v10.5 "Leopard" Apple intended this release at the end of 2006 or early 2007.( piano !!!) BR. |
iMac G3, G4, G5 are PPC based iMac Core Duo is Intel Core Duo based And Windows can not be installed on any of them "Natively" :) Regards, B |
Regards |
And on PPC based ones to change CPU, etc, will be also possible to install Windows :) |
right, I overlooked something, I thought the term iMac means the Intel-based Macs (which should be logical). but, Intel Core (either Solo or Duo) is generally an x86, so I can't see any reason why Windows would be incompatible with it. |
It is not all about CPU! Mac has no bios as PC, no booting from cd/dvd as PC, Mac is Mac and PC is PC .. When you have mac you will know that, and when you want Windows on Mac it is another case, a pity case :) @ MC Harami If you want to sell it, contact me in PM . |
@crusher: iMac does not stand for "intel based macs". iMac is just the name of the standar mac model, and it was called iMac years before the intel based macs. There's no name for intel based macs as a product. They're just iMac with intel core duo. And bb-gsm is right, macs have no bios. Macs use another system, generally called EFI. In Mac platform, the operating system has a very deep control and knowledge of the hardware, hence the better performance of macs. In a PC, windows just uses a lot of generic drivers to try to determine, in the best conditions possible, what the hell of hardware do you have inside. So, in some terms, windows is hardware-independent. It seems, the more compatible you are, the worse the performance you have. Regards |
WOW guys i am impressed with the response, some real apple experts. So in term you saying its possible but dont bother because its too slow. |
