Off Topic Zone Here all other messages... |
07-15-2006, 18:41 | #16 (permalink) |
Freak Poster Join Date: Mar 2002 Location: Gran Canaria
Member: 10087 Status: Offline Thanks Meter: 2 | If you have a powerpc Mac: you only can use Virtual PC and emulate, as told by bb-gsm If you have an intel core duo Mac: 1) you can use apple's solution "boot camp" (it will flash the EFI) and you can install XP and boot with macosx or windows xp 2) you can use the hacker's solution previous to boot camp, it also will modify the EFI and you get the same result but without the prepared set of drivers of boot camp, so computers behaviour can be erratic. 3) you can use the boot camp solution described in point 1, and instead of booting with xp, you can boot with macosx and use the application "parallel" to run xp from a windows in macosx In any case, can't imagine why a mac user could need xp Do you agree with above, bb-gsm? |
07-15-2006, 19:56 | #17 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: GEORGIA,Tbilisi
Member: 75765 Status: Offline Thanks Meter: 722 | Quote:
But me personally never played with those tools with EFI Last edited by BB-gsm; 07-15-2006 at 20:06. | |
07-15-2006, 20:12 | #18 (permalink) |
Member: 10087 Status: Offline Thanks Meter: 2 | Just for aditional technical infom, check this http://en.wikipedia.org/wiki/Extensible_Firmware_Interface |
07-15-2006, 21:03 | #19 (permalink) | |
Registered User Join Date: Sep 2002 Location: No Man's Land
Member: 15858 Status: Offline Thanks Meter: 10 | Quote:
we can choose what we want to boot from, also there is linux distribution ( unbuntu live ) that we can test it without installing. I have PowerBook G4 with two OS : tiger and ubuntu 6.06 and works perfectly (not for unlocking, it' for another usage ) BR. | |
07-17-2006, 10:16 | #21 (permalink) |
Member: 10087 Status: Offline Thanks Meter: 2 | The sense of the phrase was to establish that, in a PC, you have the BIOS, a small hardware-based firmware that allows you to control some harware options in order to make the basic process of configuration and preparation to boot. In Mac there's no need of a such a system, because instead os using a BIOS, a separated program to setup the hardware and the boot behaviour, Mac uses a system with a boot loader that is used by the operating system as well. So, there's no need to establish the boot proceediment as a separated process. (Also, that's what you loose when you use XP on an Mac intel, you loose the intimate hardware control from the operating system). Well, maybe is a weird thing. In other sense, we can talk about the PC as a hardware item where you can use a software. Mac is an union, hardware and software has the same horizontal architecture and ierarchy (whether using Mac OSx, ubuntu, XP with boot camp or whatever). Regards |
Auto select the firmware can only be installed on the Phoenix product folder?[SOLVED] | ken6430841 | Cyclonebox | 10 | 11-16-2009 09:01 |
Cool *** Windows XP Mobile Skin On my RAZR V3 | iviyst | Motorola P2k | 1 | 06-17-2008 02:06 |
update 2.07 can be installed on a single PC Help | hassenmobile | HWK | 14 | 03-23-2008 15:54 |
HELP: Can TomTom 6 (UIQ3) be installed on a W950i? | Orgazmic | GPS devices , Navigators & Maps | 43 | 03-30-2007 02:09 |
Help :- Can 3rd party apps. be installed on 6230i | LeetNuke | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 08-16-2005 15:10 |
