Off Topic Zone Here all other messages... |
View Poll Results: Dialog GPRS | |||
Dialog GPRS now enabled for Chionese phones | 0 | 0% | |
Dialog MMS Settings works 100% on chinese phones | 0 | 0% | |
Voters: 0. You may not vote on this poll |
08-18-2009, 06:54 | #1 (permalink) |
Junior Member Join Date: Aug 2004 Location: Sri Lanka
Member: 76067 Status: Offline Thanks Meter: 1 | Dialog GPRS Settings for various Chinese phones Configuring WAP/GPRS/Internet Services Using the Data Accounts Created 1. Open Services Menu. 2. Open WAP. 3. Open Settings. 4. Open Edit Profile. 5. Create/Edit a Profile and enter the following values: For Dialog GPRS Profile: Rename Profile: Dialog GPRS Homepage: www.dialogwap.com Data Account: Dialog GPRS (this data account is the one you have created) Connection Type: HTTP Proxy Address: 192.168.122.2 Proxy Port: 8080 Username: leave it blank Password: leave it blank 6. Save the Profile. 7. Activate the Profile. 8. WAP/GPRS/Internet services now ready to use. In case you encounter errors, double check the Data Account and Profile created. In some cases you need to restart the phone. Configuring MMS Using the Data Accounts Created 1. Open Messages. 2. Open MMS. 3. Open Message Settings. 4. Open Server Profile. 5. Create/Edit a Profile and enter the following values: For Dialog MMS Profile: Rename Profile: Dialog MMS Homepage: http://mms.dialog.lk:3130/mmsc Data Account: Dialog MMS (this data account is the one you have created) Connection Type: HTTP Proxy Address: 192.168.122.2 Proxy Port: 8080 Username: leave it blank Password: leave it blank 6. Save the Profile. 7. Activate the Profile. 8. MMS services now ready to use. In case you encounter errors, double check the Data Account and Profile created. In some cases you need to restart the phone. ---------------------------------------------------------------------------------- First Take Service Menu 2) Go to Data Account - GPRS - Then Edit a Settings below the settings Account Name : Dialog GPRS APN: Prepaid Customer: ppwap Postpaid Customer: www.dialogsl.com Auth.Type : Normal Then Save It Then From Service Menu select WAP 2) Settings - Edit Profile - Change any existing as Follows Rename Profile : Dialog GPRS Home page : www.dialogwap.com Data Account : Dialog GPRS (Which is we recently created on GPRS) 3) Then Save it and don’t bother about Connection Type and Activate This Profile ************************************************** ***** Manual Dialog Gprs Settings
Dialog GPRS settings for China mobile: Account Name: Dialog GPRS Homepage: www.dialogwap.com User Name: Blank Password: Blank Access Point Settings: Proxy: Enabled Proxy Address: 192.168.122.2 Proxy Port: 8080 Gateway: 192.168.122.2 Proxy Port: 9201 Data Bearer: Packet Data Bearer Settings: Packet Data Access Point: Prepaid Customer: ppwap Postpaid Customer: www.dialogsl.com Network type: IPV4 Authentication: normal User Name: Blank Password: Blank ************************************************** ************* Cheers! Intiqab Rawoof [email protected] |
The Following User Says Thank You to Intiqab For This Useful Post: |
L6 GPRS settings for Pakistan | someone2408 | Motorola P2k | 1 | 05-21-2006 21:55 |
need o2 gprs settings for c500 | jonny3803 | HTC & PDA WM( With Touchscreen) | 0 | 10-04-2005 20:08 |
Unlocking internet WAP and GPRS settings for my x-55 | civkar1 | ARM9 BASED M62 / M62+ | 0 | 08-26-2005 13:48 |
Unlock GPRS settings for NEC 515/525 | tical | NEC | 0 | 02-18-2005 08:20 |
need vodafone gprs settings for spv e100 | mikehollyy | Various | 0 | 09-18-2003 09:38 |
