Off Topic Zone Here all other messages... |
07-01-2006, 19:50 | #1 (permalink) |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | -++About MSN 80048820 error ++- Code: Sorry, we were unable to sign you in to the MSN Messenger at this time. Please try again later. To let us try and troubleshoot the problem, click the Troubleshoot button. 80048820 Fix this error / possible solutionThis error seems to indicate a problem with MSN Messenger’s encryption routines. The usual cause is that the time on your computer is not correct. To correct the time on your computer, double-click the clock in the bottom right of your screen, in the window that appears you should check both the time and date.If you use Windows XP, you can automatically correct the time by clicking the "Internet Time" tab, next click the "Update Now" button. at last i found i changed the system date to 2004, when i change that back ,all ok, hehe... waste about 2 hours! so when you met this problem pls check about system date first ,and then check BR., Denis |
Please help me. Question about MSN | tommy_123570 | Chinese Models & Cloned Phones | 0 | 03-05-2009 09:12 |
msn messenger error? | romeoryu | BlackBerry (RIM) | 3 | 01-08-2009 23:06 |
About MSN Software~ Help Plz T.T | Thaddeus | Nokia Multimedia | 2 | 06-24-2007 14:46 |
About ThunderStorm - Updater error ??? | .::Gsmdenis::. | ThunderStorm Box | 10 | 06-14-2006 03:01 |
Question about a final error when flashing T610 using test point under Win XP | lilich62 | DIV | 0 | 07-22-2004 01:43 |
