Off Topic Zone Here all other messages... |
11-16-2007, 13:08 | #1 (permalink) |
Junior Member Join Date: Oct 2007
Member: 606946 Status: Offline Thanks Meter: 0 | FLV on iPhone Converter Hope this guide give you a spring breeze. Step1: Add Files Click the ‘+’ button to choose the FLV files. If want to delete one file, click the ‘-’button. And click ‘x’ buttone, you can delete all files. Step2: Crop Video Click the ‘1 Crop’ button under the File panel to crop your file. Tip1: You can drag the frame to crop the video or adjust the parameters as you like. And click ’Select all’ will return the whole video. Tip2: Select ‘Add image water mark’ to the video and edit it. Step3: Settings Click the ‘2 Settings’ button under the File panel to select settings. Tips: ‘Select a profile’ feature provides the target format, eg : iPhone Video MPEG-4 format. Then use ‘Include video/ audio in output file’ button to set the proper parameters. Step4: Convert When everything setted OK, click ‘3 Convert’ and the program will start converting your file(s). After a while you can appreciate your favourite video(s) in the output folder you have specified. Done, just so easy! FLV on iPhone |
