Unlock Server
Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Off Topic Zone
Off Topic Zone Here all other messages...
Old 01-27-2005, 03:50   #1 (permalink)
moustafatch's Avatar
Member: 21750
Sonork: 100.62509
hard disk don't boot any more
i just install sst 5,37 in my pc
program working 10000000% and when i restart the pc i get boot error
my hard disk is totaly damedge
plzzzzzzz any one can help to repair the hard disk
my hard disk don't boot any more and i just need to make backup for my data
hard disk is not proplem for me i just want to save my data
plz if any know selution share it
Old 01-27-2005, 06:31   #2 (permalink)
gabiz_ro's Avatar
Member: 29006
what windows you have installed?
try to repair mbr of hdd
in 98 try fdisk/mbr
in xp fixmbr (not sure that's name of command,type help and see what is like that)
but you need to boot from another source.and for future some bios have some kind of protection for mbr,try to keep active that.
Old 01-27-2005, 08:53   #3 (permalink)
Member: 21750
Sonork: 100.62509
i install the program in winxp
and i just conect my killed HDD is slave in other pc and waiting the steps to do
in winxp fix mbr wrong command
Old 01-27-2005, 09:42   #4 (permalink)
gabiz_ro's Avatar
Member: 29006
that command is available only when boot from cd and choice repair
http://www.microsoft.com/resources/d...ns_fixmbr.mspx
and this command write new mbr on hdd.maybe is enough to repair.
Old 01-27-2005, 16:52   #5 (permalink)
tigertrn's Avatar
Member: 84922
I am not Shure but U may try some ways:
1. Under DOS type "fdisk /mbr" don't forgot the /mbr because uoy will start the program to split your HDD. This command clear and in some cases restore HDD boot records. If it not work try:
2. Use Partition Magic for DOS, and try to recover your HDD boot record.
3. Go to web site of the your HDD maker (e.g. if your hdd is maxtor go to maxtor.com) and try in support area to find and download the program which can do some manipulations with your HDD, and try to recover the HDD with her.
4. Try to recover HDD boot sectors with other recovery software.
Note: These recovers (except 1st) can destroy all data to your HDD , but if they can help to some people I will be happy . But the information is in the internet and you can download wen you need.
Best regards, and good luck to averyone.
Old 01-27-2005, 17:11   #6 (permalink)
espinoza's Avatar
Member: 45752
Connect your "bad" hard disk in other pc (win9x o NT) in IDE 2 or IDE 1 but SLAVE and power on, now you can "SAVE" all your data a "new" pc. If your bad hard disk is NTFS partition, ONLY working with any Win NT (2000, XP)
Save your data and after make fdisk/mbr > fdisk > format and reinstall OS
Hard Disk Repairer Tool atin_garg2005 Nokia Multimedia 60 03-30-2009 20:02
new crack for SST saving on hard disk and easy to use MaFiaaa Siemens-Benq RingTones and WallPapers 51 07-18-2005 08:00
Help me .:hack3r2k:. 338 don't ring any more after unlock LAj FuriouS II 4 03-11-2005 11:14
Warning! Using this crack will destroy hard disk codec_romania Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 03-31-2002 03:47
I have the prog that RECOVERS THE CRASHED HARD-DISKS FROM DB16A! mihut Alcatel & TCL Old Models 1 02-13-2000 12:12
Page generated in 0.63201 seconds with 11 queries
