Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Off Topic Zone
Off Topic Zone Here all other messages...
Old 04-29-2009, 03:29   #1 (permalink)
Member: 1020309
Sonork: 10001
How to put DVD and video on iPhone, iPod, Zune, PSP, Apple TV, BlackBerry,walkman,zen
The article includes two parts.
Part 1: Rip DVD to iPhone, iPod, Zune, PSP, Apple TV, BlackBerry,walkman,zen, archos,iRiver,Xbox, mobile phones etc
[img]http://www.4videosoft.com/images/box/**********-platinum.jpg[/img]
Part 2: Convert video to iPhone, iPod, Zune, PSP, Apple TV, BlackBerry,walkman,zen, archos,iRiver,Xbox, mobile phones etc
Part 1: How to rip dvd
Step 0 Install and run 4Videosoft DVD Ripper Platinum
Step 1: Import DVD.
Place the DVD into your DVD drive and click the “Load DVD” button to load DVD.
[img]http://www.4videosoft.com/images/guide/**********-platinum/**********-platinum.gif[/img]
Step 2: Video settings.
Select the output video format you want from the “Profile” drop-down list.
Step 3: Click “Open” button to open your output destination file.
Step 4: Start conversion
Click the “Start” button to start your conversion and in a short while it will be finished.
Part 2: How to convert video
Preparation: Download and install 4Videosoft Video Converter Platinum
After you download it, double click the file and follow the set-up instruction to install it.
Step 1: After you finish the installation, the friendly user interface will appear on your desk. Click “Add File” to load your video sources.
Step 2: Set output video format
Click "Profile" button from the drop-down list to select the exact output video format that is the most suitable for your player. You can click the "Settings" button to set parameters of your output video such as such as Resolution, Video Bitrate, Frame Rate, Audio Channels, Sample Rate, etc. to get the best video quality as you want.
Step 3: Click the "Start" button to start the conversion.
Tips----- Basic functions for all the 4videosoftware:
1. How to change your video effect
If you want to adjust the effect of your movie, please click the “Effect” button and a pop-up effect window will appear. It allows you to edit your movie’s effect including “Brightness, Contrast, Saturation and Volume”.
2: How to crop off the black edges and adjust the size of video play region
By using the "Crop" function you can crop off the black edge of your video and you can also drag the line around the video image to adjust the video play region to fit for your mobile devices
3: How to split your video
The "Trim" function also servers as a video splitter for you to get any time-length video episode. You can set the "Start Time" and "End Time" to set the exact time-length of the clip or you can directly drag the slide bar to the position you want.
4: How to join the videos
If you would like to put several files into one output file, please tick the check box of the “Merge into one file”.
5: How to save your favorite picture
If you like the current image when preview video, you can use the "Snapshot" option. Just click the "Snapshot" button, the image will be saved and you can click the "Open" button next to "Snapshot" button to open your picture.
The Following User Says Thank You to iloveipod0909 For This Useful Post:
Old 05-27-2009, 08:20   #2 (permalink)
samirov-gsm's Avatar
Member: 759168
nice work...............
Page generated in 0.19548 seconds with 11 queries
