Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Off Topic Zone
Off Topic Zone Here all other messages...
Old 11-25-2004, 15:55   #1 (permalink)
Member: 39561
pls somebody translate this to english language
Conectar el cable al PC y al teléfono (el teléfono encendido, sin tarjeta sim y con la batería bien cargada). Marque la casilla UNLOCK y haga click en "DO JOBS".
Acto seguido el programa leerá la información del teléfono y le pedirá que apague el terminal mientras calcula y así debe hacerlo (tarda un poco en calcular).
Ahora aparecerá una ventana como en la siguiente imagen en la cual debe hacer click en YES.
Ahora el programa le pedirá que pulse el botón de encendido del teléfono y una vez que lo pulse espere unos segundos.
Cuando se muestre como en la siguiente imagen ya está liberado.
Old 11-25-2004, 16:36   #2 (permalink)
Member: 33690
Here
HI,
NEXT TIME USE ALTAVISTA TO TRANSLATE. LISTED HERE BELOW IS THE TRANSLATION FROM SPANISH TO ENGLISH:
To connect the cable to the PC and the telephone (the ignited telephone, without card sim and with the loaded affluent battery). Mark square UNLOCK and you do click in "DO JOBS". Immediately afterwards the program will read the information of the telephone and it will request to him that it extinguishes the terminal while calculates and thus it must do it (a little in calculating takes). Now it will appear a window like in the following image in which it must do click in YES. Now the program will request to him that the button of ignition of the telephone presses and once presses waits for it seconds. When one is as in the following image already it is released.
Old 11-25-2004, 16:53   #3 (permalink)
Member: 1758
"Connect the cable to the PC and to the mobile (with the mobile powered on, without simcard and with the battery full charged). Click on Unlock button and then on "DO JOBS".
The software will read the information on the mobile and will ask you to power off while calculates (takes a while to calculate)
Now will show a windows where you must click on YES.
The application will ask you to push the power button one time, once you push the button will take a few seconds.
When shows the next image, it's done. "
I hope to be well translated
Old 11-25-2004, 17:27   #4 (permalink)
Member: 33690
Hello
@MrLavrador
I hope to be well translated [/QUOTE]
I DO HOPE THAT IT WILL HELP ONLY. NO I AM NOT A QUALIFIED TRANSLATOR. IS THE TRANSLATION RIGHT. PLEASE ADVICE AND THANKS
Old 11-25-2004, 17:34   #5 (permalink)
Member: 1758
I didn't saw your post if i did i wouldn't had reply it. Chill out.
How to convert sgh-i600 to english language-pls help *samson69* Samsung Flashers, Software, Firmware. 0 05-29-2009 13:02
How to convert sgh-i600 to english language-pls help *samson69* Samsung Flashers, Software, Firmware. 0 05-29-2009 12:57
can anyone translate this in english ?? amitks_in Griffin 2 07-01-2005 08:06
can anyone translate this in english ?? amitks_in UFS2 + UFS3-Tornadoflasher 1 06-30-2005 21:05
Translate this to english from czech language, please mr_x4you Off Topic Zone 3 12-08-2003 14:23
Page generated in 1.28277 seconds with 11 queries
