Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Off Topic Zone
Off Topic Zone Here all other messages...
Old 11-17-2001, 23:39   #1 (permalink)
Member: 1584
Question Question to computer specialists
For unlocking i use a notebook with AMD K6 400 processor,many months everything was ok.Since 3 days it brings me down. When i connect with cable to Logomanager or nokiatool - phone not connected,also with siemens phones-no connection.But with ericsson phones no problem.<br />I formated the disk new,installed once more win98, no result,the same faults.All cables are checked on another Pc and they are working well.<br />What shall i do - throw out the laptop from my window ? Or somebody can help me ?<br />Thx in advance<br />Vala
Old 11-18-2001, 00:04   #2 (permalink)
Member: 5363
Post
just a couple of stupid questions first.
do you use the same com port for all phones<br />has anything been changed in the bios<br />have you installed any additional software recently<br />Have you tried conecting any other devices to the com port<br />what version of windows are you using<br />when reinstalling did you formay the drive, format it unconditionally<br />also have you tried formatting the mbr
Old 11-18-2001, 01:45   #3 (permalink)
ARC
ARC's Avatar
Member: 5019
Sonork: 100.110196
Post
Check and change your LPT port setting in bios:
EPP/ECP - EPP - ECP
may help
Old 11-18-2001, 11:21   #4 (permalink)
ARS
Member: 2721
Post
If your cable use power from port, try it with external power. I have original cable for Ericsson 6xx and it works well on desktop PC, but on notebook not....
Old 11-18-2001, 13:59   #5 (permalink)
Member: 1584
Post
@melfalcon<br />yes, use the same com port for all phones<br />i have nothing changed in the bios<br />i have not installed any additional software recently<br />No,i dont have tried conecting any other devices to the com port (i have only phones here)<br />I tried win 98 and 98se version of when reinstalling you formay the drive, format it unconditionally. Yes i made format c: and got no error messages
@ARC<br />changing LPT - no result,same troubles
Old 11-19-2001, 01:32   #6 (permalink)
Member: 5363
Post
see if you can get a com port mouse and connect it up. see if it works.
just to check the com port
Old 11-19-2001, 05:44   #7 (permalink)
Member: 1584
Post
com port mouse dont work. But why work the com port with ericsson phones ? i am really confused.
Old 11-19-2001, 07:35   #8 (permalink)
Member: 5363
Post
well it would appear to be a faulty com port.\why\the ericsson cable is working i dont know. Check your drivers for the com port are installed ok without conflict. Check all pins are intact on the com port.
cant really think of much else!
Old 11-19-2001, 10:56   #9 (permalink)
Member: 1715
Post
Hi Vala...
most likely is your com port broken...<br />the max use power from your com port , but not all connectors with max232 uses the same powersupply pins from your com port...
try with volt meter : pin 5 ground<br /> pin 7 rts +12 volt<br /> pin 1 carrier detect +12 v<br /> pin 8 cts +12 volt<br /> pin 4 dtr +12 volt
<br />Perhaps one of them is defect..., you can make a cable with two open connector db9 male & female and put it between your com port and serial connector of your datacable... now with volt meter compare your siemens cable and erricson cable to see where the power is needed...
greetingz Timitiz..
Old 11-20-2001, 05:25   #10 (permalink)
Member: 1584
Many thanks to all who help me. In the meantime i solved this problem - i sold the notebook and got a new one <img src="biggrin.gif" border="0">
Vala
Connection question to Computer kraxx Smart-Clip 4 02-23-2006 04:29
Basic question. 7250i and noname COM cable, howto connect to computer? just for sync. Shved Nokia Digital Core Technology 4 ( DCT-4 ) 0 01-23-2005 17:41
Some Question for Network specialists Meam Off Topic Zone 0 12-09-2001 12:39
Page generated in 0.42679 seconds with 11 queries
