Off Topic Zone Here all other messages... |
12-17-2017, 08:43 | #16 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | More Easy Step Here 1-Copy Sonork Setup In Drive C 2-Open Cmd From Startup And Run As Administrator 3- Type CD C:\ Now Press Enter 4-Now Type/Copy Text From Setup- sonork-client-installer Then Press Enter Now You Sonork Setup Run And Install On Your Pc Follow Next Step For Install Sonork. Image Last edited by Deepesh Sharma; 12-17-2017 at 08:51. Reason: Add Image |
The Following 10 Users Say Thank You to Deepesh Sharma For This Useful Post: |
07-23-2018, 11:54 | #17 (permalink) | |
No Life Poster Join Date: Oct 2008 Location: DUBAI , PAKISTAN
Member: 888420 Status: Offline Sonork: 100.1611861 Thanks Meter: 394 | Thanks Quote:
so easy and very good solution thanks bro | |
The Following User Says Thank You to PlayGsm For This Useful Post: |
09-13-2018, 21:02 | #18 (permalink) |
Freak Poster Join Date: May 2016 Location: United States Age: 41
Member: 2567735 Status: Offline Sonork: 100.1678197 Thanks Meter: 24 | This doesn't seem to work on windows very well anymore, especially with the newest build. I'm on the latest preview. Seems laggy and wont connect to server. Anyone else same issue? |
01-02-2019, 02:32 | #19 (permalink) |
No Life Poster Join Date: Nov 2001 Location: morocco larache Age: 51
Member: 7334 Status: Offline Sonork: 100.112291 Thanks Meter: 47 | no brother try this solution it's work well for me Lot of thanks to Deepesh Sharma More Easy Step Here Here More Easy Step- 1-Copy Sonork Setup In Drive C 2-Open Cmd From Startup And Run As Administrator 3- Type CD C:\ Now Press Enter 4-Now Type/Copy Text From Setup- sonork-client-installer Then Press Enter Now You Sonork Setup Run And Install On Your Pc Follow Next Step For Install Sonork. Image |
01-02-2019, 23:51 | #20 (permalink) |
Member: 2567735 Status: Offline Sonork: 100.1678197 Thanks Meter: 24 | Problem isn’t installing, it’s not connecting. This software has problems with Microsoft surface devices Sent from my iPhone using Tapatalk |
01-31-2019, 13:52 | #21 (permalink) |
Freak Poster Join Date: Dec 2011 Location: Jeddah
Member: 1708749 Status: Offline Sonork: Nil Thanks Meter: 14 | before formatting your computer copy the sonork folder located in C/ program files after formatting your computer paste the same folder in C/ program files and then INSTALL fresh SONORK CLIENT ..while installing it will ask you sonork folder already exists ,,do u want to replace it CLICK YES THIS tutorial is for people who forget sonork password or cant get old messages |
