05-31-2006, 05:55 | #1 (permalink) |
Junior Member Join Date: Dec 2002 Age: 52
Member: 18750 Status: Offline Thanks Meter: 1 | A31 can not unlock with Dreambox I have tried to unlock A31 with TP but the phone is not booting. I have tried with normal cut track after a picture i found on the forum, the phone booting bat did not unlock. I attached a picture . |
05-31-2006, 14:46 | #3 (permalink) | |
Freak Poster Join Date: Oct 2005 Location: KM64tw Age: 37
Member: 187149 Status: Offline Sonork: 100.1611848 Thanks Meter: 33 | Quote:
**** you and your updates!!!!!!!!!!!!! | |
06-02-2006, 11:13 | #4 (permalink) |
Insane Poster Join Date: Aug 2005
Member: 170122 Status: Offline Thanks Meter: 14 | A31 does not unlock Hi I have the same problem as specified above. I did not succed to boot the phone with testpoint. Only after I have cuted the track it connected but ... the result was Error: Invalid configuration, please check model name Error: Failed. Phone info: A31, v7, Locked to Vodaphone Spain Hope to have a solution as soon as posible. BR Florin |
07-17-2006, 10:50 | #8 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: dreambox
Member: 241271 Status: Offline Thanks Meter: 30 | Quote:
07-18-2006, 03:52 | #9 (permalink) |
Freak Poster Join Date: Apr 2005 Location: china Age: 45
Member: 142233 Status: Offline Thanks Meter: 0 | ok i Connect testpoint to phone pcb TP DBSS not work Always show “working....‘ i cut phone pcb and use "cut track" mode DBSS work ok can repair flash and unlock. my testpoint work ok with other phone (c60...) thanks |
07-18-2006, 04:56 | #10 (permalink) | |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Quote:
In some cases is better to use external power to A31 PCB instead of red wire that coming with test cable from DreamBox and repeat operation with test point few times - there I/O levels from E-Gold lite are problem ... | |
c417 can not unlock with ust pro2 | anwar030 | UST Pro II | 2 | 06-19-2008 10:19 |
E65 can not unlock with Online Unlock | helper_786 | Universalbox | 4 | 04-24-2008 13:47 |
PHILIP S660 CAN NOT UNLOCK with mmodule 1.45 | jham | Infinity-Box | 2 | 04-26-2007 04:44 |
E398 can not unlock with smartclip v2.14 | lianghx | Smart-Clip | 22 | 11-25-2006 20:13 |
SX1 can be unlock with DreamBox | aukonline | DreamBox | 8 | 09-14-2006 16:41 |
