08-25-2008, 09:55 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: PAKISTAN Age: 45
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | A31 Flash but Dead i've recieved one A31 siemens it was blinking only and i flash it by Cut Track TP and Phone successfully flashed but now even its not blinking but it does take power. and also i can't download from support area as well i got the problem Box is authorized but download is disabled. here is the log. Code: [25/08/2008 09:15:16] --- Reading Info--------------------------------------------------------------- [25/08/2008 09:15:16] User selected phone A31 using Normal (Cut track) boot mode [25/08/2008 09:15:17] [25/08/2008 09:15:18] Power On the phone ... OK [25/08/2008 09:15:18] Sending loader ... OK [25/08/2008 09:15:21] Loading application ...OK [25/08/2008 09:15:25] Testing RAM... OK [25/08/2008 09:15:25] Flash Chip = ST M30L0R7000T1, size 16384 Kb [25/08/2008 09:15:25] Phone ID = E02135FF [25/08/2008 09:15:25] Flash IMEI = 358757-00-783746-4 [25/08/2008 09:15:26] Manufacturer SIEMENS [25/08/2008 09:15:26] Model A31 [25/08/2008 09:15:26] Language lg92 [25/08/2008 09:15:26] Version 7 [25/08/2008 09:15:26] Phone IMEI = 358757-00-783746-4 [25/08/2008 09:15:26] SPLock CRC = OK [25/08/2008 09:15:26] Phone Code = 5423 : FF [25/08/2008 09:15:26] SIMCardID = 2A7261 [25/08/2008 09:15:26] Done. [25/08/2008 09:15:26] [25/08/2008 09:15:28] --- Unlocking------------------------------------------------------------------ [25/08/2008 09:15:28] User selected phone A31 using Normal (Cut track) boot mode [25/08/2008 09:15:29] [25/08/2008 09:15:29] Power On the phone ... OK [25/08/2008 09:15:29] Sending loader ... OK [25/08/2008 09:15:34] Loading application ...OK [25/08/2008 09:15:37] Testing RAM... OK [25/08/2008 09:15:38] Flash Chip = ST M30L0R7000T1, size 16384 Kb [25/08/2008 09:15:38] Phone ID = E02135FF [25/08/2008 09:15:38] Flash IMEI = 358757-00-783746-4 [25/08/2008 09:15:38] Manufacturer SIEMENS [25/08/2008 09:15:38] Model A31 [25/08/2008 09:15:38] Language lg92 [25/08/2008 09:15:38] Version 7 [25/08/2008 09:15:38] Phone IMEI = 358757-00-783746-4 [25/08/2008 09:15:39] SPLock CRC = OK [25/08/2008 09:15:39] Phone Code = 5423 : FF [25/08/2008 09:15:43] Writting speed is 146 cps [25/08/2008 09:15:43] Done. [25/08/2008 09:15:43] [25/08/2008 09:16:04] --- Switching On the phone----------------------------------------------------- [25/08/2008 09:16:04] User selected phone A31 using Normal (Cut track) boot mode [25/08/2008 09:16:07] [25/08/2008 09:16:07] Power On the phone ... OK [25/08/2008 09:16:07] Sending loader ... OK [25/08/2008 09:16:20] Error : Failed. [25/08/2008 09:16:20] [25/08/2008 09:20:45] --- Reading Info--------------------------------------------------------------- [25/08/2008 09:20:45] User selected phone A31 using Normal (Cut track) boot mode [25/08/2008 09:20:47] [25/08/2008 09:20:47] Power On the phone ... OK [25/08/2008 09:20:47] Sending loader ... OK [25/08/2008 09:20:51] Loading application ...OK [25/08/2008 09:20:55] Testing RAM... OK [25/08/2008 09:20:55] Flash Chip = ST M30L0R7000T1, size 16384 Kb [25/08/2008 09:20:55] Phone ID = E02135FF [25/08/2008 09:20:55] Flash IMEI = 358757-00-783746-4 [25/08/2008 09:20:55] Manufacturer SIEMENS [25/08/2008 09:20:55] Model A31 [25/08/2008 09:20:55] Language lg92 [25/08/2008 09:20:55] Version 7 [25/08/2008 09:20:56] Phone IMEI = 358757-00-783746-4 [25/08/2008 09:20:56] SPLock CRC = OK [25/08/2008 09:20:56] Phone Code = < NOT SET > : FF [25/08/2008 09:20:56] Done. [25/08/2008 09:20:56] [25/08/2008 09:21:02] --- Reading Full Phone Settings------------------------------------------------ [25/08/2008 09:21:03] User selected phone A31 using Normal (Cut track) boot mode [25/08/2008 09:21:04] [25/08/2008 09:21:04] Power On the phone ... OK [25/08/2008 09:21:04] Sending loader ... OK [25/08/2008 09:21:08] Loading application ...OK [25/08/2008 09:21:12] Testing RAM... OK [25/08/2008 09:21:12] Flash Chip = ST M30L0R7000T1, size 16384 Kb [25/08/2008 09:21:12] Phone ID = E02135FF [25/08/2008 09:21:12] Flash IMEI = 358757-00-783746-4 [25/08/2008 09:21:12] Manufacturer SIEMENS [25/08/2008 09:21:12] Model A31 [25/08/2008 09:21:12] Language lg92 [25/08/2008 09:21:12] Version 7 [25/08/2008 09:21:13] Phone IMEI = 358757-00-783746-4 [25/08/2008 09:21:13] SPLock CRC = OK [25/08/2008 09:21:13] Phone Code = < NOT SET > : FF [25/08/2008 09:21:21] Total 386 block(s) downloaded : [25/08/2008 09:21:21] EEFULL - 200 block(s) [25/08/2008 09:21:21] EELITE - 186 block(s) [25/08/2008 09:21:24] Done. [25/08/2008 09:21:24] [25/08/2008 09:21:26] --- Loading Flash File--------------------------------------------------------- [25/08/2008 09:21:37] Loading "C:\Users\Administrator\Desktop\A31_v7_st_flash.bin"... [25/08/2008 09:21:37] Loading flash for A31 [25/08/2008 09:21:37] Language : lg4 [25/08/2008 09:21:44] Done. [25/08/2008 09:21:44] [25/08/2008 09:21:53] --- Writing Flash-------------------------------------------------------------- [25/08/2008 09:21:53] User selected phone A31 using Normal (Cut track) boot mode [25/08/2008 09:21:54] [25/08/2008 09:21:55] Power On the phone ... OK [25/08/2008 09:21:55] Sending loader ... OK [25/08/2008 09:21:59] Loading application ...OK [25/08/2008 09:22:03] Testing RAM... OK [25/08/2008 09:22:03] Flash Chip = ST M30L0R7000T1, size 16384 Kb [25/08/2008 09:22:03] Phone ID = E02135FF [25/08/2008 09:22:03] Flash IMEI = 358757-00-783746-4 [25/08/2008 09:22:03] Manufacturer SIEMENS [25/08/2008 09:22:03] Model A31 [25/08/2008 09:22:03] Language lg92 [25/08/2008 09:22:03] Version 7 [25/08/2008 09:22:03] File name : C:\Users\Administrator\Desktop\A31_v7_st_flash.bin [25/08/2008 09:26:12] Writting speed is 67530 cps [25/08/2008 09:26:12] Phone IMEI = invalid IMEI [25/08/2008 09:26:12] SPLock FAILED [25/08/2008 09:26:12] Warning : setting default lock data [25/08/2008 09:26:12] Setting IMEI = 358757-00-783746-4 [25/08/2008 09:26:17] Writting speed is 133 cps [25/08/2008 09:26:17] Done. [25/08/2008 09:26:17] [25/08/2008 09:26:23] --- Repareing------------------------------------------------------------------ [25/08/2008 09:26:24] User selected phone A31 using Normal (Cut track) boot mode [25/08/2008 09:26:25] [25/08/2008 09:26:25] Power On the phone ... OK [25/08/2008 09:26:25] Sending loader ... OK [25/08/2008 09:26:30] Loading application ...OK [25/08/2008 09:26:33] Testing RAM... OK [25/08/2008 09:26:34] Flash Chip = ST M30L0R7000T1, size 16384 Kb [25/08/2008 09:26:34] Phone ID = E02135FF [25/08/2008 09:26:34] Flash IMEI = 358757-00-783746-4 [25/08/2008 09:26:34] Manufacturer SIEMENS [25/08/2008 09:26:34] Model A31 [25/08/2008 09:26:34] Language lg4 [25/08/2008 09:26:34] Version 7 [25/08/2008 09:26:34] Phone IMEI = 358757-00-783746-4 [25/08/2008 09:26:35] SPLock CRC = OK [25/08/2008 09:26:35] Phone Code = < NOT SET > : FF [25/08/2008 09:26:35] Setting IMEI = 358757-00-783746-4 [25/08/2008 09:26:35] New SKey = 98846079 [25/08/2008 09:26:35] New Boot Key = 16BC0A4D-4E388EA1-A2BF3332-340F0F27 [25/08/2008 09:26:35] New Boot Hash = BD69CD4C-86753376-4A1CB117-F99AF8FE [25/08/2008 09:26:36] Default Boot Mode = Normal [25/08/2008 09:26:41] Writting speed is 108 cps [25/08/2008 09:26:42] Done. [25/08/2008 09:26:42] [25/08/2008 09:26:44] --- Unlocking------------------------------------------------------------------ [25/08/2008 09:26:44] User selected phone A31 using Normal (Cut track) boot mode [25/08/2008 09:26:45] [25/08/2008 09:26:45] Power On the phone ... OK [25/08/2008 09:26:45] Sending loader ... OK [25/08/2008 09:26:50] Loading application ...OK [25/08/2008 09:26:54] Testing RAM... OK [25/08/2008 09:26:54] Flash Chip = ST M30L0R7000T1, size 16384 Kb [25/08/2008 09:26:54] Phone ID = E02135FF [25/08/2008 09:26:54] Flash IMEI = 358757-00-783746-4 [25/08/2008 09:26:54] Manufacturer SIEMENS [25/08/2008 09:26:54] Model A31 [25/08/2008 09:26:54] Language lg4 [25/08/2008 09:26:54] Version 7 [25/08/2008 09:26:55] Phone IMEI = 358757-00-783746-4 [25/08/2008 09:26:55] SPLock CRC = OK [25/08/2008 09:26:55] Phone Code = < NOT SET > : FF [25/08/2008 09:27:00] Writting speed is 142 cps [25/08/2008 09:27:00] Done. [25/08/2008 09:27:00] [25/08/2008 09:27:04] --- Switching On the phone----------------------------------------------------- [25/08/2008 09:27:05] User selected phone A31 using Normal (Cut track) boot mode [25/08/2008 09:27:08] [25/08/2008 09:27:08] Power On the phone ... OK [25/08/2008 09:27:08] Sending loader ... OK [25/08/2008 09:27:21] Error : Failed. [25/08/2008 09:27:21] [25/08/2008 09:27:42] --- Writing Selected Settings-------------------------------------------------- [25/08/2008 09:27:42] User selected phone A31 using Normal (Cut track) boot mode [25/08/2008 09:27:43] [25/08/2008 09:27:43] Power On the phone ... OK [25/08/2008 09:27:43] Sending loader ... OK [25/08/2008 09:27:47] Loading application ...OK [25/08/2008 09:27:51] Testing RAM... OK [25/08/2008 09:27:51] Flash Chip = ST M30L0R7000T1, size 16384 Kb [25/08/2008 09:27:51] Phone ID = E02135FF [25/08/2008 09:27:51] Flash IMEI = 358757-00-783746-4 [25/08/2008 09:27:51] Manufacturer SIEMENS [25/08/2008 09:27:51] Model A31 [25/08/2008 09:27:51] Language lg4 [25/08/2008 09:27:51] Version 7 [25/08/2008 09:27:51] [25/08/2008 09:27:59] Total 386 records loaded [25/08/2008 09:28:03] Writting speed is 13594 cps [25/08/2008 09:28:03] Done. [25/08/2008 09:28:03] [25/08/2008 09:28:28] --- Reading Service Info------------------------------------------------------- [25/08/2008 09:28:29] User selected phone A31 using Normal (Cut track) boot mode [25/08/2008 09:28:32] [25/08/2008 09:28:32] Power On the phone ... OK [25/08/2008 09:28:32] Sending loader ... OK [25/08/2008 09:28:46] Error : Failed. [25/08/2008 09:28:46] [25/08/2008 09:28:56] --- Setting up display parameters---------------------------------------------- [25/08/2008 09:28:56] User selected phone A31 using Normal (Cut track) boot mode [25/08/2008 09:28:59] [25/08/2008 09:29:00] Power On the phone ... OK [25/08/2008 09:29:00] Sending loader ... OK [25/08/2008 09:29:13] Error : Failed. [25/08/2008 09:29:13] [25/08/2008 09:29:23] --- Reading Info--------------------------------------------------------------- [25/08/2008 09:29:23] User selected phone A31 using Normal (Cut track) boot mode [25/08/2008 09:29:24] [25/08/2008 09:29:24] Power On the phone ... OK [25/08/2008 09:29:24] Sending loader ... OK [25/08/2008 09:29:28] Loading application ...OK [25/08/2008 09:29:32] Testing RAM... OK [25/08/2008 09:29:32] Flash Chip = ST M30L0R7000T1, size 16384 Kb [25/08/2008 09:29:32] Phone ID = E02135FF [25/08/2008 09:29:32] Flash IMEI = 358757-00-783746-4 [25/08/2008 09:29:32] Manufacturer SIEMENS [25/08/2008 09:29:32] Model A31 [25/08/2008 09:29:32] Language lg4 [25/08/2008 09:29:32] Version 7 [25/08/2008 09:29:32] Phone IMEI = 358757-00-783746-4 [25/08/2008 09:29:33] SPLock CRC = OK [25/08/2008 09:29:33] Phone Code = < NOT SET > : FF [25/08/2008 09:29:33] Done. [25/08/2008 09:29:33] [25/08/2008 09:29:39] --- Repareing------------------------------------------------------------------ [25/08/2008 09:29:39] User selected phone A31 using Normal (Cut track) boot mode [25/08/2008 09:29:41] [25/08/2008 09:29:41] Power On the phone ... OK [25/08/2008 09:29:41] Sending loader ... OK [25/08/2008 09:29:45] Loading application ...OK [25/08/2008 09:29:48] Testing RAM... OK [25/08/2008 09:29:48] Flash Chip = ST M30L0R7000T1, size 16384 Kb [25/08/2008 09:29:49] Phone ID = E02135FF [25/08/2008 09:29:49] Flash IMEI = 358757-00-783746-4 [25/08/2008 09:29:49] Manufacturer SIEMENS [25/08/2008 09:29:49] Model A31 [25/08/2008 09:29:49] Language lg4 [25/08/2008 09:29:49] Version 7 [25/08/2008 09:29:49] Phone IMEI = 358757-00-783746-4 [25/08/2008 09:29:49] SPLock CRC = OK [25/08/2008 09:29:49] Phone Code = < NOT SET > : FF [25/08/2008 09:29:49] Setting IMEI = 358757-00-783746-4 [25/08/2008 09:29:49] New SKey = 30438685 [25/08/2008 09:29:49] New Boot Key = 9846C6F6-7B068E88-77009F1C-180B64BA [25/08/2008 09:29:49] New Boot Hash = 7EC50C70-30F05344-BD0FC3F7-CE7EE2C9 [25/08/2008 09:29:51] Default Boot Mode = Normal [25/08/2008 09:29:56] Writting speed is 109 cps [25/08/2008 09:29:57] Done. [25/08/2008 09:29:57] [25/08/2008 09:30:45] --- Setting Normal Boot Mode--------------------------------------------------- [25/08/2008 09:30:45] User selected phone A31 using Normal (Cut track) boot mode [25/08/2008 09:30:47] [25/08/2008 09:30:47] Power On the phone ... OK [25/08/2008 09:30:47] Sending loader ... OK [25/08/2008 09:30:51] Loading application ...OK [25/08/2008 09:30:54] Testing RAM... OK [25/08/2008 09:30:54] Flash Chip = ST M30L0R7000T1, size 16384 Kb [25/08/2008 09:30:55] Phone ID = E02135FF [25/08/2008 09:30:55] Flash IMEI = 358757-00-783746-4 [25/08/2008 09:30:55] Manufacturer SIEMENS [25/08/2008 09:30:55] Model A31 [25/08/2008 09:30:55] Language lg4 [25/08/2008 09:30:55] Version 7 [25/08/2008 09:30:57] Writting speed is 1 cps [25/08/2008 09:30:57] Done. [25/08/2008 09:30:57] [25/08/2008 09:31:00] --- Switching On the phone----------------------------------------------------- [25/08/2008 09:31:00] User selected phone A31 using Normal (Cut track) boot mode [25/08/2008 09:31:03] [25/08/2008 09:31:03] Power On the phone ... OK [25/08/2008 09:31:03] Sending loader ... OK [25/08/2008 09:31:16] Error : Failed. [25/08/2008 09:31:16] [25/08/2008 10:24:53] [25/08/2008 10:24:53] DBSS Start 3.7 [25/08/2008 11:23:50] [25/08/2008 11:23:50] DBSS Start 3.7 [25/08/2008 11:24:04] --- Loading Flash File--------------------------------------------------------- [25/08/2008 11:24:12] Loading "C:\Users\Administrator\Desktop\A31_079111_service.exe"... [25/08/2008 11:24:13] Language : lg91 [25/08/2008 11:24:16] Done. [25/08/2008 11:24:16] [25/08/2008 11:24:30] --- Writing Flash-------------------------------------------------------------- [25/08/2008 11:24:33] User selected phone A31 using Normal (Cut track) boot mode [25/08/2008 11:24:34] [25/08/2008 11:24:34] Power On the phone ... OK [25/08/2008 11:24:34] Sending loader ... OK [25/08/2008 11:24:38] Loading application ...OK [25/08/2008 11:24:42] Testing RAM... OK [25/08/2008 11:24:42] Flash Chip = ST M30L0R7000T1, size 16384 Kb [25/08/2008 11:24:42] Phone ID = E02135FF [25/08/2008 11:24:42] Flash IMEI = 358757-00-783746-4 [25/08/2008 11:24:42] Manufacturer SIEMENS [25/08/2008 11:24:42] Model A31 [25/08/2008 11:24:42] Language lg4 [25/08/2008 11:24:42] Version 7 [25/08/2008 11:24:42] File name : C:\Users\Administrator\Desktop\A31_079111_service.exe [25/08/2008 11:31:51] Writting speed is 25056 cps [25/08/2008 11:31:51] Done. [25/08/2008 11:31:51] [25/08/2008 11:32:40] --- Repareing------------------------------------------------------------------ [25/08/2008 11:32:40] User selected phone A31 using Normal (Cut track) boot mode [25/08/2008 11:32:41] [25/08/2008 11:32:41] Power On the phone ... OK [25/08/2008 11:32:41] Sending loader ... OK [25/08/2008 11:32:45] Loading application ...OK [25/08/2008 11:32:49] Testing RAM... OK [25/08/2008 11:32:50] Flash Chip = ST M30L0R7000T1, size 16384 Kb [25/08/2008 11:32:51] Phone ID = E02135FF [25/08/2008 11:32:51] Flash IMEI = 358757-00-783746-4 [25/08/2008 11:32:51] Manufacturer SIEMENS [25/08/2008 11:32:51] Model A31 [25/08/2008 11:32:51] Language lg91 [25/08/2008 11:32:51] Version 7 [25/08/2008 11:32:52] Phone IMEI = invalid IMEI [25/08/2008 11:32:52] SPLock FAILED [25/08/2008 11:32:52] Warning : setting default lock data [25/08/2008 11:32:52] Setting IMEI = 358757-00-783746-4 [25/08/2008 11:32:52] New SKey = 55881761 [25/08/2008 11:32:52] New Boot Key = 91B6410E-9CD3799D-0399381C-35101C6B [25/08/2008 11:32:52] New Boot Hash = 781D01F4-D326EA40-A43F45D9-E62C4575 [25/08/2008 11:32:53] Default Boot Mode = Normal [25/08/2008 11:32:59] Writting speed is 104 cps [25/08/2008 11:33:00] Done. [25/08/2008 11:33:00] [25/08/2008 11:33:02] --- Unlocking------------------------------------------------------------------ [25/08/2008 11:33:02] User selected phone A31 using Normal (Cut track) boot mode [25/08/2008 11:33:03] [25/08/2008 11:33:04] Power On the phone ... OK [25/08/2008 11:33:04] Sending loader ... OK [25/08/2008 11:33:08] Loading application ...OK [25/08/2008 11:33:11] Testing RAM... OK [25/08/2008 11:33:11] Flash Chip = ST M30L0R7000T1, size 16384 Kb [25/08/2008 11:33:12] Phone ID = E02135FF [25/08/2008 11:33:12] Flash IMEI = 358757-00-783746-4 [25/08/2008 11:33:12] Manufacturer SIEMENS [25/08/2008 11:33:12] Model A31 [25/08/2008 11:33:12] Language lg91 [25/08/2008 11:33:12] Version 7 [25/08/2008 11:33:12] Phone IMEI = 358757-00-783746-4 [25/08/2008 11:33:12] SPLock CRC = OK [25/08/2008 11:33:12] Phone Code = < NOT SET > : FF [25/08/2008 11:33:17] Writting speed is 138 cps [25/08/2008 11:33:18] Done. [25/08/2008 11:33:18] [25/08/2008 11:35:14] [25/08/2008 11:35:14] DBSS Start 3.7 [25/08/2008 11:35:17] --- Reading Info--------------------------------------------------------------- [25/08/2008 11:35:17] User selected phone A31 using Normal (Cut track) boot mode [25/08/2008 11:35:19] [25/08/2008 11:35:19] Power On the phone ... OK [25/08/2008 11:35:19] Sending loader ... OK [25/08/2008 11:35:22] Loading application ...OK [25/08/2008 11:35:26] Testing RAM... OK [25/08/2008 11:35:26] Flash Chip = ST M30L0R7000T1, size 16384 Kb [25/08/2008 11:35:27] Phone ID = E02135FF [25/08/2008 11:35:27] Flash IMEI = 358757-00-783746-4 [25/08/2008 11:35:27] Manufacturer SIEMENS [25/08/2008 11:35:27] Model A31 [25/08/2008 11:35:27] Language lg91 [25/08/2008 11:35:27] Version 7 [25/08/2008 11:35:27] Phone IMEI = 358757-00-783746-4 [25/08/2008 11:35:27] SPLock CRC = OK [25/08/2008 11:35:27] Phone Code = < NOT SET > : FF [25/08/2008 11:35:27] Done. [25/08/2008 11:35:27] [25/08/2008 11:35:56] --- Switching On the phone----------------------------------------------------- [25/08/2008 11:35:56] User selected phone A31 using Normal (Cut track) boot mode [25/08/2008 11:35:59] [25/08/2008 11:35:59] Power On the phone ... OK [25/08/2008 11:35:59] Sending loader ... OK [25/08/2008 11:36:12] Error : Failed. [25/08/2008 11:36:12] [25/08/2008 11:36:17] --- Loading Settings Map File-------------------------------------------------- [25/08/2008 11:36:19] Loading : C:\Users\Administrator\Desktop\A31_v7_358757007837464_0825-0921.dmap [25/08/2008 11:36:19] Done. [25/08/2008 11:36:19] [25/08/2008 11:36:22] --- Writing Selected Settings-------------------------------------------------- [25/08/2008 11:36:22] User selected phone A31 using Normal (Cut track) boot mode [25/08/2008 11:36:23] [25/08/2008 11:36:24] Power On the phone ... OK [25/08/2008 11:36:24] Sending loader ... OK [25/08/2008 11:36:28] Loading application ...OK [25/08/2008 11:36:31] Testing RAM... OK [25/08/2008 11:36:31] Flash Chip = ST M30L0R7000T1, size 16384 Kb [25/08/2008 11:36:32] Phone ID = E02135FF [25/08/2008 11:36:32] Flash IMEI = 358757-00-783746-4 [25/08/2008 11:36:32] Manufacturer SIEMENS [25/08/2008 11:36:32] Model A31 [25/08/2008 11:36:32] Language lg91 [25/08/2008 11:36:32] Version 7 [25/08/2008 11:36:32] [25/08/2008 11:36:44] Total 377 records loaded [25/08/2008 11:36:51] Writting speed is 7528 cps [25/08/2008 11:36:51] Done. [25/08/2008 11:36:51] Take Care ENJOY |
08-25-2008, 13:00 | #2 (permalink) | ||
No Life Poster Join Date: Mar 2006 Location: Bangladesh
Member: 247758 Status: Offline Sonork: 100.1574842 Thanks Meter: 259 | Quote:
The Following User Says Thank You to hackerbd For This Useful Post: |
08-25-2008, 13:24 | #3 (permalink) | |
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | Quote:
Take Care ENJOY | |
08-25-2008, 16:48 | #5 (permalink) | |
thanks mate for the flash file you saved my day. phone is working fine now. Take Care ENJOY | |
Completely flashed but dead | alamgarh | Infinity-Box | 2 | 02-23-2010 18:06 |
E105 please wait..successfull flashed but dead | 3stanGsm | UFS2 + UFS3-Tornadoflasher | 0 | 08-06-2007 11:27 |
K750 Full Flashed But Dead | smart_mobile | Cruiser Suite | 2 | 11-16-2006 15:40 |
6680 Flashed but dead !!! | tacticman | Nokia Base Band 5 ( BB-5 ) | 4 | 10-30-2006 17:08 |
