04-19-2007, 17:03 | #3 (permalink) |
Junior Member Join Date: Jul 2006
Member: 306331 Status: Offline Thanks Meter: 0 | Drean..error when using functions!! hello friends..my drean this giving that error oh.she is new it was never used.som-- Reading Box Info----------------------------------------------------------- Box SN : Firmware Version : 1.08.0 Firmware Build Info : 2579 14 February 2007 13:18:10 Hardware version : 1.2 Done. --- Unlocking------------------------------------------------------------------ Error : You use not calibrated device Please, contact your dealer! Error : Failed.e friend helps? |
04-19-2007, 19:33 | #5 (permalink) | |
Member: 306331 Status: Offline Thanks Meter: 0 | serial box Quote:
Box SN : Firmware Version : 1.08.0 Firmware Build Info : 2579 14 February 2007 13:18:10 Hardware version : 1.2 Done. --- Unlocking------------------------------------------------------------------ Error : You use not calibrated device Please, contact your dealer! Error : Failed. | |
04-23-2007, 18:09 | #7 (permalink) |
Freak Poster Join Date: Sep 2004 Location: brazil
Member: 80368 Status: Offline Thanks Meter: 32 | Error : You use not calibrated device dream box plus not worging...help me please -- Unlocking--------------------------------------------------------------- --- Error : You use not calibrated device Please, contact your dealer! Error : Failed. --- Unlocking------------------------------------------------------------------ Error : You use not calibrated device Please, contact your dealer! Error : Failed. --- Reading Info--------------------------------------------------------------- Error : You use not calibrated device Please, contact your dealer! Error : Failed. |
04-23-2007, 20:11 | #9 (permalink) |
Member: 80368 Status: Offline Thanks Meter: 32 | Error : You use not calibrated device //////////////////////////////////////////////////////////// Last edited by GSM_Support; 04-24-2007 at 08:18. Reason: Contained serial number |
04-24-2007, 15:04 | #11 (permalink) | |
Member: 306331 Status: Offline Thanks Meter: 0 | Resolved problem!!!! Quote:
good morning supports.. my supplier changed my box since last week. ok thank you | |
8120 unlocker error. this os does not match device? | The Repair Shop | BlackBerry (RIM) | 16 | 12-28-2010 08:53 |
HELP SUPPORT!!! ERROR : $NXP3G is not a valid integer value | phanthom2o4o | SPT BOX | 6 | 11-29-2009 12:29 |
pls help: Error : box is not calibrated | freddy black | DreamBox | 1 | 03-28-2008 13:30 |
Phoenix error : MCU do not fit into storage devices on APE side | Anno | Nokia Base Band 5 ( BB-5 ) | 0 | 01-17-2007 11:12 |
