12-20-2006, 22:46 | #1 (permalink) |
Freak Poster Join Date: Aug 2004 Age: 47
Member: 77446 Status: Offline Thanks Meter: 8 | Canīt flash SL75. Always stops at 33% I tried with new flashfile from support, the old one and file from another phone, but progress bar never goes beyond 33% (Address : 2000000 (84380 cps). I donīt thing this is hardware problem, cause phone was working normally before. Could dream team give me some advice?? BR |
12-21-2006, 14:38 | #3 (permalink) | |
Freak Poster Join Date: Mar 2006 Location: Brazil
Member: 245043 Status: Offline Thanks Meter: 8 | Quote:
best regards | |
12-21-2006, 14:50 | #4 (permalink) |
No Life Poster Join Date: Mar 2006 Location: dreambox
Member: 241271 Status: Offline Thanks Meter: 30 | We think that it is a hardware problem of this phone. But send ALL log files from DBSS with your forum's name and problem description to us (Program Files->DreamBox ALL .log files). Thanks. |
12-21-2006, 16:13 | #5 (permalink) | |
Member: 77446 Status: Offline Thanks Meter: 8 | Quote:
But from what you wrote I undestand you were able to flash it with an old DBSS version. Is this right?? BR | |
12-21-2006, 16:26 | #6 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Croatia Age: 49
Member: 234440 Status: Offline Thanks Meter: 20 | You can flash SL75 with this last version od DBSS. If you can not, this mean that you have hardware problem. I flash my SL75 with this last version of DBSS, and was OK. |
12-21-2006, 18:27 | #7 (permalink) |
Member: 245043 Status: Offline Thanks Meter: 8 | No...my phone dead after unlock with "format bootcore" implemented in version 2.2 of DBSS, i try to flash but stop in 33% or 49% with any file or sw version...isn't hardware problem! this version contain serious bugs with this boot mode and flash writing..... one more time, help Dreamsupporter ! |
12-21-2006, 18:53 | #9 (permalink) |
Member: 241271 Status: Offline Thanks Meter: 30 | To moaster Please, set "Disable strict model and firmware validation" in Options -> General. And try to use DBSS v2.3. But we think that it is hardware problem of this phone. |
12-22-2006, 12:56 | #10 (permalink) | |
I'm wait correction of this bugs with SL75.. one more time isn't hardware problem...I have two pieces thus Best Regards DreamSupporter | |
12-22-2006, 17:53 | #12 (permalink) | |
What Moaster is saying is true. I also tried to flash it with lowest speed and got same result. Progress stops at 33%. AND phone has NOT hardware problem. What happened to this phone is: A guy tried to unlock it with Martech and it became dead (Martech fvcks bootcore area). Then he tried to write eeprom area (also with martech), but that doesnīt solved the problem (of course, cause problem is in bootcore). He brought it to me, I solved bootcore problem using format bootcore function from Dreambox, but I still canīt make it alive cause it seems eeprom area was also damaged by him and DreamBox flash process for SL75 always stops at 33%. BR | |
12-23-2006, 13:31 | #13 (permalink) |
Member: 245043 Status: Offline Thanks Meter: 8 | look these log files DreamSupporter: Repairing------------------------------------------------------------------ [22/12/2006 22:07:36] User selected phone SL75 using Normal boot mode [22/12/2006 22:07:37] [22/12/2006 22:07:37] Power On the phone ... OK [22/12/2006 22:07:38] Testing RAM ...OK [22/12/2006 22:07:41] Flash Chip = AMD S29WS256N, size 32768 Kb [22/12/2006 22:07:41] Flash Chip = AMD S29GL512N, size 65536 Kb [22/12/2006 22:07:41] Flash IMEI = 359083-00-******-* [22/12/2006 22:07:41] Bootcore: SIEMENS SL75 [22/12/2006 22:07:41] Firmware: SIEMENS SL75 v16 lg1 [22/12/2006 22:07:41] Phone IMEI = 359083-00-******-* [22/12/2006 22:07:41] Warning : Flash IMEI is not equal to Phone IMEI! [22/12/2006 22:07:41] Warning : Phone software could not work properly! [22/12/2006 22:07:41] Warning : Please, fix Phone IMEI! [22/12/2006 22:07:41] SPLock CRC = FAILED [22/12/2006 22:07:41] Warning : setting default lock data [22/12/2006 22:07:41] Setting IMEI = 359083-00-******-* [22/12/2006 22:07:49] Address : 3FC0000 (141 cps) [22/12/2006 22:07:49] Done. [22/12/2006 22:07:49] [22/12/2006 22:08:56] --- Running scenario----------------------------------------------------------- [22/12/2006 22:08:56] User selected phone SL75 using Normal boot mode [22/12/2006 22:08:56] Repair IMEI (use user defined) [22/12/2006 22:08:56] [22/12/2006 22:08:57] [22/12/2006 22:08:57] Power On the phone ... OK [22/12/2006 22:08:57] Testing RAM ...OK [22/12/2006 22:09:00] Flash Chip = AMD S29WS256N, size 32768 Kb [22/12/2006 22:09:00] Flash Chip = AMD S29GL512N, size 65536 Kb [22/12/2006 22:09:00] Flash IMEI = 359083-00-******-* [22/12/2006 22:09:00] Bootcore: SIEMENS SL75 [22/12/2006 22:09:00] Firmware: SIEMENS SL75 v16 lg1 [22/12/2006 22:09:00] Warning : EELITE is corrupted [22/12/2006 22:09:00] Phone IMEI = invalid IMEI [22/12/2006 22:09:00] SPLock FAILED [22/12/2006 22:09:00] Warning : setting default lock data [22/12/2006 22:09:00] Setting IMEI = 359083-00-******-* [22/12/2006 22:09:02] Error : security data encoding failed [22/12/2006 22:09:02] Error : Failed. [22/12/2006 22:09:02] [22/12/2006 22:09:15] --- Repairing------------------------------------------------------------------ [22/12/2006 22:09:15] User selected phone SL75 using Normal boot mode [22/12/2006 22:09:16] [22/12/2006 22:09:16] Power On the phone ... OK [22/12/2006 22:09:17] Testing RAM ...OK [22/12/2006 22:09:19] Flash Chip = AMD S29WS256N, size 32768 Kb [22/12/2006 22:09:19] Flash Chip = AMD S29GL512N, size 65536 Kb [22/12/2006 22:09:19] Flash IMEI = 359083-00-******-* [22/12/2006 22:09:19] Bootcore: SIEMENS SL75 [22/12/2006 22:09:19] Firmware: SIEMENS SL75 v16 lg1 [22/12/2006 22:09:19] Warning : EELITE is corrupted [22/12/2006 22:09:19] Phone IMEI = invalid IMEI [22/12/2006 22:09:19] SPLock FAILED [22/12/2006 22:09:19] Warning : setting default lock data [22/12/2006 22:09:19] Setting IMEI = 359083-00-******-* [22/12/2006 22:09:21] Error : security data encoding failed [22/12/2006 22:09:21] Error : Failed. [22/12/2006 22:09:21] [22/12/2006 22:13:10] --- Loading Flash File--------------------------------------------------------- [22/12/2006 22:13:10] User selected phone SL75 using Normal boot mode [22/12/2006 22:14:15] Loading "D:\SL75_lg3_v10_fullflash.dtf"... [22/12/2006 22:14:17] Done. [22/12/2006 22:14:17] [22/12/2006 22:14:48] --- Writing Flash-------------------------------------------------------------- [22/12/2006 22:14:48] User selected phone SL75 using Normal boot mode [22/12/2006 22:14:49] [22/12/2006 22:14:49] Power On the phone ... OK [22/12/2006 22:14:50] Testing RAM ...OK [22/12/2006 22:14:53] Flash Chip = AMD S29WS256N, size 32768 Kb [22/12/2006 22:14:53] Flash Chip = AMD S29GL512N, size 65536 Kb [22/12/2006 22:14:53] Flash IMEI = 359083-00-******-* [22/12/2006 22:14:53] Bootcore: SIEMENS SL75 [22/12/2006 22:14:53] Firmware: SIEMENS SL75 v16 lg1 [22/12/2006 22:14:53] File name : D:\SL75_lg3_v10_fullflash.dtf [22/12/2006 22:14:53] Warning : EELITE is corrupted [22/12/2006 22:14:53] Phone IMEI = invalid IMEI [22/12/2006 22:14:53] SPLock FAILED [22/12/2006 22:14:53] Warning : setting default lock data [22/12/2006 22:14:53] Setting IMEI = 359083-00-******-* [22/12/2006 22:14:54] Error : security data encoding failed [22/12/2006 22:14:54] Error : Failed. [22/12/2006 22:14:54] [22/12/2006 22:15:08] --- Writing Flash-------------------------------------------------------------- [22/12/2006 22:15:08] User selected phone SL75 using Normal boot mode [22/12/2006 22:15:09] [22/12/2006 22:15:09] Power On the phone ... OK [22/12/2006 22:15:10] Testing RAM ...OK [22/12/2006 22:15:12] Flash Chip = AMD S29WS256N, size 32768 Kb [22/12/2006 22:15:12] Flash Chip = AMD S29GL512N, size 65536 Kb [22/12/2006 22:15:12] Flash IMEI = 359083-00-******-* [22/12/2006 22:15:12] Bootcore: SIEMENS SL75 [22/12/2006 22:15:13] Firmware: SIEMENS SL75 v16 lg1 [22/12/2006 22:15:13] File name : D:\SL75_lg3_v10_fullflash.dtf [22/12/2006 22:15:13] Warning : EELITE is corrupted [22/12/2006 22:15:13] Phone IMEI = invalid IMEI [22/12/2006 22:15:13] SPLock FAILED [22/12/2006 22:15:13] Warning : setting default lock data [22/12/2006 22:15:13] Setting IMEI = 359083-00-******-* [22/12/2006 22:15:14] Error : security data encoding failed [22/12/2006 22:15:14] Error : Failed. [22/12/2006 22:15:14] [22/12/2006 22:15:23] --- Running scenario----------------------------------------------------------- [22/12/2006 22:15:23] User selected phone SL75 using Normal boot mode [22/12/2006 22:15:23] Write Fullflash [22/12/2006 22:15:23] [22/12/2006 22:15:23] [22/12/2006 22:15:24] Power On the phone ... OK [22/12/2006 22:15:24] Testing RAM ...OK [22/12/2006 22:15:27] Flash Chip = AMD S29WS256N, size 32768 Kb [22/12/2006 22:15:27] Flash Chip = AMD S29GL512N, size 65536 Kb [22/12/2006 22:15:27] Flash IMEI = 359083-00-******-* [22/12/2006 22:15:27] Bootcore: SIEMENS SL75 [22/12/2006 22:15:27] Firmware: SIEMENS SL75 v16 lg1 [22/12/2006 22:30:41] Address : 2000000 (78570 cps) [22/12/2006 22:30:41] Warning : Aborted by user. [22/12/2006 22:30:41] [22/12/2006 22:30:44] --- Reading Info--------------------------------------------------------------- [22/12/2006 22:30:44] User selected phone SL75 using Normal boot mode [22/12/2006 22:30:45] [22/12/2006 22:30:52] Power On the phone ... OK [22/12/2006 22:30:52] Testing RAM ...OK [22/12/2006 22:31:00] Warning : Aborted by user. [22/12/2006 22:31:00] [22/12/2006 22:31:01] --- Reading Info--------------------------------------------------------------- [22/12/2006 22:31:01] User selected phone SL75 using Normal boot mode [22/12/2006 22:31:02] [22/12/2006 22:31:02] Power On the phone ... OK [22/12/2006 22:31:03] Testing RAM ...OK [22/12/2006 22:31:06] Flash Chip = AMD S29WS256N, size 32768 Kb [22/12/2006 22:31:06] Flash Chip = AMD S29GL512N, size 65536 Kb [22/12/2006 22:31:06] Flash IMEI = 359083-00-******-* [22/12/2006 22:31:06] Bootcore: SIEMENS SL75 [22/12/2006 22:31:06] Firmware: SIEMENS SL75 v10 lg3 [22/12/2006 22:31:06] Phone IMEI = invalid IMEI [22/12/2006 22:31:06] SPLock FAILED [22/12/2006 22:31:06] Warning : setting default lock data [22/12/2006 22:31:06] Done. [22/12/2006 22:31:06] [22/12/2006 22:51:59] --- Reading Info--------------------------------------------------------------- [22/12/2006 22:51:59] Error : Can not detect connection [22/12/2006 22:51:59] Error : Failed. [22/12/2006 22:51:59] [22/12/2006 22:52:11] --- Reading Info--------------------------------------------------------------- [22/12/2006 22:52:14] User selected phone SL75 using Normal boot mode [22/12/2006 22:52:15] [22/12/2006 22:52:15] Power On the phone ... OK [22/12/2006 22:52:16] Testing RAM ...OK [22/12/2006 22:52:18] Flash Chip = AMD S29WS256N, size 32768 Kb [22/12/2006 22:52:18] Flash Chip = AMD S29GL512N, size 65536 Kb [22/12/2006 22:52:18] Flash IMEI = 359083-00-******-* [22/12/2006 22:52:18] Warning : Bootcore is erased! [22/12/2006 22:52:18] Firmware: SIEMENS SL75 v10 lg3 [22/12/2006 22:52:18] Phone IMEI = invalid IMEI [22/12/2006 22:52:18] SPLock FAILED [22/12/2006 22:52:18] Warning : setting default lock data [22/12/2006 22:52:18] Done. [22/12/2006 22:52:18] [22/12/2006 22:52:44] --- Writing Flash-------------------------------------------------------------- [22/12/2006 22:52:44] User selected phone SL75 using Normal boot mode [22/12/2006 22:52:45] [22/12/2006 22:52:45] Power On the phone ... OK [22/12/2006 22:52:46] Testing RAM ...OK [22/12/2006 22:52:48] Flash Chip = AMD S29WS256N, size 32768 Kb [22/12/2006 22:52:48] Flash Chip = AMD S29GL512N, size 65536 Kb [22/12/2006 22:52:48] Flash IMEI = 359083-00-******-* [22/12/2006 22:52:48] Warning : Bootcore is erased! [22/12/2006 22:52:48] Firmware: SIEMENS SL75 v10 lg3 [22/12/2006 22:52:48] File name : D:\SL75_lg3_v10_fullflash.dtf [22/12/2006 22:52:56] Address : 2020000 (93741 cps) [22/12/2006 22:52:56] Warning : Aborted by user. [22/12/2006 22:52:56] [22/12/2006 22:53:05] --- Running scenario----------------------------------------------------------- [22/12/2006 22:53:05] User selected phone SL75 using Normal boot mode [22/12/2006 22:53:06] [22/12/2006 22:53:06] Zones to write: [22/12/2006 22:53:06] EEPROM [22/12/2006 22:53:06] [22/12/2006 22:53:06] [22/12/2006 22:53:10] Power On the phone ... OK [22/12/2006 22:53:11] Testing RAM ...OK [22/12/2006 22:53:13] Flash Chip = AMD S29WS256N, size 32768 Kb [22/12/2006 22:53:13] Flash Chip = AMD S29GL512N, size 65536 Kb [22/12/2006 22:53:13] Flash IMEI = 359083-00-******-* [22/12/2006 22:53:13] Bootcore: SIEMENS SL75 [22/12/2006 22:53:13] Firmware: SIEMENS SL75 v10 lg3 [22/12/2006 22:53:20] Address : 2040000 (492751 cps) [22/12/2006 22:53:20] Warning : Aborted by user. [22/12/2006 22:53:20] [22/12/2006 22:53:26] --- Repairing------------------------------------------------------------------ [22/12/2006 22:53:26] User selected phone SL75 using Normal boot mode [22/12/2006 22:53:27] [22/12/2006 22:53:31] Power On the phone ... OK [22/12/2006 22:53:32] Testing RAM ...OK [22/12/2006 22:53:35] Flash Chip = AMD S29WS256N, size 32768 Kb [22/12/2006 22:53:35] Flash Chip = AMD S29GL512N, size 65536 Kb [22/12/2006 22:53:35] Flash IMEI = 359083-00-******-* [22/12/2006 22:53:35] Bootcore: SIEMENS SL75 [22/12/2006 22:53:35] Firmware: SIEMENS SL75 v10 lg3 [22/12/2006 22:53:35] Warning : EELITE is corrupted [22/12/2006 22:53:35] Phone IMEI = invalid IMEI [22/12/2006 22:53:35] SPLock FAILED [22/12/2006 22:53:35] Warning : setting default lock data [22/12/2006 22:53:35] Setting IMEI = 359083-00-******-* [22/12/2006 22:53:36] Error : security data encoding failed [22/12/2006 22:53:36] Error : Failed. [22/12/2006 22:53:36] [23/12/2006 00:21:30] --------------------------------------------------------------------- I don't know what to do anymore .....and the worst, I'll have to pay for the customers......................................... ................................. heeeeeeellllllllpppp!!!!!!! |
12-24-2006, 16:42 | #14 (permalink) |
Member: 234440 Status: Offline Thanks Meter: 20 | Why you use Normal boot mode and not use Test Point? 1. Fullflash SL75 in Test Point mode 2. When finish flashing, make Repair IMEI (use factory IMEI from OTP area) / 2 times start this 3. Unlock all locks and then, if you do not have hardware problem, SL75 will turn ON. This full flash which is now on boot-loader is working. I test it. Regards |
K-300 FS flashing always stops at 38%!!! | MUNEEB_AKHTAR_RAZA | Cruiser Suite | 3 | 05-22-2006 18:36 |
w900 stops at 33% with semc V7.7!!!! | GSMLover2010 | SonyEricsson (USB-Smart) | 1 | 04-23-2006 01:02 |
try to flash dead v3,alway stop at 87%,please me | markLEE | Motorola P2k | 0 | 02-17-2006 13:48 |
MC60 - flashing always stops at 83% | realdodo | E-Gold Based Phones | 7 | 09-27-2004 20:02 |
BE4 130 01 - MCOMM stops at 33% | mobils | Alcatel & TCL Old Models | 0 | 10-14-2001 10:07 |
