Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2010 Location: iran - mazandaran- shahi Age: 30
Member: 1422911 Status: Offline Thanks: 156
| cx70 flash file request zimence cx70 after unlock dead plz help User selected phone CX70 using Normal boot mode Power On the phone ... OK Testing RAM ...OK Error : #31E0:002A0247 Flash Chip = AMD Am29BDS128H, size 16384 Kb Error : #31E0:002A0247 Flash Chip = AMD Am29BDS128H, size 16384 Kb Flash IMEI = 354926-00-404336-8 Phone ID = 46613781 Warning : Bootcore is erased! Firmware = SIEMENS CX70 v50 lg6 Phone IMEI = 354926-00-404336-8 SPLock CRC = OK Phone Code = < NOT SET > : FF Error : #31E0:00180C2B Error : #31E0:001C006C [CFI Flash Chip Information] JEDEC ID - FFFF ( 00FF-00FF ) amin khosravi: PRI Command Set - 0002 ( AMD / Fujitsu Standard ) PRI Ext. Offset - 0040 ALT Command Set - 0000 ( No Interface Specified ) ALT Ext. Offset - 0000 Minimum Vcc - 1.7 V Maximum Vcc - 1.9 V Minimum Vpp - chip has no Vpp pin Maximum Vpp - chip has no Vpp pin Typical Byte / Word Write Timeout - 16 mcs Typical Full Buffer Write Timeout - not supported Typical Block Erase Timeout - 512 ms Typical Chip Erase Timeout - not supported Maximum Byte / Word Write Timeout - 256 mcs Maximum Full Buffer Write Timeout - not supported Maximum Block Erase Timeout - 8192 ms Maximum Chip Erase Timeout - not supported Device Size - 1000000 (HEX) byte(s) Bus Interface - 0001 ( x16-only async. ) Maximum Multi-byte Write - 01 (HEX) byte(s) Number of Er amin khosravi: 2) 00FE blocks of 010000 bytes 3) 0008 blocks of 002000 bytes [CFI Flash Chip Information] JEDEC ID - FFFF ( 00FF-00FF ) PRI Command Set - 0002 ( AMD / Fujitsu Standard ) PRI Ext. Offset - 0040 ALT Command Set - 0000 ( No Interface Specified ) ALT Ext. Offset - 0000 Minimum Vcc - 1.7 V Maximum Vcc - 1.9 V Minimum Vpp - chip has no Vpp pin Maximum Vpp - chip has no Vpp pin Typical Byte / Word Write Timeout - 16 mcs Typical Full Buffer Write Timeout - not supported Typical Block Erase Timeout - 512 ms Typical Chip Erase Timeout - not supported Maximum Byte / Word Write Timeout - 256 mcs Maximum Full Buffer Write Timeout - not supported Maximum Block Erase Timeout - 8192 ms amin khosravi: Maximum Chip Erase Timeout - not supported Device Size - 1000000 (HEX) byte(s) Bus Interface - 0001 ( x16-only async. ) Maximum Multi-byte Write - 01 (HEX) byte(s) Number of Erase Regions - 03 1) 0008 blocks of 002000 bytes 2) 00FE blocks of 010000 bytes 3) 0008 blocks of 002000 bytes Done. support im wait please shre me flash file |
| The Following 4 Users Say Thank You to garibaldini For This Useful Post: |
| | #2 (permalink) |
| dream doesnt have any supporter???????????? |
| The Following User Says Thank You to garibaldini For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| FLASH BOX WANTED!!!!!! | J | Wanted Products | 9 | 07-14-2012 20:42 |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
| how can we use *.scr files to unlock | shadow77 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 1 | 10-27-1999 03:13 |
| need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 08-16-1999 12:20 |
| 5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 07-07-1999 12:27 |
