06-01-2008, 15:40 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: INDONESIA Age: 38
Member: 183921 Status: Offline Sonork: 100.1590817 Thanks Meter: 205 | To Dreambox did u need this dump?? there is something weird with the cid, is dump file will be usefull to db team for support otp49 phone?? here is the log.. Code: --- Reading Info--------------------------------------------------------------- User selected phone K310 using Normal boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 80400301FFFFFFFF (DB2012) EROM Color = 4 : RED EROM CID = 52 NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 353315-01-021650-0 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 GDFS Simlocks : Lock 0 = OFF (00) [5/5] (Network) Lock 1 = OFF (00) [5/5] (Network Subset) Lock 2 = OFF (00) [5/5] (Service Provider) Lock 3 = OFF (00) [5/5] (Corporate) Lock 4 = OFF (00) [5/5] (SIM Card) Lock 5 = OFF (00) [5/5] (Extended) Operator code = 000-00 Done. --- Read Full Flash------------------------------------------------------------ User selected phone K310 using Test Point boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 80400301FFFFFFFF (DB2012) EROM Color = 4 : RED EROM CID = 52 NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 353315-01-021650-0 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Flash Chip : Intel 48F50xxM0Y0 Flash Chip ID : 887E0089 Saving "C:\Documents and Settings\kevin\Desktop\New Folder\K310_otp49_cid52_full.bin"... Done. --- Read GDFS------------------------------------------------------------------ User selected phone K310 using Test Point boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 80400301FFFFFFFF (DB2012) EROM Color = 4 : RED EROM CID = 52 NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 353315-01-021650-0 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Flash Chip : Intel 48F50xxM0Y0 Flash Chip ID : 887E0089 Reading GDFS... Saving "C:\Documents and Settings\kevin\Desktop\New Folder\K310_gdfs_otp49_cid52.dmap"... Done. the log.. Code: --- Security Bypass------------------------------------------------------------ User selected phone K310 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 80400301FFFFFFFF (DB2012) EROM Color = 4 : RED EROM CID = 52 NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 353315-01-021650-0 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Stage 1 completed succesfully Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K310 using Test Point boot mode Stage 2 start Hint : Now the probe might be disconnected Error : Stage 2 is not supported for this phone Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K310 using Test Point boot mode Stage 2 start Hint : Now the probe might be disconnected Processing... Entering Security Bypass mode ... 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 80400301FFFFFFFF (DB2012) EROM Color = 4 : RED EROM CID = 50 Baseband Chip ID = 8040 Phone ID = 2180236415204905 Finalizing ... Stage 2 completed succesfully Done. --- Reading Info--------------------------------------------------------------- User selected phone K310 using Test Point boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 80400301FFFFFFFF (DB2012) EROM Color = 4 : RED EROM CID = 50 NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 353315-01-021650-0 OTP CID = 49 EROM Color = 4 : RED EROM CID = 50 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 80400301FFFFFFFF (DB2012) EROM Color = 4 : RED EROM CID = 50 Warning : Aborted by user. --- Reading Info--------------------------------------------------------------- User selected phone K310 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 80400301FFFFFFFF (DB2012) EROM Color = 4 : RED EROM CID = 50 Baseband Chip ID = 8040 Phone ID = 2180236415204905 Flash Chip : Intel 48F50xxM0Y0 Flash Chip ID : 887E0089 Reading GDFS... Testing security ... GDFS 0013 Hash Failed GDFS 0006 Hash Failed GDFS 000E Hash Failed Error : Failed. --- Unlock and Repair---------------------------------------------------------- User selected phone K310 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 80400301FFFFFFFF (DB2012) EROM Color = 4 : RED EROM CID = 50 Baseband Chip ID = 8040 Phone ID = 2180236415204905 Reading GDFS... Testing security ... GDFS 0013 Hash Failed GDFS 0006 Hash Failed GDFS 000E Hash Failed Error : Failed. br, kevin168 |
06-02-2008, 09:04 | #3 (permalink) |
Member: 183921 Status: Offline Sonork: 100.1590817 Thanks Meter: 205 | i don't know how to make it, i need another cid49 phones to make a test again.. badly i don't have it yet at this time.. br, kevin168 |
06-03-2008, 16:47 | #4 (permalink) |
Member: 183921 Status: Offline Sonork: 100.1590817 Thanks Meter: 205 | i already try another DB2010 cid49 phone, try to upgrade CID but doesn't work, i don't have any idea bout this phone, how it can be? are Dream Team can give any information? br, kevin168 |
06-03-2008, 20:52 | #6 (permalink) |
Member: 183921 Status: Offline Sonork: 100.1590817 Thanks Meter: 205 | sorry but i don't ask bout DB2010 support, please read again my log.. Code: User selected phone K310 using Normal boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 80400301FFFFFFFF (DB2012) EROM Color = 4 : RED EROM CID = 52 NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 353315-01-021650-0 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 with OTP CID 49 like u said that was DB2010 but with EROM / FLASH CID 52 and u said that was DB2012 so what type is this phone DB2010 or DB2012 let see i have already make unlock operation on this phone, Code: DBSS Start 3.5 [01/06/2008 21:46:57] --- Reading Info--------------------------------------------------------------- [01/06/2008 21:47:00] User selected phone K310 using Security Bypass boot mode [01/06/2008 21:47:00] 1) Turn OFF the phone. [01/06/2008 21:47:00] 2) Connect the phone to DreamBox cable. [01/06/2008 21:47:00] Boot Responce = 5A [01/06/2008 21:47:00] Processor ID = 80400301FFFFFFFF (DB2012) [01/06/2008 21:47:00] EROM Color = 4 : RED [01/06/2008 21:47:00] EROM CID = 50 [01/06/2008 21:47:02] Baseband Chip ID = 8040 [01/06/2008 21:47:02] Phone ID = 2180236415204905 [01/06/2008 21:47:02] Flash Chip : Intel 48F50xxM0Y0 [01/06/2008 21:47:02] Flash Chip ID : 887E0089 [01/06/2008 21:47:02] Reading GDFS... [01/06/2008 21:47:05] Testing security ... [01/06/2008 21:47:05] GDFS 0013 Hash Failed [01/06/2008 21:47:05] GDFS 0006 Hash Failed [01/06/2008 21:47:05] GDFS 000E Hash Failed [01/06/2008 21:47:05] Error : Failed. [01/06/2008 21:47:05] [01/06/2008 21:47:10] --- Loading GDFS file---------------------------------------------------------- [01/06/2008 21:47:25] Loading "E:\Dream_box\Dream_box_SE\Firmware_DUMP\K310i\With_TP_Method\K310i_Cid50_GDFS.dmap"... [01/06/2008 21:47:26] Done. [01/06/2008 21:47:26] [01/06/2008 21:47:28] --- Write GDFS----------------------------------------------------------------- [01/06/2008 21:47:28] User selected phone K310 using Security Bypass boot mode [01/06/2008 21:47:29] 1) Turn OFF the phone. [01/06/2008 21:47:29] 2) Connect the phone to DreamBox cable. [01/06/2008 21:47:29] Boot Responce = 5A [01/06/2008 21:47:29] Processor ID = 80400301FFFFFFFF (DB2012) [01/06/2008 21:47:29] EROM Color = 4 : RED [01/06/2008 21:47:29] EROM CID = 50 [01/06/2008 21:47:31] Baseband Chip ID = 8040 [01/06/2008 21:47:31] Phone ID = 2180236415204905 [01/06/2008 21:47:31] Flash Chip : Intel 48F50xxM0Y0 [01/06/2008 21:47:31] Flash Chip ID : 887E0089 [01/06/2008 21:47:31] Generating GDFS... [01/06/2008 21:47:31] Writing GDFS... [01/06/2008 21:47:40] Done. [01/06/2008 21:47:40] [01/06/2008 21:47:43] --- Unlock and Repair---------------------------------------------------------- [01/06/2008 21:47:43] User selected phone K310 using Security Bypass boot mode [01/06/2008 21:47:44] 1) Turn OFF the phone. [01/06/2008 21:47:44] 2) Connect the phone to DreamBox cable. [01/06/2008 21:47:44] Boot Responce = 5A [01/06/2008 21:47:44] Processor ID = 80400301FFFFFFFF (DB2012) [01/06/2008 21:47:44] EROM Color = 4 : RED [01/06/2008 21:47:44] EROM CID = 50 [01/06/2008 21:47:46] Baseband Chip ID = 8040 [01/06/2008 21:47:46] Phone ID = 2180236415204905 [01/06/2008 21:47:46] Reading GDFS... [01/06/2008 21:47:48] Testing security ... [01/06/2008 21:47:48] GDFS 0013 Hash Failed [01/06/2008 21:47:48] GDFS 0006 Hash Failed [01/06/2008 21:47:48] GDFS 000E Hash Failed [01/06/2008 21:47:48] GDFS 001C Hash Failed [01/06/2008 21:47:48] Unlocking ... [01/06/2008 21:47:48] Testing security ... [01/06/2008 21:47:48] GDFS 0013 Hash OK [01/06/2008 21:47:48] GDFS 0006 Hash OK [01/06/2008 21:47:48] GDFS 000E Hash OK [01/06/2008 21:47:48] GDFS 001C Hash OK [01/06/2008 21:47:48] Generating GDFS... [01/06/2008 21:47:48] Writing GDFS... [01/06/2008 21:47:57] Done. i don't see any HW difference in DB2010 and DB2012 phones. i just want to say, becoz i see that phone with OTP49 has erom cid 52 this mean erom upgrade from 49 > 50 or 52 is possible. i want to ask how to upgrade it's CID?? if we can upgrade CID on DB2010 phone we can make repair in all CID49 phones. br, kevin168 |
need code for this dump | tsm1 | CAR Electronics | 25 | 03-10-2014 21:22 |
need edit vin on this dump | nacer_elec | CAR Electronics | 5 | 01-06-2011 19:48 |
need this flash file. | naeem janjua | Infinity-Box | 2 | 03-30-2010 15:13 |
did anyone have this problem | nepoleanl | UST Pro II | 2 | 03-30-2010 10:11 |
