06-03-2008, 00:26 | #2 (permalink) |
Banned Join Date: May 2006 Location: United Kingdom
Member: 270521 Status: Offline Sonork: 100.15962233 Thanks Meter: 369 | its not difficult to remove the glue u can use hot air to remove or any paint remover lequid as far as i myself is concerned i dont remove glue just count the pins and press the needle a bit hard and it will be connected to the tp and ur phone will be unlocked give it a try BR Sherry |
06-03-2008, 00:46 | #3 (permalink) | |
Product Manager Join Date: Apr 2007
Member: 488825 Status: Offline Thanks Meter: 365 | Quote:
yeap!!! you are right bro, i do not remove glue on w200 just push a bit hard and get contact, until now more than 50 unlocked and without remove any glue on them. | |
06-03-2008, 03:26 | #5 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Pinas Age: 45
Member: 91411 Status: Offline Sonork: 100.1584444 Thanks Meter: 372 | actually in all tp's of dreambox the w200i tp is so far the easiest.no need to remove glue.just push the tp needle and it will pass thru the emicon.then you can unlock..... |
01-14-2009, 05:21 | #9 (permalink) |
Insane Poster Join Date: Apr 2005 Location: Pilipinas ! Age: 43
Member: 137181 Status: Offline Thanks Meter: 3 | w200 TP is very easy.... if the glue is very thick you have to lightly scratch it or a sharp pointed needle will do the trick...make sure you count the pins. regards swensonb DBSS USER |
New Easy Test Points For Nokia N80 E65 E61 N73 by Sagmaster TEAM | Aamir_Zia | BB5BOX | 136 | 04-25-2008 09:33 |
i need easy test point for n80..? | shumrtong | BB5BOX | 11 | 12-25-2007 17:29 |
i need easy test point for n80..? | communication_expert | MT-BOX | 4 | 12-17-2007 08:26 |
UID BOX+Free dejan software= Easy Test point for free!!! | sheryngan | Nokia Base Band 5 ( BB-5 ) | 35 | 09-11-2007 21:24 |
