09-14-2008, 21:16 | #2 (permalink) |
Insane Poster Join Date: Feb 2008
Member: 696888 Status: Offline Thanks Meter: 5 | i think you should be use setool for this .... it,s maybe best for this ...... http://download.fars-gsm.com/Booali/...lash_video.rar download this video and folow this video it,s maybe help you.......this video is for db2020 platform... good luck |
09-14-2008, 21:30 | #3 (permalink) | |
Member: 696888 Status: Offline Thanks Meter: 5 | Quote:
good luck | |
The Following User Says Thank You to MOSHIRGSM For This Useful Post: |
09-15-2008, 11:09 | #4 (permalink) |
Major Poster Join Date: Apr 2008
Member: 747678 Status: Offline Thanks Meter: 16 | Hey people !-) Forget about long howto. EMPTY FILL with Dreambox is the sipmlest you have ever seen. You have phone with EMPTY flash 1. Do "Security Bypass" in testpoint boot mode. 2. Do "Unlock And Repair GDFS Security Blocks" with "Write and lock OTP IMEI" checked in security bypass boot mode. Do not forget to enter CORRECT IMEI !!! 3. Write Firmware And that's all ;-) logs I will post later, when get to my working place. |
The Following 4 Users Say Thank You to BumbaRumba For This Useful Post: |
09-15-2008, 13:04 | #5 (permalink) |
Member: 747678 Status: Offline Thanks Meter: 16 | Success Log This is my EMPTY FILL success log Code: --- Security Bypass------------------------------------------------------------ User selected phone W850 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = Open OTP IMEI = 048575-55-048575-4 OTP CID = <unknown> EROM Color = FFFFFFFF : UNKNOWN EROM CID = -1 Warning : Connected phone is not W850 Please select correct phone model Warning : Unrecognized phone model Warning : Empty board detected ... Warning : Connected phone is not W850 Please select correct phone model Warning : Unrecognized phone model Hint : Now the probe might be disconnected Processing ... | Stage 1 completed succesfully Stage 2 start ADC (26) 0 Hint : Now the probe might be disconnected Processing... Entering Security Bypass mode ... - Time 6734 ms (38928 cps) 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = Open OTP IMEI = 048575-55-048575-4 OTP CID = <unknown> EROM Color = 4 : RED EROM CID = 53 Warning : Connected phone is not W850 Please select correct phone model Warning : Unrecognized phone model Baseband Chip ID = 9900 Phone ID = FFFFFFFFFFFFFFFF Stage 2 completed succesfully Done. --- Unlock and Repair---------------------------------------------------------- User selected phone W850 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = Open OTP IMEI = 048575-55-048575-4 OTP CID = <unknown> EROM Color = 4 : RED EROM CID = 53 Warning : Connected phone is not W850 Please select correct phone model Warning : Unrecognized phone model Locking OTP ... IMEI 35XXXXXXXXXXXXX CID 49 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 35XXXXXXXXXXXXX OTP CID = <unknown> EROM Color = 4 : RED EROM CID = 53 Baseband Chip ID = 9900 Phone ID = FFFFFFFFFFFFFFFF Reading GDFS... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Unlocking ... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Generating GDFS... Writing GDFS... Done. Last edited by BumbaRumba; 09-15-2008 at 13:10. Reason: Cutting IMEI :-) |
The Following 2 Users Say Thank You to BumbaRumba For This Useful Post: |
how to do?need empty fill?help me | wew | SETool2 | 1 | 07-26-2008 04:12 |
How empty fill w580 | GARY2006A | Sony Ericsson | 0 | 07-03-2008 17:47 |
How to do EMPTY FILL PROCEDURE on k790i??? | Unlocker_001 | SETool2 | 0 | 06-18-2008 18:31 |
how to use empty fill? | jonar23 | Sony Ericsson | 1 | 12-23-2007 14:55 |
How to empty fill db2020???? | master76 | Sony Ericsson | 2 | 03-11-2007 15:41 |
