12-22-2006, 10:50 | #2 (permalink) |
No Life Poster Join Date: Mar 2006 Location: dreambox
Member: 241271 Status: Offline Thanks Meter: 30 | Hi, HEDEF_GSM. You can change IMEI in EEPROM to different than stored in OTP. But a phone will not able to be ON. If IMEI in EEPROM is the same as in OTP, than the phone will be able to be ON. Or if OTP zone is not writed in the flash before, than you can write any IMEI and your phone will be able to be ON. Repair IMEI Use of this option enables to restore damaged phone IMEI 1. Connect DreamBox to PC and run DBSS. The light indicator glows green, which means that DreamBox device is ready to work. 2. Connect the phone to the front side of DreamBox. The phone must be switched off, and the battery should be charged at least for 40% of its overall power. 3. Choose the required phone model from the scrolling list and select a correct access mode. (See “Access modes” description). 4. Select Security tab. 5. To update or restore IMEI (International Mobile Equipment Identifier), mark the Use factory IMEI from flash OTP Area checkbox. 6. To restore IMEI manually, enter original 14 digits IMEI number. 7. Click Repair IMEI button. If checkbox Do not update/repair security area is checked, all network locks will remain saved. Otherwise all locks will be unlocked. |
How to rebuild imei ks360 with z3x-box | luyanda | Z3X-Team Products | 4 | 10-18-2009 16:54 |
i cant connect with infinity box....pls help me........ | jahfartv | Infinity-Box | 4 | 07-08-2009 19:51 |
How to unlock Vodafone V527 with MICRO-BOX?ple help me! | NO.7 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 4 | 06-28-2009 04:10 |
how to unlock n 73 with ufs+hwk please help me hwk team | mahesh_patel361 | HWK | 4 | 12-27-2007 18:04 |
