07-03-2008, 12:16 | #1 (permalink) |
No Life Poster Join Date: Jan 2004
Member: 51125 Status: Offline Thanks Meter: 1,435 | Reading GDFS Testing security Error : Failed. - Unlock and Repair---------------------------------------------------------- User selected phone K550 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 354893-01-428313-9 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 23804D6A15909168 Reading GDFS... Testing security ... Error : Failed. |
07-03-2008, 12:51 | #3 (permalink) |
Member: 51125 Status: Offline Thanks Meter: 1,435 | Looks this phone hardware issue sir wat this problem sir --- Security Bypass------------------------------------------------------------ User selected phone K550 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 354893-01-428313-9 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Stage 1 completed succesfully Stage 2 start Hint : Now the probe might be disconnected Processing... Entering Security Bypass mode ... 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 354893-01-428313-9 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 23804D6A15909168 Finalizing ... Stage 2 completed succesfully Done. --- Unlock and Repair---------------------------------------------------------- User selected phone K550 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 354893-01-428313-9 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 23804D6A15909168 Reading GDFS... Error : CRC failed Error : Failed. |
07-03-2008, 13:10 | #4 (permalink) |
Member: 51125 Status: Offline Thanks Meter: 1,435 | Unlock and Repair---------------------------------------------------------- User selected phone K550 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 354893-01-428313-9 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 23804D6A15909168 Reading GDFS... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Unlocking ... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Generating GDFS... Writing GDFS... Done. BUT MY PROBLEM NOT SHOL red light blinking only plzzzzz help me sir plzzzzzzzzzzz |
07-03-2008, 13:23 | #5 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 214480 Status: Offline Thanks Meter: 2,087 | Hello! 1. Download this fullflash file K550 2. Choose model K550 in DBSS 3. Select Access Mode - Test Point 4. Go to Security tab & Execute " Security Bypass" Operation 5. Select Access Mode - Security Bypass 6. Go to Misc tab & Write Full Flash (look in p.#1) 7. After flashing go to Security tab & make "Unlock & Repair GDFS Sec. Blc." 8. Go to Flash tab & flash: Main+FS+Custpac. If that not help to You so it is HW problem - LCD, FlexCable, Flash IC, water damage etc. ... |
Updating Box Firmware Error : Failed. | .::allgsmkey::. | DreamBox | 7 | 09-02-2009 09:25 |
SL45 Error : RAM Test Failed @060000 | chikubie | DreamBox | 1 | 06-09-2008 13:41 |
CX65 Testing RAM .Error : Failed. | aukonline | DreamBox | 2 | 07-02-2007 12:01 |
C62 - Recovering Gdfs Failed, Code Error : 68 | *Diablo* | NON Siemens Brand (ODM Phones) | 0 | 09-13-2004 07:13 |
