how to repair k800 gdfs damaged hi please im new user for dream box SE give me method how can repair k800i GDFS damaged thank in advance |
mate, l m new member for dream box also,l m also take long time to understand how to use the box.it only very hard to make test point ,n got 2 test point much want to make ,after successful to make test point n only can repair the gdfs n unlock.( much use microscope to see the test point )hope u will understand my english. |
1. use test point mode to enable Security Bypass 2. connect phone with Security Bypass Mode 3. flash another GDFS from a good K800 to the one you wanna flash 4. repaid and unlock your phone |
u can use easy test point |
-- Write GDFS----------------------------------------------------------------- User selected phone K800 using Test Point boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 357315-01-165967-0 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Error : Failed. help me |
man plz upload these easy tp's thanks |
Hello! 1. Download fullflash file K800 2. Choose model K800 in DBSS 3. Select Access Mode - Test Point 4. Go to Security tab & Execute " Security Bypass" Operation 5. Select Access Mode - Security Bypass 6. Go to Misc tab & Write Full Flash (look in p.#1) 7. After flashing go to Security tab & make "Unlock & Repair GDFS Sec. Blc." 8. Go to Flash tab & flash: Main+FS+Custpac. If that not help to You so it is HW problem - LCD, FlexCable, Flash IC, water damage etc. ... |
how can repair gdfs damaged with SETOOL ? ? |
plz help me how to repair gdfs with setoo ? |
brother this section is not for setool box is to dreambox and sorry |
give me any one k800 easy tp for repair gdfs |
