Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > DreamBox
Old 06-27-2008, 18:27   #1 (permalink)
Member: 447609
Thanks Meter: 3
how to repair k800 gdfs damaged
hi
please im new user for dream box SE
give me method how can repair k800i GDFS damaged
thank in advance
The Following User Says Thank You to alssalafiy For This Useful Post:
Old 06-27-2008, 20:32   #2 (permalink)
5mobile's Avatar
Member: 70278
Thanks Meter: 19
mate, l m new member for dream box also,l m also take long time to understand how to use the box.it only very hard to make test point ,n got 2 test point much want to make ,after successful to make test point n only can repair the gdfs n unlock.( much use microscope to see the test point )hope u will understand my english.
The Following User Says Thank You to 5mobile For This Useful Post:
Old 06-29-2008, 21:30   #3 (permalink)
gwaai's Avatar
Member: 49581
Thanks Meter: 73
Originally Posted by alssalafiy View Post
hi
thank in advance
1. use test point mode to enable Security Bypass
2. connect phone with Security Bypass Mode
3. flash another GDFS from a good K800 to the one you wanna flash
4. repaid and unlock your phone
Old 06-29-2008, 22:02   #4 (permalink)
Member: 210280
Thanks Meter: 6
u can use easy test point
Old 07-01-2008, 09:06   #5 (permalink)
a.w.m.wafaz's Avatar
Member: 763865
Sonork: Cvlvertcharges
Thanks Meter: 121
-- Write GDFS-----------------------------------------------------------------
User selected phone K800 using Test Point boot mode
1) Turn OFF the phone.
2) Connect the phone to DreamBox cable.
Boot Responce = 5A
Processor ID = 99000301FFFFFFFF (DB2020 / DB2030)
NOR Flash ID = 897E
OTP Status = LOCKED
OTP IMEI = 357315-01-165967-0
OTP CID = 51
EROM Color = 4 : RED
EROM CID = 52
Hint : Now the probe might be disconnected
Processing ...
Error : Failed.
help me
Old 07-01-2008, 09:38   #6 (permalink)
llcoolr's Avatar
Member: 53408
Sonork: 100.1593951
Thanks Meter: 1,008
man plz upload these easy tp's
thanks
Old 07-01-2008, 13:30   #7 (permalink)
GSM Dream's Avatar
Member: 214480
Thanks Meter: 2,087
Hello!
1. Download fullflash file K800
2. Choose model K800 in DBSS
3. Select Access Mode - Test Point
4. Go to Security tab & Execute " Security Bypass" Operation
5. Select Access Mode - Security Bypass
6. Go to Misc tab & Write Full Flash (look in p.#1)
7. After flashing go to Security tab & make "Unlock & Repair GDFS Sec. Blc."
8. Go to Flash tab & flash: Main+FS+Custpac.
If that not help to You so it is HW problem - LCD, FlexCable, Flash IC, water damage etc. ...
The Following 3 Users Say Thank You to GSM Dream For This Useful Post:
Old 07-02-2008, 07:24   #8 (permalink)
Member: 748559
Thanks Meter: 9
how can repair gdfs damaged with SETOOL ? ?
The Following User Says Thank You to adilmalik For This Useful Post:
Old 07-02-2008, 07:25   #9 (permalink)
Member: 748559
Thanks Meter: 9
plz help me how to repair gdfs with setoo ?
Old 07-03-2008, 15:07   #10 (permalink)
Member: 447609
Thanks Meter: 3
hi
brother this section is not for setool box is to dreambox
and sorry
Old 05-25-2009, 03:55   #11 (permalink)
Member: 655012
Thanks Meter: 26
give me any one k800 easy tp for repair gdfs
Old 05-25-2009, 04:01   #12 (permalink)
djlicks's Avatar
Member: 158242
Sonork: 100.1591384
Thanks Meter: 189
only easy tp for stage 1
how to recover k800 gdfs aliajk SETool2 6 09-27-2009 08:21
How to solve w200 gdfs damaged unlock trigger Universalbox 1 11-30-2008 21:16
how to repair k800 eerom?? caddisfly Universalbox 2 11-02-2006 15:39
Page generated in 0.35634 seconds with 8 queries
