05-08-2008, 08:45 | #1 (permalink) |
Banned Join Date: Jul 2005 Location: Philippines Age: 53
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | Invalid GDFS structure and/or configuration User selected phone K320 using Test Point boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 50 NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 353322-01-150204-5 OTP CID = 50 EROM Color = 4 : RED EROM CID = 50 Hint : Now the probe might be disconnected Processing ... Flash Chip : Intel 48F50xxM0Y0 Flash Chip ID : 887E0089 Generating GDFS... Writing GDFS... Done. --- Security Bypass------------------------------------------------------------ User selected phone K320 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 50 NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 353322-01-150204-5 OTP CID = 50 EROM Color = 4 : RED EROM CID = 50 Hint : Now the probe might be disconnected Processing ... Error : Invalid GDFS structure and/or configuration. Hint : Try to flash firmware. Error : Failed. |
05-08-2008, 11:41 | #3 (permalink) | |
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | Quote:
after put gdfs post later.............. | |
05-08-2008, 11:56 | #4 (permalink) |
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | look after put good gdfs logs: OTP LOCKED:1 CID:50 PAF:1 IMEI:35332201150204 CERT:RED FLASH CID:50 COLOR:RED IMEI MISMATCH ! GDFS IMEI:35165002207136 Model:K320i Brand:Sony Ericsson MAPP CXC article: R4GC012 prgCXC1250683_CHINA_MA MAPP CXC version: R4GC012 Language Package:APAC CDA article: CDA102727/101 CDA version: R2A Default article: Default version: PROVIDER: 515-05 Network LOCKED |
05-08-2008, 11:56 | #5 (permalink) |
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | -- Reading Info--------------------------------------------------------------- User selected phone K320 using Normal boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 50 NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 353322-01-150204-5 OTP CID = 50 EROM Color = 4 : RED EROM CID = 50 GDFS Simlocks : Lock 0 = LOCKED (01) [5/5] (Network) Lock 1 = OFF (00) [5/5] (Network Subset) Lock 2 = OFF (00) [5/5] (Service Provider) Lock 3 = OFF (00) [5/5] (Corporate) Lock 4 = OFF (00) [5/5] (SIM Card) Lock 5 = OFF (00) [5/5] (Extended) Operator code = 515-05 Done. |
05-08-2008, 12:20 | #6 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 214480 Status: Offline Thanks Meter: 2,087 | Our solution depends on the configuration GDFS. If DB2012 phone has "Invalid GDFS and/or configuration" and firmware flashing or GDFS reorganizing didn't help - nothing can be done. We know about this problem and working on it. |
05-09-2008, 04:03 | #8 (permalink) |
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | Bengo Thanks For Update: Solved Reading Info--------------------------------------------------------------- User selected phone K320 using Normal boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 50 NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 353322-01-150204-5 OTP CID = 50 EROM Color = 4 : RED EROM CID = 50 GDFS Simlocks : Lock 0 = LOCKED (01) [5/5] (Network) Lock 1 = OFF (00) [5/5] (Network Subset) Lock 2 = OFF (00) [5/5] (Service Provider) Lock 3 = OFF (00) [5/5] (Corporate) Lock 4 = OFF (00) [5/5] (SIM Card) Lock 5 = OFF (00) [5/5] (Extended) Operator code = 515-05 Done. --- Security Bypass------------------------------------------------------------ User selected phone K320 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 50 NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 353322-01-150204-5 OTP CID = 50 EROM Color = 4 : RED EROM CID = 50 Hint : Now the probe might be disconnected Processing ... Stage 1 completed succesfully Stage 2 start Hint : Now the probe might be disconnected Processing... Entering Security Bypass mode ... 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 50 Baseband Chip ID = 8040 Phone ID = 22802A6415C0AB24 Finalizing ... Stage 2 completed succesfully Done. --- Unlock and Repair---------------------------------------------------------- User selected phone K320 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 50 Baseband Chip ID = 8040 Phone ID = 22802A6415C0AB24 Reading GDFS... Testing security ... GDFS 0013 Hash Failed GDFS 0006 Hash Failed GDFS 000E Hash Failed GDFS 001C Hash Failed Unlocking ... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Generating GDFS... Writing GDFS... Done. |
05-09-2008, 05:01 | #10 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: tamilnadu, india.
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | Quote:
how solved the problem sir... for me it shows like this only.... --- Security Bypass------------------------------------------------------------ User selected phone W200 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 52 NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 355441-01-116076-6 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... / Error : Invalid GDFS structure and/or configuration. Hint : Try to flash firmware. Error : Failed. please help me too....thanks sir.. | |
05-09-2008, 06:10 | #13 (permalink) |
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | sorry bro... updated to the 3.5 then also remains same... -- Security Bypass------------------------------------------------------------ User selected phone W200 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 52 NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 355441-01-116076-6 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... / Error : Invalid GDFS structure and/or configuration. Hint : Try to flash firmware. Error : Failed anymore idea thanks.. |
05-09-2008, 09:06 | #15 (permalink) |
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | thanks sir... i will try and post result... can you please guide here...http:///vbb/...d.php?t=535728 thanks a lot sir |
W810: Invalid GDFS structure and/or configuration. | samih127 | DreamBox | 5 | 03-11-2009 06:48 |
Invalid GDFS structure and/or configuration. | saajith | DreamBox | 2 | 07-02-2008 14:31 |
Error : Invalid GDFS structure and/or configuration. | MPK | DreamBox | 6 | 05-08-2008 13:20 |
dead w200 Error : Invalid GDFS structure and/or configuration. | Paul Guaņuna | DreamBox | 4 | 04-08-2008 09:55 |
Invalid GDFS structure and/or configuration | vhgsm | DreamBox | 7 | 03-31-2008 16:19 |
