07-13-2008, 09:55 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 44
Member: 52956 Status: Offline Thanks Meter: 49 | ~~>>Again And Again Bug(ERROR 09) ????????????? I have s500 2 weeks ago that tamperd with dbss and now I have another that tamperd with dbss at first S500 in red blink statue HERE MY LOG: Code: --- Security Bypass------------------------------------------------------------ User selected phone S500 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 359885-01-852816-7 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Stage 1 completed succesfully Stage 2 start Hint : Now the probe might be disconnected Processing... Entering Security Bypass mode ... - Status 09 Error : Failed. HERE MY LOG : Code: -- Security Bypass------------------------------------------------------------ User selected phone S500 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 359885-01-852816-7 OTP CID = 51 Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone S500 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 359885-01-852816-7 OTP CID = 51 Error : Failed. I write previously other thread that with k800 I have problem but problem continue and these phones....................... link for error boot k800 http:///vbb/showthread.php?t=560995 and another for this error that after boot show failed http:///vbb/showthread.php?t=539369 PLEASE SOLVE...................................... BR GSMLOVER |
07-17-2008, 14:16 | #3 (permalink) |
Insane Poster Join Date: Apr 2005 Location: Pilipinas ! Age: 42
Member: 137181 Status: Offline Thanks Meter: 3 | i got the same issues over and over i have 3 pcs w850 GDFS problem...same at stage 2 error if its a bug i hope they will resolve it soon cause many customers are waiting regards swensonb |
07-17-2008, 16:13 | #5 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Under the Sky
Member: 678886 Status: Offline Sonork: 100.1661586 Thanks Meter: 171 | i have one too k800 it gives error and cant connect with dreambox and setool what should we do stagte 1 is ok but sage 2 always fails |
07-17-2008, 16:24 | #7 (permalink) |
No Life Poster Join Date: Dec 2004 Location: all over the world Age: 45
Member: 101769 Status: Offline Sonork: 100.95669 Thanks Meter: 68 | I think that new version is too buggy Im also have some problems for that reason Im using old version and work like a charms. regards |
07-17-2008, 16:30 | #8 (permalink) |
Insane Poster Join Date: Jan 2004 Location: Slovakia
Member: 49999 Status: Offline Thanks Meter: 4 | TP STAGE 2 work too, but you must have good luck .... You must be patient. See me log.... [29/05/2008 18:11:26] User selected phone K800 using Test Point boot mode [29/05/2008 18:11:26] Stage 1 started [29/05/2008 18:11:26] 1) Turn OFF the phone. [29/05/2008 18:11:26] 2) Connect the phone to DreamBox cable. [29/05/2008 18:11:26] Boot Responce = 5A [29/05/2008 18:11:27] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [29/05/2008 18:11:29] NOR Flash ID = 897E [29/05/2008 18:11:29] OTP Status = LOCKED [29/05/2008 18:11:29] OTP IMEI = 354716-01-******-x [29/05/2008 18:11:29] OTP CID = 51 [29/05/2008 18:11:29] EROM Color = 4 : RED [29/05/2008 18:11:29] EROM CID = 51 [29/05/2008 18:11:57] Hint : Now the probe might be disconnected [29/05/2008 18:12:07] Processing ... [29/05/2008 18:12:07] Stage 1 completed succesfully [29/05/2008 18:12:08] Stage 2 start [29/05/2008 18:12:44] Hint : Now the probe might be disconnected [29/05/2008 18:12:49] Processing... [29/05/2008 18:12:56] Entering Security Bypass mode ... [29/05/2008 18:12:56] 1) Turn OFF the phone. [29/05/2008 18:12:56] 2) Connect the phone to DreamBox cable. [29/05/2008 18:12:56] Boot Responce = 5A [29/05/2008 18:12:56] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [29/05/2008 18:12:57] Sending Application ... [29/05/2008 18:12:59] NOR Flash ID = 897E [29/05/2008 18:12:59] OTP Status = LOCKED [29/05/2008 18:12:59] OTP IMEI = 354716-01-******-x [29/05/2008 18:12:59] OTP CID = 51 [29/05/2008 18:12:59] EROM Color = 4 : RED [29/05/2008 18:12:59] EROM CID = 52 [29/05/2008 18:13:01] Baseband Chip ID = 9900 [29/05/2008 18:13:01] Phone ID = 23809C6915606E76 [29/05/2008 18:13:01] Finalizing ... [29/05/2008 18:13:02] Stage 2 completed succesfully [29/05/2008 18:13:02] Done. |
07-19-2008, 13:23 | #9 (permalink) | |
Member: 678886 Status: Offline Sonork: 100.1661586 Thanks Meter: 171 | Quote:
07-19-2008, 14:54 | #12 (permalink) |
No Life Poster Join Date: May 2007 Location: Alien Nation
Member: 515413 Status: Offline Thanks Meter: 146 | [19/07/2008 05:51:55] Stage 2 start [19/07/2008 05:52:13] Hint : Now the probe might be disconnected [19/07/2008 05:52:18] Processing... [19/07/2008 05:52:24] Entering Security Bypass mode ... [19/07/2008 05:52:24] 1) Turn OFF the phone. [19/07/2008 05:52:24] 2) Connect the phone to DreamBox cable. [19/07/2008 05:52:25] Boot Responce = 5A [19/07/2008 05:52:25] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [19/07/2008 05:52:26] Sending Application ... [19/07/2008 05:52:27] NOR Flash ID = 2019 [19/07/2008 05:52:27] OTP Status = LOCKED [19/07/2008 05:52:27] OTP IMEI = 351708-01-355297-4 [19/07/2008 05:52:27] OTP CID = 49 [19/07/2008 05:52:28] EROM Color = 4 : RED [19/07/2008 05:52:28] EROM CID = 52 [19/07/2008 05:52:29] Baseband Chip ID = 9900 [19/07/2008 05:52:29] Phone ID = 2180DC5D1510BE56 [19/07/2008 05:52:29] Finalizing ... [19/07/2008 05:52:30] Stage 2 completed succesfully [19/07/2008 05:52:30] Done. [19/07/2008 05:52:30] [19/07/2008 05:52:36] --- Security Bypass------------------------------------------------------------ [19/07/2008 05:52:36] User selected phone K800 using Security Bypass boot mode [19/07/2008 05:52:36] 1) Turn OFF the phone. [19/07/2008 05:52:36] 2) Connect the phone to DreamBox cable. [19/07/2008 05:52:36] Boot Responce = 5A [19/07/2008 05:52:36] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [19/07/2008 05:52:38] Sending Application ... [19/07/2008 05:52:39] NOR Flash ID = 2019 [19/07/2008 05:52:39] OTP Status = LOCKED [19/07/2008 05:52:39] OTP IMEI = 351708-01-355297-4 [19/07/2008 05:52:39] OTP CID = 49 [19/07/2008 05:52:39] EROM Color = 4 : RED [19/07/2008 05:52:39] EROM CID = 52 [19/07/2008 05:52:41] Baseband Chip ID = 9900 [19/07/2008 05:52:41] Phone ID = 2180DC5D1510BE56 [19/07/2008 05:52:41] Flash Chip : ST M58PR512J [19/07/2008 05:52:41] Flash Chip ID : 88190020 [19/07/2008 05:52:49] | [19/07/2008 05:52:49] Status 09 >>>>THIS [19/07/2008 05:52:49] Error : Failed. [19/07/2008 05:52:49] [19/07/2008 05:52:53] --- Security Bypass------------------------------------------------------------ [19/07/2008 05:52:53] User selected phone K800 using Security Bypass boot mode [19/07/2008 05:52:53] 1) Turn OFF the phone. [19/07/2008 05:52:53] 2) Connect the phone to DreamBox cable. [19/07/2008 05:52:53] Boot Responce = 5A [19/07/2008 05:52:53] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [19/07/2008 05:53:01] Error : Please execute "Security Bypass" operation first [19/07/2008 05:53:01] Warning : Aborted by user. [19/07/2008 05:53:01] [19/07/2008 05:53:09] --- Security Bypass------------------------------------------------------------ [19/07/2008 05:53:09] User selected phone K800 using Security Bypass boot mode [19/07/2008 05:53:10] 1) Turn OFF the phone. [19/07/2008 05:53:10] 2) Connect the phone to DreamBox cable. [19/07/2008 05:53:10] Boot Responce = 5A [19/07/2008 05:53:10] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [19/07/2008 05:53:13] Error : Please execute "Security Bypass" operation first [19/07/2008 05:53:14] Warning : Aborted by user. [19/07/2008 05:53:14] [19/07/2008 05:53:18] --- Security Bypass------------------------------------------------------------ [19/07/2008 05:53:18] User selected phone K800 using Security Bypass boot mode [19/07/2008 05:53:19] 1) Turn OFF the phone. [19/07/2008 05:53:19] 2) Connect the phone to DreamBox cable. [19/07/2008 05:53:19] Boot Responce = 5A [19/07/2008 05:53:19] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [19/07/2008 05:53:21] Error : Please execute "Security Bypass" operation first [19/07/2008 05:53:21] Warning : Aborted by user. [19/07/2008 05:53:21] [19/07/2008 05:53:30] [19/07/2008 05:53:30] DBSS Start 3.6 [19/07/2008 05:53:38] --- Security Bypass------------------------------------------------------------ [19/07/2008 05:53:38] User selected phone K800 using Security Bypass boot mode [19/07/2008 05:53:38] 1) Turn OFF the phone. [19/07/2008 05:53:38] 2) Connect the phone to DreamBox cable. [19/07/2008 05:53:39] Boot Responce = 5A [19/07/2008 05:53:39] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [19/07/2008 05:53:43] Error : Please execute "Security Bypass" operation first [19/07/2008 05:53:43] Warning : Aborted by user. [19/07/2008 05:53:43] [19/07/2008 05:53:46] --- Security Bypass------------------------------------------------------------ [19/07/2008 05:53:46] User selected phone K800 using Test Point boot mode [19/07/2008 05:53:47] Stage 1 started [19/07/2008 05:53:47] 1) Turn OFF the phone. [19/07/2008 05:53:47] 2) Connect the phone to DreamBox cable. [19/07/2008 05:53:47] Boot Responce = 5A [19/07/2008 05:53:47] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [19/07/2008 05:53:49] NOR Flash ID = 2019 [19/07/2008 05:53:50] OTP Status = LOCKED [19/07/2008 05:53:50] OTP IMEI = 351708-01-355297-4 [19/07/2008 05:53:50] OTP CID = 49 [19/07/2008 05:53:50] Error : Failed. [19/07/2008 05:53:50] [19/07/2008 05:53:56] --- Security Bypass------------------------------------------------------------ [19/07/2008 05:53:56] User selected phone K800 using Test Point boot mode [19/07/2008 05:53:56] Stage 1 started [19/07/2008 05:53:56] 1) Turn OFF the phone. [19/07/2008 05:53:56] 2) Connect the phone to DreamBox cable. [19/07/2008 05:53:57] Boot Responce = 5A [19/07/2008 05:53:57] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [19/07/2008 05:53:59] NOR Flash ID = 2019 [19/07/2008 05:53:59] OTP Status = LOCKED [19/07/2008 05:53:59] OTP IMEI = 351708-01-355297-4 [19/07/2008 05:53:59] OTP CID = 49 [19/07/2008 05:53:59] Error : Failed. [19/07/2008 05:53:59] [19/07/2008 05:54:13] [19/07/2008 05:54:13] DBSS Start 3.6 [19/07/2008 05:54:25] --- Security Bypass------------------------------------------------------------ [19/07/2008 05:54:27] User selected phone K800 using Test Point boot mode [19/07/2008 05:54:28] Stage 1 started [19/07/2008 05:54:28] 1) Turn OFF the phone. [19/07/2008 05:54:28] 2) Connect the phone to DreamBox cable. [19/07/2008 05:54:28] Boot Responce = 5A [19/07/2008 05:54:28] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [19/07/2008 05:54:30] NOR Flash ID = 2019 [19/07/2008 05:54:30] OTP Status = LOCKED [19/07/2008 05:54:30] OTP IMEI = 351708-01-355297-4 [19/07/2008 05:54:30] OTP CID = 49 [19/07/2008 05:54:30] Error : Failed. [19/07/2008 05:54:30] [19/07/2008 05:54:32] --- Reading Info--------------------------------------------------------------- [19/07/2008 05:54:33] User selected phone K800 using Normal boot mode [19/07/2008 05:54:33] 1) Turn OFF the phone. [19/07/2008 05:54:33] 2) Connect the phone to DreamBox cable. [19/07/2008 05:54:33] Boot Responce = 5A [19/07/2008 05:54:33] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [19/07/2008 05:54:36] NOR Flash ID = 2019 [19/07/2008 05:54:36] OTP Status = LOCKED [19/07/2008 05:54:36] OTP IMEI = 351708-01-355297-4 [19/07/2008 05:54:36] OTP CID = 49 [19/07/2008 05:54:36] Error : Failed. [19/07/2008 05:54:36] [19/07/2008 05:54:37] --- Reading Info--------------------------------------------------------------- [19/07/2008 05:54:37] User selected phone K800 using Normal boot mode [19/07/2008 05:54:37] 1) Turn OFF the phone. [19/07/2008 05:54:37] 2) Connect the phone to DreamBox cable. [19/07/2008 05:54:37] Boot Responce = 5A [19/07/2008 05:54:37] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [19/07/2008 05:54:40] NOR Flash ID = 2019 [19/07/2008 05:54:40] OTP Status = LOCKED [19/07/2008 05:54:40] OTP IMEI = 351708-01-355297-4 [19/07/2008 05:54:40] OTP CID = 49 [19/07/2008 05:54:40] Error : Failed. [19/07/2008 05:54:40] [19/07/2008 05:54:40] --- Reading Info--------------------------------------------------------------- [19/07/2008 05:54:40] User selected phone K800 using Normal boot mode [19/07/2008 05:54:41] 1) Turn OFF the phone. [19/07/2008 05:54:41] 2) Connect the phone to DreamBox cable. [19/07/2008 05:54:41] Boot Responce = 5A [19/07/2008 05:54:41] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [19/07/2008 05:54:43] NOR Flash ID = 2019 [19/07/2008 05:54:43] OTP Status = LOCKED [19/07/2008 05:54:43] OTP IMEI = 351708-01-355297-4 [19/07/2008 05:54:43] OTP CID = 49 [19/07/2008 05:54:44] Error : Failed. [19/07/2008 05:54:44] [19/07/2008 05:54:54] --- Security Bypass------------------------------------------------------------ [19/07/2008 05:54:54] User selected phone K800 using Test Point boot mode [19/07/2008 05:54:55] Stage 2 start >>>AFTER CHANGE SENSITIFITY [19/07/2008 05:55:48] Hint : Now the probe might be disconnected [19/07/2008 05:55:53] Processing... [19/07/2008 05:56:00] Entering Security Bypass mode ... [19/07/2008 05:56:00] 1) Turn OFF the phone. [19/07/2008 05:56:00] 2) Connect the phone to DreamBox cable. [19/07/2008 05:56:00] Boot Responce = 5A [19/07/2008 05:56:00] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [19/07/2008 05:56:02] Sending Application ... [19/07/2008 05:56:03] NOR Flash ID = 2019 [19/07/2008 05:56:03] OTP Status = LOCKED [19/07/2008 05:56:03] OTP IMEI = 351708-01-355297-4 [19/07/2008 05:56:03] OTP CID = 49 [19/07/2008 05:56:03] EROM Color = 4 : RED [19/07/2008 05:56:03] EROM CID = 52 [19/07/2008 05:56:05] Baseband Chip ID = 9900 [19/07/2008 05:56:05] Phone ID = 2180DC5D1510BE56 [19/07/2008 05:56:05] Finalizing ... [19/07/2008 05:56:05] Stage 2 completed succesfully [19/07/2008 05:56:06] Done. [19/07/2008 05:56:06] [19/07/2008 05:56:09] --- Security Bypass------------------------------------------------------------ [19/07/2008 05:56:09] User selected phone K800 using Security Bypass boot mode [19/07/2008 05:56:09] 1) Turn OFF the phone. [19/07/2008 05:56:09] 2) Connect the phone to DreamBox cable. [19/07/2008 05:56:10] Boot Responce = 5A [19/07/2008 05:56:10] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [19/07/2008 05:56:11] Sending Application ... [19/07/2008 05:56:12] NOR Flash ID = 2019 [19/07/2008 05:56:12] OTP Status = LOCKED [19/07/2008 05:56:12] OTP IMEI = 351708-01-355297-4 [19/07/2008 05:56:12] OTP CID = 49 [19/07/2008 05:56:12] EROM Color = 4 : RED [19/07/2008 05:56:12] EROM CID = 52 [19/07/2008 05:56:14] Baseband Chip ID = 9900 [19/07/2008 05:56:14] Phone ID = 2180DC5D1510BE56 [19/07/2008 05:56:14] Flash Chip : ST M58PR512J [19/07/2008 05:56:14] Flash Chip ID : 88190020 [19/07/2008 05:56:28] 1) Turn OFF the phone. [19/07/2008 05:56:28] 2) Connect the phone to DreamBox cable. [19/07/2008 05:56:28] Boot Responce = 5A [19/07/2008 05:56:28] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [19/07/2008 05:56:29] Sending Application ... [19/07/2008 05:56:31] NOR Flash ID = 2019 [19/07/2008 05:56:31] OTP Status = LOCKED [19/07/2008 05:56:31] OTP IMEI = 351708-01-355297-4 [19/07/2008 05:56:31] OTP CID = 49 [19/07/2008 05:56:31] EROM Color = 4 : RED [19/07/2008 05:56:31] EROM CID = 52 [19/07/2008 05:56:33] Baseband Chip ID = 9900 [19/07/2008 05:56:33] Phone ID = 2180DC5D1510BE56 [19/07/2008 05:56:33] Finalizing ... [19/07/2008 05:56:33] Done. [19/07/2008 05:56:33] [19/07/2008 05:56:37] --- Unlock and Repair---------------------------------------------------------- [19/07/2008 05:56:37] User selected phone K800 using Security Bypass boot mode [19/07/2008 05:56:38] 1) Turn OFF the phone. [19/07/2008 05:56:38] 2) Connect the phone to DreamBox cable. [19/07/2008 05:56:38] Boot Responce = 5A [19/07/2008 05:56:38] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [19/07/2008 05:56:39] Sending Application ... [19/07/2008 05:56:41] NOR Flash ID = 2019 [19/07/2008 05:56:41] OTP Status = LOCKED [19/07/2008 05:56:41] OTP IMEI = 351708-01-355297-4 [19/07/2008 05:56:41] OTP CID = 49 [19/07/2008 05:56:41] EROM Color = 4 : RED [19/07/2008 05:56:41] EROM CID = 52 [19/07/2008 05:56:42] Baseband Chip ID = 9900 [19/07/2008 05:56:42] Phone ID = 2180DC5D1510BE56 [19/07/2008 05:56:42] Reading GDFS... [19/07/2008 05:56:43] Error : CRC failed [19/07/2008 05:56:43] Error : Failed. [19/07/2008 05:56:43] [19/07/2008 05:56:46] --- Loading GDFS file---------------------------------------------------------- [19/07/2008 05:56:55] Loading "E:\DB\gdfs\K800_gdfs.dmap"... [19/07/2008 05:56:55] Done. [19/07/2008 05:56:55] [19/07/2008 05:56:56] --- Write GDFS----------------------------------------------------------------- [19/07/2008 05:56:56] User selected phone K800 using Security Bypass boot mode [19/07/2008 05:56:57] 1) Turn OFF the phone. [19/07/2008 05:56:57] 2) Connect the phone to DreamBox cable. [19/07/2008 05:56:57] Boot Responce = 5A [19/07/2008 05:56:57] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [19/07/2008 05:56:58] Sending Application ... [19/07/2008 05:57:00] NOR Flash ID = 2019 [19/07/2008 05:57:00] OTP Status = LOCKED [19/07/2008 05:57:00] OTP IMEI = 351708-01-355297-4 [19/07/2008 05:57:00] OTP CID = 49 [19/07/2008 05:57:00] EROM Color = 4 : RED [19/07/2008 05:57:00] EROM CID = 52 [19/07/2008 05:57:01] Baseband Chip ID = 9900 [19/07/2008 05:57:01] Phone ID = 2180DC5D1510BE56 [19/07/2008 05:57:01] Flash Chip : ST M58PR512J [19/07/2008 05:57:01] Flash Chip ID : 88190020 [19/07/2008 05:57:01] Generating GDFS... [19/07/2008 05:57:01] Writing GDFS... [19/07/2008 05:57:06] Done. [19/07/2008 05:57:06] [19/07/2008 05:57:08] --- Unlock and Repair---------------------------------------------------------- [19/07/2008 05:57:08] User selected phone K800 using Security Bypass boot mode [19/07/2008 05:57:09] 1) Turn OFF the phone. [19/07/2008 05:57:09] 2) Connect the phone to DreamBox cable. [19/07/2008 05:57:09] Boot Responce = 5A [19/07/2008 05:57:09] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [19/07/2008 05:57:10] Sending Application ... [19/07/2008 05:57:12] NOR Flash ID = 2019 [19/07/2008 05:57:12] OTP Status = LOCKED [19/07/2008 05:57:12] OTP IMEI = 351708-01-355297-4 [19/07/2008 05:57:12] OTP CID = 49 [19/07/2008 05:57:12] EROM Color = 4 : RED [19/07/2008 05:57:12] EROM CID = 52 [19/07/2008 05:57:13] Baseband Chip ID = 9900 [19/07/2008 05:57:13] Phone ID = 2180DC5D1510BE56 [19/07/2008 05:57:13] Reading GDFS... [19/07/2008 05:57:15] Testing security ... [19/07/2008 05:57:15] GDFS 0013 Hash Failed [19/07/2008 05:57:15] GDFS 0006 Hash Failed [19/07/2008 05:57:15] GDFS 000E Hash Failed [19/07/2008 05:57:15] GDFS 001C Hash Failed [19/07/2008 05:57:15] Unlocking ... [19/07/2008 05:57:16] Testing security ... [19/07/2008 05:57:16] GDFS 0013 Hash OK [19/07/2008 05:57:16] GDFS 0006 Hash OK [19/07/2008 05:57:16] GDFS 000E Hash OK [19/07/2008 05:57:16] GDFS 001C Hash OK [19/07/2008 05:57:16] Generating GDFS... [19/07/2008 05:57:16] Writing GDFS... [19/07/2008 05:57:20] Done. |
07-19-2008, 16:19 | #13 (permalink) | |
Member: 52956 Status: Offline Thanks Meter: 49 | Quote:
at frist we have error 09 after 2 times then flash ic tamperd and not recognized with dreambox.............. then we cant change sensivity from 70 to 90............... | |
07-19-2008, 17:30 | #14 (permalink) |
Member: 678886 Status: Offline Sonork: 100.1661586 Thanks Meter: 171 | i agree with gsmlover phone cant be recognized by box ...it dosnt give info.. but some times after a few tries it with be ok once but fails on stage2 i've tried with all possible sensevity but no luck |
07-19-2008, 20:45 | #15 (permalink) |
Member: 137181 Status: Offline Thanks Meter: 3 | me too tried any possible sensitivity on my s500 though....no luck still failed at stage 2. always a long beeeeeeeepppppppp after connecting to TP area...nothing GND touches needle exept TP point hmmmmm... regards swensonb |
17-09-2008 MEGA update again and again! New flash files added to support area! | GSMtricks | Multi-box LITE | 2 | 09-28-2008 02:52 |
17-09-2008 MEGA update again and again! New flash files added to support area! | GSMtricks | PadFinder box | 2 | 09-17-2008 15:51 |
17-09-2008 MEGA update again and again! New flash files added to support area! | GSMtricks | Multi-Box | 1 | 09-17-2008 15:40 |
17-09-2008 MEGA update again and again! New flash files added to support area! | GSMtricks | Chinese Cocktail | 0 | 09-17-2008 13:16 |
17-09-2008 MEGA update again and again! New flash files added to support area! | GSMtricks | Service Products News & Updates | 0 | 09-17-2008 13:13 |
