08-31-2008, 01:34 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: ALGERIA Age: 17
Member: 467636 Status: Offline Sonork: Double Kanon Thanks Meter: 2,654 | K550 problem In TP 2 [30/08/2008 18:54:26] User selected phone K550 using Test Point boot mode [30/08/2008 18:54:27] Stage 1 started [30/08/2008 18:54:27] 1) Turn OFF the phone. [30/08/2008 18:54:27] 2) Connect the phone to DreamBox cable. [30/08/2008 18:54:27] Boot Responce = 5A [30/08/2008 18:54:27] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [30/08/2008 18:54:29] NOR Flash ID = 897E [30/08/2008 18:54:29] OTP Status = LOCKED [30/08/2008 18:54:29] OTP IMEI = 356657-01-952019-3 [30/08/2008 18:54:29] OTP CID = 51 [30/08/2008 18:54:29] EROM Color = 4 : RED [30/08/2008 18:54:29] EROM CID = 52 [30/08/2008 18:54:40] Hint : Now the probe might be disconnected [30/08/2008 18:54:49] Processing ... [30/08/2008 18:54:49] Stage 1 completed succesfully [30/08/2008 18:54:50] Stage 2 start [30/08/2008 18:55:03] Timeout detected [30/08/2008 18:55:03] Error : Failed. Allways this message error when i do the second TP"Timeout detected " "Error : Failed." it's show that's working But allTimeswith this msg error I can do directelly the TP TP2 but ALL time with this message error. but when i want to read info It's stop in 97% the first time it not stop in 97% PLease confirme me That's HRADware Or soft Ware Problem THX |
08-31-2008, 03:06 | #2 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Pinas Age: 45
Member: 91411 Status: Offline Sonork: 100.1584444 Thanks Meter: 372 | have you tried to adjust your pin detection?try to adjust it to 80%...also try to change your dbss version....hope it helps.post result....... |
08-31-2008, 10:11 | #3 (permalink) |
Insane Poster Join Date: Apr 2005 Location: Pilipinas ! Age: 43
Member: 137181 Status: Offline Thanks Meter: 3 | yes follow what alfox said on tp sensitivity when in TP process try to press ON/OFF switch see if it responds post results regards swensonb DBSS USER |
v3re problems in tp | chris2007 | Smart-Clip | 3 | 01-16-2009 09:34 |
