06-09-2008, 09:49 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: ---------->>Gsm City
Member: 489622 Status: Offline Thanks Meter: 435 | k550i cant repair GDFS Code: --- Write GDFS----------------------------------------------------------------- User selected phone K550 using Test Point boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 356657-01-984596-2 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Flash Chip : ST M58PR512J Flash Chip ID : 88190020 Generating GDFS... Writing GDFS... Done. Code: --- Loading Main Firmware file------------------------------------------------- Loading "E:\Dream Box\K550\R6BC002\CXC1250669_LI_RED_CID52_R6BC002.dtf"... Model : K550c Version : R6BC002 Done. --- Loading File System file--------------------------------------------------- Loading "E:\Dream Box\K550\R6BC002\FS_T_MOB_INT_B_LI_RED_CID52_R6BC002[sk,mk,hu,hr,en].dtf"... Model : K550i Version : R6BC002 Languages : sk,mk,hu,hr,en Done. --- Loading customization package---------------------------------------------- Loading "E:\Dream Box\K550\R6BC002\CDA102743-88_[T_MOB_INT_B].dta"... [CDA info] cda-number : CDA102743/88 cda-revision : R7A country : Slovak Republic operator : T-Mobile SK language-variant-name : T_MOB_INT_B Done. --- Writing firmware----------------------------------------------------------- User selected phone K550 using Normal boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 356657-01-984596-2 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Sending Main Firmware Certificate ... OK. Writing Main Firmware Blocks Finished. Sending File System Certificate ... OK. Writing File System Blocks Finished. Starting CS Loader GDFS Service ... Starting CS Loader File System Service ... Error : Failed. Please help me out dreambox supporter what should i have to do? BR, yasin_telecom |
06-10-2008, 08:52 | #4 (permalink) |
Member: 489622 Status: Offline Thanks Meter: 435 | But same with DCU60 cutomization not done. yes i already done repair/unlock, but problem is now white display vibrate, but cutomization not done, error! how to fix it? BR, yasin_telecom |
07-15-2008, 12:14 | #11 (permalink) |
No Life Poster Join Date: Apr 2005 Location: .... Ghari Matani ...... Age: 18
Member: 135601 Status: Offline Sonork: 100.1612518 Thanks Meter: 68 | Now its An Hw Prob as i thk ...... same condition an K800i .... ven Customize Gdfs Got error ..... Anywyz i try wid SETool .....Flash IC faulty BR |
07-29-2008, 09:51 | #14 (permalink) |
Freak Poster Join Date: Feb 2005 Age: 52
Member: 114143 Status: Offline Thanks Meter: 55 | @GSM Dream please salove my prolem k550i i recived k550 in white light i did tp and unlock and repair Gdfs security --same white light i fallow this steps 1. Download that file - k550_Full_Flash 3. Select Access Mode - Test Point 4. Go to Security tab & Execute " Security Bypass" Operation 5. Select Access Mode - Security Bypass 6. Go to Misc tab & Write Full Flash (look in p.#1) 7. After flashing go to Security tab & make "Unlock & Repair GDFS Sec. Blc." 8. Go to Flash tab & flash: Main+FS+Custpac. ---same white light and i tryed onley write gdfs ---handset switched on but all locks closed "0" after that i tryed "Unlock & Repair GDFS Sec. Blc" ---handset gone white light please tell me what is the problem |
The Following User Says Thank You to mohangbvk For This Useful Post: |
07-29-2008, 11:26 | #15 (permalink) | |
No Life Poster Join Date: Dec 2005
Member: 214480 Status: Offline Thanks Meter: 2,087 | Hello mohangbvk! Quote:
k550i after repair gdfs cid53 with log phone onley sony ericsson logo | ..:::Gsm india:::.. | SETool2 | 7 | 02-27-2010 04:34 |
K800 Cant Repair GDFS Error in Stage 2 | tcom25100 | DreamBox | 2 | 07-18-2008 08:16 |
K800 cant repair Gdfs ?? | ~mr_Ten$ion~ | SETool2 | 2 | 07-10-2008 02:21 |
k320i cant repair gdfs | 99026 | DreamBox | 3 | 05-24-2008 05:54 |
Cant Repair Gdfs | Nasmi | DreamBox | 2 | 05-06-2008 11:15 |
