08-27-2008, 21:22 | #1 (permalink) |
Insane Poster Join Date: Apr 2005 Location: Pilipinas ! Age: 42
Member: 137181 Status: Offline Thanks Meter: 3 | K610 DEAD GDFS Problem Success ! with DEAD GDFS Problem after the long time stocked i managed to revive it via TP and matching tricks for stubborn stage 2 failed problem Here's The LOGS Code: -- Security Bypass------------------------------------------------------------ User selected phone K610 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 357912-01-swensonb OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K610 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 357912-01-swensonb OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Stage 1 completed succesfully Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K610 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K610 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K610 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K610 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K610 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K610 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K610 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K610 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K610 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K610 using Test Point boot mode Stage 2 start Hint : Now the probe might be disconnected Processing... Entering Security Bypass mode ... 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 357912-01-swensonb OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 238018761550E020 Finalizing ... Stage 2 completed succesfully Done. --- Unlock and Repair---------------------------------------------------------- User selected phone K610 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 357912-01-swensonb OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 238018761550E020 Reading GDFS... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Unlocking ... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Generating GDFS... Writing GDFS... Done. thanks to wallyboy for the unit and master sh-fu alfox for the encouragement regards swensonb |
09-03-2008, 22:46 | #2 (permalink) |
Crazy Poster Join Date: Dec 2006
Member: 419750 Status: Offline Thanks Meter: 6 | Hi, today, I tried unlock K610 aswell, but I didn't have too much luck like you. I tried many time make TP for stage 2 (pin 15), but it still "Timeout".When I made TP for stage 2 red diode (close to power button) started flashing, but phone is working well (it means no broken GDFS), customer is using phone normal. It is second phone with same behaviour, and same fault. I don't know, where is fault. - Security Bypass------------------------------------------------------------ User selected phone K610 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 351943-01-******-* OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Stage 1 completed succesfully Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K610 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K610 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K610 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. BR G. |
Customer's w580i Phone dead after unlocking!! Now GDFS problem PLEASE HELP ASAP!!! | djdownfawl | SETool2 | 13 | 11-26-2009 08:49 |
K530 dead GDFS success via TP DBSS | swensonb | DreamBox | 5 | 09-27-2009 05:51 |
K610 GDFS repaired successfully with v .43 | hasnain | SETool2 | 0 | 09-09-2009 17:10 |
K610 repair gdfs error! | chikubie | Cruiser Suite | 16 | 09-30-2008 05:18 |
K610 Dead Cid 52 Damage Gdfs | ronkiton | DreamBox | 0 | 03-29-2008 12:29 |
