Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > DreamBox
Old 06-11-2008, 08:04   #1 (permalink)
mj_0990's Avatar
Member: 306026
Thanks Meter: 111
k610 redblink after write gdfs
hello
i have k610 only redblink after write gdfs with dbse
before write gdfs the phone can connect with dbse and any flasher box
but now it can't connect with dbse and any flasher box
what should i do to make this phone alive
Old 06-11-2008, 11:05   #2 (permalink)
GSM Dream's Avatar
Member: 214480
Thanks Meter: 2,087
Hello!
1. Download fullflash file for K610
2. Choose model K610 in DBSS
3. Select Access Mode - Test Point
4. Go to Security tab & Execute " Security Bypass" Operation
5. Select Access Mode - Security Bypass
6. Go to Misc tab & Write Full Flash (look in p.#1)
7. After flashing go to Security tab & make "Unlock & Repair GDFS Sec. Blc."
8. Go to Flash tab & flash: Main+FS+Custpac.
If that not help to You so it is HW problem - LCD, FlexCable, Flash IC, water damage etc. ...
Old 06-11-2008, 11:28   #3 (permalink)
Member: 515413
Thanks Meter: 146
Originally Posted by mj_0990 View Post
hello
try trick's..make short + - for 3seconds ,,try 2/3 times...
Old 06-11-2008, 11:35   #4 (permalink)
mj_0990's Avatar
Member: 306026
Thanks Meter: 111
yes i already this trik and phone can connect perfect on dbse
but after tp stage 2 the phone can't connect again
can't detect flash chip
i try to reball the flash chip but its not change anything
--- Reading Info---------------------------------------------------------------
User selected phone K610 using Test Point boot mode
1) Turn OFF the phone.
2) Connect the phone to DreamBox cable.
Boot Responce = 5A
Processor ID = 99000301FFFFFFFF (DB2020 / DB2030)
Error : Failed.
on setool it said
SIGNED MODE (USING SERVER).
ALTERNATIVE SECURITY BYPASS ENABLED.
Open COM port OK
ChipID:9900,EMP protocol:0301
Speed:921600
err: 45 (13)
loader prologue returns invalid status
Can't load ID loader !
Elapsed: 16 secs
if flash chip damage it usualy said phone is black
Old 06-11-2008, 11:47   #5 (permalink)
mj_0990's Avatar
Member: 306026
Thanks Meter: 111
i need to know the value of this capasitor
Old 06-11-2008, 22:54   #6 (permalink)
TICTAC_M's Avatar
Member: 331361
Thanks Meter: 155
read it post, it can help you.
http://www./showthread.php?t=548242
Old 06-13-2008, 13:37   #7 (permalink)
sharaz191's Avatar
Member: 249300
Sonork: 10101010
Thanks Meter: 569
err: 45 (13)
flash chip damage..replace new flash chip
Old 06-13-2008, 18:42   #8 (permalink)
harim_1981's Avatar
Member: 243961
Sonork: 100.1591654
Thanks Meter: 104
is that may be TPs short circuited...
w850 dead after write gdfs in se tool help manekmobile07 Old Ericsson Phones & Sony Phones 2 12-04-2007 13:05
how to unlock k800i after write gdfs kurdistan Cruiser Suite 4 10-01-2007 14:26
Problem radio k750 after write gdfs and repuild SP area gprsman SonyEricsson (USB-Smart) 1 08-20-2006 21:10
After write GDFS z530i ...... smartecs Cruiser Suite 2 07-14-2006 09:20
Lg u8120c Dead After write GDFS By HWK fromdesert LG 0 03-22-2006 11:20
Page generated in 0.20741 seconds with 10 queries
