Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > DreamBox
Old 10-04-2008, 08:23   #76 (permalink)
ken_jez's Avatar
Member: 612008
Thanks Meter: 25
Originally Posted by FullFLASHgSMPH View Post
test w660 need remove flash ic tested
sir pls post the pic for references.. tia
Old 10-04-2008, 09:25   #77 (permalink)
FullFLASHgSMPH's Avatar
Member: 161739
Sonork: 100.1584054
Thanks Meter: 3,338
log tested today
need to remove flash ic....
--- Security Bypass------------------------------------------------------------
User selected phone W660 using Test Point boot mode
Stage 1 started
1) Turn OFF the phone.
2) Connect the phone to DreamBox cable.
Boot Responce = 5A
Processor ID = 99000301FFFFFFFF (DB2020 / DB2030)
NOR Flash ID = 897E
OTP Status = LOCKED
OTP IMEI = 359584-01-132491-0
OTP CID = 51
EROM Color = 4 : RED
EROM CID = 52
Hint : Now the probe might be disconnected
Processing ...
Stage 1 completed succesfully
Stage 2 start
Processing...
Entering Security Bypass mode ...
Boot Responce = 5A
Sending Application ...
NOR Flash ID = 897E
OTP Status = LOCKED
OTP CID = 51
EROM CID = 52
Baseband Chip ID = 9900
Phone ID = 2380A07C15B05820
Finalizing ...
Stage 2 completed succesfully
Done.
Unlock and Repair----------------------------------------------------------
User selected phone W660 using Security Bypass boot mode
Boot Responce = 5A
NOR Flash ID = 897E
OTP Status = LOCKED
OTP CID = 51
EROM CID = 52
Reading GDFS...
Testing security ...
GDFS 0013 Hash Failed
GDFS 0006 Hash Failed
GDFS 000E Hash Failed
GDFS 001C Hash Failed
Unlocking ...
GDFS 0013 Hash OK
GDFS 0006 Hash OK
GDFS 000E Hash OK
GDFS 001C Hash OK
Generating GDFS...
Writing GDFS...
Done.
Old 10-08-2008, 14:44   #78 (permalink)
Member: 482218
Thanks Meter: 119
w580/s500 new 5060MOYOBE A8017126 tp succeeded as posted by other user. tp1 is done in pin 1 same side as other moyobe and tp2 using easy tp2. worked like a charm!!
The Following User Says Thank You to el_venga For This Useful Post:
Old 10-15-2008, 23:55   #79 (permalink)
Member: 175273
Thanks Meter: 68
Originally Posted by llcoolr View Post
man please upload easy tp for stage1 model k610
And stage2 please ! I am trying hous and hours to bypass stage 2 without issue .
Old 10-25-2008, 17:57   #80 (permalink)
Member: 379788
Thanks Meter: 13
plz help me whare is TP w660 ????????????????????????? Plz
Old 03-26-2009, 00:36   #81 (permalink)
MYUNLOCKING's Avatar
Member: 749969
Sonork: 100.1581886
Thanks Meter: 771
Is it necessary to resold again both resistors near tp2 after tp..
and if i do wrong tp2 then is it necessary to start again whole process like first tp1 then tp2 or just start from tp2?
my last question is is there any way to repair redblink with out opening phone in cid52 or above??
Old 03-26-2009, 04:11   #82 (permalink)
Member: 161739
Sonork: 100.1584054
Thanks Meter: 3,338
nono why not killing market
Old 08-12-2010, 13:11   #83 (permalink)
Member: 670125
Thanks Meter: 18
Hi I need K770 easy tp urgent please.cant connect to using dcu mode to write gdfs
my 101x sag dd make some easy GsmXplorer SAGEM JTAG UNLOCKER 2 05-09-2007 10:58
Making Tp With Majic Tp-some Questions jamohaki Ultima Box Light 4 05-04-2007 09:49
how to make p2k easy-tool working in my xp,sp2 Gjakova Motorola P2K (USB-Smart) 9 07-18-2006 20:41
Is possible make an easy way to convers v525 to v600? Uvedovle Smart-Clip 7 02-15-2005 00:55
why dont u make it easy steve faisal butt FuriouS II 1 09-20-2004 10:12
Page generated in 0.18596 seconds with 10 queries
