03-08-2006, 22:27 | #1 (permalink) |
Freak Poster Join Date: Jun 2002 Location: Spain Age: 52
Member: 13239 Status: Offline Thanks Meter: 3 | My first impression with this Box 1- The is no TP for M55? I only see Cutting Track TP. Finaly I did it with java midlet patching, and SST cracked (I readed after patched can boot with normal mode select, will try with next one). I edit tested this morning same method with one C60 with bootcore patched and same result, this has to be made with SST too: [09/03/2006 08:43:52] --- Reading Info--------------------------------------------------------------- [09/03/2006 08:43:52] User selected phone C60 using Normal (Cut track) boot mode [09/03/2006 08:43:53] [09/03/2006 08:43:53] Power On the phone ... OK [09/03/2006 08:43:54] [09/03/2006 08:43:54] Error : Sending loader failed. Check Boot Mode selection. [09/03/2006 08:43:54] [09/03/2006 08:43:54] Error : Check phone model selection. [09/03/2006 08:43:54] Error : Failed. [09/03/2006 08:43:58] --- Reading Info--------------------------------------------------------------- [09/03/2006 08:43:58] User selected phone C60 using Boot Core BUG boot mode [09/03/2006 08:43:59] [09/03/2006 08:43:59] Power On the phone ... OK [09/03/2006 08:44:01] [09/03/2006 08:44:01] Error : Sending loader failed. Check Boot Mode selection. [09/03/2006 08:44:01] [09/03/2006 08:44:01] Error : Check phone model selection. [09/03/2006 08:44:01] Error : Failed. For this fones is needed a way to send false bootkey to boot it. 2- With an CF75 (that is S-Gold) I read in manual you can use both probes, but always soft says : "Please use testpoint and press button if ready". So if I use probe without button must press button in the one with it?? Don't understand the use of this method, any one can explain? 3- Why same boot method is called in different way (stored boot key for E-Gold, Imei for S-Gold)? I think boot are Stored BKey, obviously calculated before with other boot method. By now I'm very happy with this box, made without problems an CF62, A57, CF75 and C65, don't expect less from this Great Team. CONGRATULATIONS. And Carry On (as a song says) Best Regards Last edited by jesusangel; 03-09-2006 at 08:58. |
03-09-2006, 11:19 | #2 (permalink) | ||||
No Life Poster Join Date: Dec 2005
Member: 214480 Status: Offline Thanks Meter: 2,087 | Quote:
We know about this boot mathod, and will support it in next updates. Quote:
You can use any probe for touch to pint on the board. But after that you must press the button on the probe whith button. For example: You touch to the testpoint using probe without button and push the button on other probe, or you touch to the testpoint using probe with button and push the button on it. Quote:
Stored Boot Key for E-Gold - use key calculated before with other boot method Quote:
Thank you ! | ||||
03-09-2006, 16:25 | #3 (permalink) |
Member: 13239 Status: Offline Thanks Meter: 3 | Ok, understood and wait for this E-Gold improvement. One mor thing, I still working with new models and comment Waht I see. Today C75: 1- Auto mode don't work because when DreamBox emulates sim in phone, it ask if wan to copy sim phonebook and still waiting for an answer, so process fail. 2- In manual mode I execute all correctly but Dreambox still Working and finaly the moving bar stops, and stay this way \. After 20-30 minutes I decided to abort and swicht off phone. But it seems like works because next time I read info with auto mode it last some time (I supose to calculate Bootkey) and finaly read all info, and next time of course this process with Bkey calculated was faster, and of course can rad flash and unlock. Tomorrow will try with another C75, if you think or know this a bug and need the logs let me know, and will send it. Regards |
03-09-2006, 17:00 | #4 (permalink) | |||
If you will have this problem - just try once more. Quote:
You must not wait 20-30 min, maximum 3-5 minutes. (usually it takes about 1 minute). Thanks, we will explore this problem. Quote:
Thank you for report. It would be good if you will sent logs to us. | |||
Ub team my first day with ub box need info | MR PROTEC | Universalbox | 9 | 09-18-2009 10:20 |
:: Read this - First steps with Multi-box LITE :: read before use | GSMtricks | Multi-box LITE | 0 | 09-02-2007 10:20 |
this is my first post of this forum | itmobiz | Old Ericsson Phones & Sony Phones | 9 | 06-26-2007 18:45 |
my first N500i with furious | JAVA Good | FuriousGold | 2 | 11-10-2006 12:22 |
my first time with NS dongle | saiful2001 | NSPRO | 2 | 11-25-2005 13:09 |
