05-09-2008, 04:05 | #1 (permalink) |
Banned Join Date: Jul 2005 Location: Philippines Age: 53
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | Post Problem SUCCESS by DREAMBOX PROBLEM GDFS and Invalid GDFS structure and/or configuration Reading Info--------------------------------------------------------------- User selected phone K320 using Normal boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 50 NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 353322-01-150204-5 OTP CID = 50 EROM Color = 4 : RED EROM CID = 50 GDFS Simlocks : Lock 0 = LOCKED (01) [5/5] (Network) Lock 1 = OFF (00) [5/5] (Network Subset) Lock 2 = OFF (00) [5/5] (Service Provider) Lock 3 = OFF (00) [5/5] (Corporate) Lock 4 = OFF (00) [5/5] (SIM Card) Lock 5 = OFF (00) [5/5] (Extended) Operator code = 515-05 Done. --- Security Bypass------------------------------------------------------------ User selected phone K320 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 50 NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 353322-01-150204-5 OTP CID = 50 EROM Color = 4 : RED EROM CID = 50 Hint : Now the probe might be disconnected Processing ... Stage 1 completed succesfully Stage 2 start Hint : Now the probe might be disconnected Processing... Entering Security Bypass mode ... 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 50 Baseband Chip ID = 8040 Phone ID = 22802A6415C0AB24 Finalizing ... Stage 2 completed succesfully Done. --- Unlock and Repair---------------------------------------------------------- User selected phone K320 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 50 Baseband Chip ID = 8040 Phone ID = 22802A6415C0AB24 Reading GDFS... Testing security ... GDFS 0013 Hash Failed GDFS 0006 Hash Failed GDFS 000E Hash Failed GDFS 001C Hash Failed Unlocking ... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Generating GDFS... Writing GDFS... Done. |
05-09-2008, 12:32 | #2 (permalink) |
No Life Poster Join Date: Mar 2006 Location: tamilnadu, india.
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | Success ...success....success..... K550 GDFS repaired successfully.... thanks to Dream team... Code: --- Security Bypass------------------------------------------------------------ User selected phone K550 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 358516-01-121770-3 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Stage 1 completed succesfully Stage 2 start Hint : Now the probe might be disconnected Processing... Entering Security Bypass mode ... 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 358516-01-121770-3 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 2380747815A0BA1D Finalizing ... Stage 2 completed succesfully Done. --- Loading GDFS file---------------------------------------------------------- Loading "D:\DreamSE\GDFS\K550\K550.dmap"... Done. --- Write GDFS----------------------------------------------------------------- User selected phone K550 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 358516-01-121770-3 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 2380747815A0BA1D Flash Chip : Intel 48F50xxM0Y0 Flash Chip ID : 887E0089 Generating GDFS... Writing GDFS... Done. --- Unlock and Repair---------------------------------------------------------- User selected phone K550 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 358516-01-121770-3 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 2380747815A0BA1D Reading GDFS... Testing security ... GDFS 0013 Hash Failed GDFS 0006 Hash Failed GDFS 000E Hash Failed GDFS 001C Hash Failed Unlocking ... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Generating GDFS... Writing GDFS... Done. |
05-10-2008, 13:32 | #3 (permalink) |
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | Another w200 " FULL " unlocked by DreamSE...thanks to team... Code: --- Security Bypass------------------------------------------------------------ User selected phone W200 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 52 NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 359707-01-570231-6 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Stage 1 completed succesfully Stage 2 start Hint : Now the probe might be disconnected Processing... Entering Security Bypass mode ... 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 8040 Phone ID = 23801B7D1570378B Finalizing ... Stage 2 completed succesfully Done. --- Unlock and Repair---------------------------------------------------------- User selected phone W200 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 8040 Phone ID = 23801B7D1570378B Reading GDFS... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Unlocking ... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Generating GDFS... Writing GDFS... Done. |
05-14-2008, 06:56 | #4 (permalink) |
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | After lot of Struggle....i got working W850.... log is here... Code: -- Security Bypass------------------------------------------------------------ User selected phone W850 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 352826-01-375038-7 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Stage 1 completed succesfully Stage 2 start Hint : Now the probe might be disconnected Processing... Entering Security Bypass mode ... 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 352826-01-375038-7 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 21803A6215E08F5B Finalizing ... Stage 2 completed succesfully Done. --- Write GDFS----------------------------------------------------------------- User selected phone W850 using Test Point boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 352826-01-375038-7 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Warning : Aborted by user. --- Write GDFS----------------------------------------------------------------- User selected phone W850 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 352826-01-375038-7 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 21803A6215E08F5B Flash Chip : ST M58PR512J Flash Chip ID : 88190020 Generating GDFS... Writing GDFS... Done. --- Unlock and Repair---------------------------------------------------------- User selected phone W850 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 352826-01-375038-7 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 21803A6215E08F5B Reading GDFS... Testing security ... GDFS 0013 Hash Failed GDFS 0006 Hash Failed GDFS 000E Hash Failed GDFS 001C Hash Failed Unlocking ... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Generating GDFS... Writing GDFS... Error : Failed. --- Unlock and Repair---------------------------------------------------------- User selected phone W850 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 352826-01-375038-7 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 21803A6215E08F5B Reading GDFS... Testing security ... Error : Failed. --- Loading GDFS file---------------------------------------------------------- Loading "D:\DreamSE\gdfs W850\gdfs W850_352401014557650_0305-1458.dmap"... Done. --- Write GDFS----------------------------------------------------------------- User selected phone W850 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 352826-01-375038-7 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 21803A6215E08F5B Flash Chip : ST M58PR512J Flash Chip ID : 88190020 Generating GDFS... Writing GDFS... Done. --- Unlock and Repair---------------------------------------------------------- User selected phone W850 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 352826-01-375038-7 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 21803A6215E08F5B Reading GDFS... Testing security ... GDFS 0013 Hash Failed GDFS 0006 Hash Failed GDFS 000E Hash Failed GDFS 001C Hash Failed Unlocking ... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Generating GDFS... Writing GDFS... Error : Failed. --- Loading flash file--------------------------------------------------------- Loading "D:\DreamSE\W850\W850_full__Intel_BO__Cid52_before_TP\W850_full_(Intel_BO)_Cid52_before TP.bin"... Done. --- Write Flash---------------------------------------------------------------- User selected phone W850 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 352826-01-375038-7 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 21803A6215E08F5B Flash Chip : ST M58PR512J Flash Chip ID : 88190020 Writing ... Error : Failed. --- Write Flash---------------------------------------------------------------- User selected phone W850 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 352826-01-375038-7 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 21803A6215E08F5B Flash Chip : ST M58PR512J Flash Chip ID : 88190020 Writing ... Error : Failed. --- Loading GDFS file---------------------------------------------------------- Loading "D:\DreamSE\GDFS\gdfs W850\gdfs W850_352401014557650_0305-1458.dmap"... Done. --- Write GDFS----------------------------------------------------------------- User selected phone W850 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 352826-01-375038-7 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 21803A6215E08F5B Flash Chip : ST M58PR512J Flash Chip ID : 88190020 Generating GDFS... Writing GDFS... Done. --- Unlock and Repair---------------------------------------------------------- User selected phone W850 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 352826-01-375038-7 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 21803A6215E08F5B Reading GDFS... Testing security ... GDFS 0013 Hash Failed GDFS 0006 Hash Failed GDFS 000E Hash Failed GDFS 001C Hash Failed Unlocking ... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Generating GDFS... Writing GDFS... Done. |
05-14-2008, 07:19 | #5 (permalink) |
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | but my W850 struck in PLEASE WAIT.... last post have the LOG.... please advice me....whether i have to write a another GDFS...or what... Supporters....help me... |
05-14-2008, 07:27 | #6 (permalink) |
Freak Poster Join Date: Sep 2005 Age: 50
Member: 178616 Status: Offline Thanks Meter: 90 | how to repair gdfs plz some one tell me and plz post video for help how to repair gdfs in v630 and k800 ..as describe test point by dream box .so first remove ic then do it or no need to remove ic test point work with removing ic .plz describe in details .. |
05-14-2008, 10:40 | #7 (permalink) |
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | another w850 GDFS repaired successfully...Ic type 5060M0Y0B0 varient2. here is the log....(for Reference) Code: --- Security Bypass------------------------------------------------------------ User selected phone W850 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 352826-01-926586-9 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Stage 1 completed succesfully Stage 2 start Hint : Now the probe might be disconnected Processing... Entering Security Bypass mode ... 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 352826-01-926586-9 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 23803A6215A037E2 Finalizing ... Stage 2 completed succesfully Done. --- Loading GDFS file---------------------------------------------------------- Loading "D:\DreamSE\GDFS\gdfs W850\gdfs W850_352401014557650_0305-1458.dmap"... Done. --- Write GDFS----------------------------------------------------------------- User selected phone W850 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 352826-01-926586-9 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 23803A6215A037E2 Flash Chip : Intel 48F50xxM0Y0 Flash Chip ID : 887E0089 Generating GDFS... Writing GDFS... Done. --- Unlock and Repair---------------------------------------------------------- User selected phone W850 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 352826-01-926586-9 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 23803A6215A037E2 Reading GDFS... Testing security ... GDFS 0013 Hash Failed GDFS 0006 Hash Failed GDFS 000E Hash Failed GDFS 001C Hash Failed Unlocking ... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Generating GDFS... Writing GDFS... Done |
05-14-2008, 10:41 | #8 (permalink) | |
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | Quote:
just TP is visible in sides of the IC... look thru Microscope...nothing more | |
12-10-2008, 03:09 | #9 (permalink) |
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | k550 ver 3.11 white done: oading GDFS file---------------------------------------------------------- Loading "E:\Dreambox\Gdfs\DB GDFS\K550_GDFS.dmap"... Done. --- Write GDFS----------------------------------------------------------------- User selected phone K550 using Test Point boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 359346-01-799136-9 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Flash Chip : Intel 48F50xxM0Y0 Flash Chip ID : 887E0089 Generating GDFS... Writing GDFS... Done. --- Security Bypass------------------------------------------------------------ User selected phone K550 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 359346-01-799136-9 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Stage 1 completed succesfully Stage 2 start Hint : Now the probe might be disconnected Processing... Entering Security Bypass mode ... 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 359346-01-799136-9 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 2380B27B15001AC3 Finalizing ... Stage 2 completed succesfully Done. --- Security Bypass------------------------------------------------------------ User selected phone K550 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 359346-01-799136-9 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 2380B27B15001AC3 Flash Chip : Intel 48F50xxM0Y0 Flash Chip ID : 887E0089 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 359346-01-799136-9 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 2380B27B15001AC3 Finalizing ... Done. --- Unlock and Repair---------------------------------------------------------- User selected phone K550 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 359346-01-799136-9 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 2380B27B15001AC3 Reading GDFS... Testing security ... GDFS 0013 Hash Failed GDFS 0006 Hash Failed GDFS 000E Hash Failed GDFS 001C Hash Failed Unlocking ... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Generating GDFS... Writing GDFS... Done. |
Post here successfully repair by Dreambox | hackerbd | DreamBox | 10 | 03-09-2011 21:20 |
==<<<k530 gdfs problem done by dreambox===>>> | jakoy | DreamBox | 0 | 08-10-2008 11:22 |
K810i GDFS problem done by DREAMBOX | jakoy | DreamBox | 0 | 07-13-2008 03:27 |
success repair w580 red led blinking by dreambox | glx_kks | DreamBox | 0 | 05-03-2008 18:11 |
