Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > DreamBox
Old 08-20-2007, 19:12   #1 (permalink)
Moderator
.::iRizwan::.'s Avatar
Member: 79937
Sonork: 100.84313
Lightbulb Problem with DreamBox
from somedays my dreambox is not working.it connect sucessfully with software but on trying anything like read info etc. it gives following error
Error : You use not calibrated device
Please, contact your dealer!
Error : Failed.
On "Read Box info"
Box Info:
Box SN : xxxx
Firmware Version : 1.08.0
Firmware Build Info : 2579 14 February 2007 13:18:10
Hardware version : 1.1
Done.
what can be the problem?
Old 08-20-2007, 19:25   #2 (permalink)
Member: 241271
Hi, .::Rizwan::.!
Did work your box before? This error can be only on box which has manufacture defect.
Old 08-20-2007, 19:37   #3 (permalink)
Moderator
Member: 79937
Sonork: 100.84313
yes i was using it from many months,this error come somedays before.
Old 08-20-2007, 20:28   #4 (permalink)
Member: 241271
Please, check PM. Thanks.
Old 09-21-2007, 09:53   #5 (permalink)
Member: 153080
Dreambox Problem
Please help, I have problem too, in my dreambox always show :
error : You short power conector to ground, please check it.
When i check the dreambox pcb, capasitor C8 is burned, anyone know what type the c8 is? I wanna change it, but don't know the value of that.
Old 09-21-2007, 15:11   #6 (permalink)
Member: 241271
Hi Hengki!
Please, run Read Box Info and send to me by Private Message an information from logs. I'll try to help you.
Old 09-22-2007, 11:03   #7 (permalink)
Member: 153080
Originally Posted by DreamSupporter View Post
Hi Hengki!
I've send PM to you, and waiting for solution.
Old 09-24-2007, 12:22   #8 (permalink)
Member: 241271
Please, check your PM.
z610i flashing problem with dreambox alfox DreamBox 8 03-25-2008 14:34
s68 problem with dreambox bobjani2005 DreamBox 3 04-03-2007 13:14
s65 reading problem with dreambox bobjani2005 DreamBox 6 12-04-2006 09:26
problem with dreambox coolmax DreamBox 1 07-10-2006 10:37
Problem with DreamBox== Urgent Help Needed. Wake up dreambox team KSM1 DreamBox 6 05-26-2006 14:37
Page generated in 0.28797 seconds with 11 queries
