04-17-2010, 01:00 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Ecuador -Andes
Member: 331361 Status: Offline Thanks Meter: 155 | Problem with version version 3.24 today i try to unlock w200 but program show that i need connect with 2 + 5 but i connect in it mode, program do not see it. it is fist problem after it i tried to write gdfs in c510 buy program show error. i change to version 3.22 and all working good. please review it. |
04-19-2010, 12:11 | #2 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 214480 Status: Offline Thanks Meter: 2,087 | Hello! Please, send all log files (dbss.log, dbss1.log, dbsserror.log etc.) from DreamBox folder (Program Files->DreamBox) to us ([email protected]). Thank you. |
04-20-2010, 12:34 | #4 (permalink) |
No Life Poster Join Date: Feb 2006 Location: campioni del mondo
Member: 235881 Status: Offline Thanks Meter: 221 | i have samme problems k320 not detect in 324 Unlock and Repair---------------------------------------------------------- User selected phone K320 using DCU60 boot mode 1) Turn OFF the phone. 2) Hold <2>+<5> buttons and connect the phone to DCU60 cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color (BOOT) = 4 : RED EROM CID (BOOT) = 50 Error : Invalid boot method. Plese boot holding <2>+<5> Error : #3180:003506DA Error : Failed. |
04-22-2010, 16:01 | #5 (permalink) |
No Life Poster Join Date: Jun 2002 Location: City
Member: 12663 Status: Offline Thanks Meter: 78 | w200 same problem Code: --- Unlock and Repair---------------------------------------------------------- User selected phone W200 using DCU60 boot mode 1) Turn OFF the phone. 2) Hold <2>+<5> buttons and connect the phone to DCU60 cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color (BOOT) = 4 : RED EROM CID (BOOT) = 52 Error : Invalid boot method. Plese boot holding <2>+<5> Error : #3180:003506DA Error : Failed. Read info: Code: --- Reading Info--------------------------------------------------------------- User selected phone W200 using DCU60 boot mode 1) Turn OFF the phone. 2) Hold <C> button and connect the phone to DCU60 cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color (BOOT) = 4 : RED EROM CID (BOOT) = 52 NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 359707-01-843994-0 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 GDFS Simlocks : Lock 0 = LOCKED (01) [5/5] (Network) Lock 1 = OFF (00) [5/5] (Network Subset) Lock 2 = OFF (00) [5/5] (Service Provider) Lock 3 = OFF (00) [5/5] (Corporate) Lock 4 = OFF (00) [5/5] (SIM Card) Lock 5 = OFF (00) [5/5] (Extended) Operator code = 219-01 Done. |
04-27-2010, 10:57 | #6 (permalink) | |
Cheater -Don't Deal with him- Join Date: Jan 2004 Location: Pakistan
Member: 51218 Status: Offline Thanks Meter: 77 | Quote:
WR KHAWAR Read info: | |
04-27-2010, 12:14 | #7 (permalink) |
Junior Member Join Date: Jul 2009
Member: 1071819 Status: Offline Thanks Meter: 6 | For DB201x Unlock and Repair without testpoint must be done ONLY in "Normal" mode (using box cable). (probably they forgot to disable unlock button when you select DCU60 access mode) |
04-27-2010, 12:20 | #8 (permalink) |
Member: 12663 Status: Offline Thanks Meter: 78 | W880 test test using DCU 60 and UNLOCK Code: --- Unlock and Repair---------------------------------------------------------- User selected phone W880 using DCU60 boot mode 1) Turn OFF the phone. 2) Hold <2>+<5> buttons and connect the phone to DCU60 cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Booting via SEMCBOOT ... Error : Invalid boot method. Plese boot holding <2>+<5> Error : #3180:003506DA Error : Failed. test using security bypass ... Code: --- Unlock and Repair---------------------------------------------------------- User selected phone W880 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Timeout detected Error : #3180:00340405 Error : Please execute "Security Bypass" operation first Error : #3180:00350431 Error : #3180:00350633 Error : Failed. final, selecting normal mode and UNLOCK Code: --- Unlock and Repair---------------------------------------------------------- User selected phone W880 using Normal boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 357774-01-787824-9 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Processing P96 authentication ... 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Writing EROM ... Done. All ok, Unlocked ok |
04-27-2010, 12:41 | #9 (permalink) | |
Member: 1071819 Status: Offline Thanks Meter: 6 | Quote:
Second : if phone is not in "Security Bypass" (Patched SEMCBOOT), program says "Please execute "Security Bypass" operation first". Third : yes "Normal" mode via box cable works. (If you press "2+5" in first case, you will also get success log) | |
04-27-2010, 12:46 | #10 (permalink) | |
Member: 12663 Status: Offline Thanks Meter: 78 | Quote:
Maybe U can post your log how U handle unlocking same phones as U have described above | |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
