05-26-2008, 19:06 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Location: Lima - Perú
Member: 598854 Status: Offline Thanks Meter: 141 | Problem with w850 2nd stage failed It says both are on side 3, but i see differences between 2 variants, please help me, i do all proecedurre right, but always same time out User selected phone W850 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 352826-01-347179-4 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Stage 1 completed succesfully Stage 2 start Timeout detected Error : Failed. |
05-28-2008, 08:55 | #3 (permalink) |
Member: 598854 Status: Offline Thanks Meter: 141 | hello, in pictures appear 2 variants, i found 3 and none of them work, same time out error, its 2 stage pictures ok? i didnt see the same side on 2nd stage 2 pictures, please help me with that. Best Regards |
05-29-2008, 13:40 | #4 (permalink) |
No Life Poster Join Date: Mar 2006 Location: tamilnadu, india.
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | first stage you finished using Varient 1 or 2...? if you followed Stage 1 is Var 1 means...select Stage 2 also Var 1. got it... |
05-29-2008, 13:46 | #5 (permalink) | |
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | Quote:
stage 2 will have in the side 3 Var 2 means both the stages are is sine 3 | |
05-30-2008, 23:55 | #6 (permalink) |
Member: 598854 Status: Offline Thanks Meter: 141 | i know thata bro, but thanks anyway, look this are my prob: i achieve to pass the 1st stage with easy tp and normal variant 1 , but second stage always failed i try all variants, im confused with image from support, its not same side on 2nd stage, please please somebody could send me and image of correct place for tp 2nd stage. here the image the yellow circles where i achieve the 1st stage , and pink circles where i found 2nd stage variants but all of them failed time out detected: this are my flash chip 2 nd stage variant 1: 2 nd stage variant 2: it say that 2 variants are on side 3. but i see a lot of differences between the 2. B.R |
05-31-2008, 06:14 | #7 (permalink) |
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | can you post here ...your Microscope image....let the supporters also will see the different varient otherthan thiese two... let we will discuss more about it' |
05-31-2008, 07:47 | #8 (permalink) |
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | can you post here ...your Microscope image....let the supporters also will see the different varient otherthan these two... let we will discuss more about it' |
problem with w850 | Mohsin Ali S | DreamBox | 2 | 09-12-2008 18:56 |
problem with W850 phones | Nasmi | DreamBox | 15 | 05-29-2008 06:02 |
weird problem with w850 | FMC_GSM | DreamBox | 9 | 05-15-2008 04:04 |
daniel problem with n500i code request failed | SoSgSm | FuriousGold | 7 | 07-19-2007 11:04 |
I have problem with interceptor ????? Box login failed | EndlessConnections | Cruiser Suite | 2 | 08-21-2004 16:52 |
