02-07-2010, 01:06 | #1 (permalink) |
Freak Poster Join Date: Nov 2006
Member: 389266 Status: Offline Thanks Meter: 17 | Question on cable tp dream box *******************W200 ****************** User selected phone W200 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color (BOOT) = 4: RED EROM CID (BOOT) = 52 NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 351566-02-111563-4 OTP CID = 51 EROM Color = 4: RED EROM CID = 52 Processing ... Hint: Now the probe might be disconnected Successfully completed Stage 1 Stage 2 start Timeout detected Error: # 3140:003303 FD Error: # 3140:003406 F6 Error: Failed. ************************************************** **************************************** always the same error in the case of w810 ****************w810 ***************************** User selected phone W810 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) Warning: Detected platform is different from selected EROM Color (BOOT) = 4: RED EROM CID (BOOT) = 50 NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 356573-01-571653-9 OTP CID = 50 EROM Color = 4: RED EROM CID = 50 Processing ... Hint: Now the probe might be disconnected Successfully completed Stage 1 Stage 2 start Hint: Now the probe might be disconnected Processing ... Entering Security Bypass mode ... 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) Warning: Detected platform is different from selected EROM Color (BOOT) = 4: RED EROM CID (BOOT) = 50 Baseband Chip ID = 8040 Phone ID = 2280DD701550908B Finalizing ... Successfully completed Stage 2 Error: # 3140:004 C0A53 Error: # 3140:003302 A7 Done. ************************************************** ********** after so many attempts in the final this w810 phone is the flash chip damage my cable as I have read this wrong? how can I test the performance of my cable? can be fixed? that I care? thanks for the help and forgive my bad English lucky |
02-08-2010, 17:11 | #4 (permalink) |
Member: 389266 Status: Offline Thanks Meter: 17 | User selected phone K790 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 351708-01-589679-1 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Warning : Connected phone is not K790 Please select correct phone model Seems to be K800 Hint : Now the probe might be disconnected Processing ... Stage 1 completed succesfully Stage 2 start Timeout detected Error : #3150:00320403 Error : #3150:00330705 Error : Failed. **************************** k790 same problem, faild tp 2 thanks |
02-08-2010, 17:57 | #6 (permalink) |
Member: 389266 Status: Offline Thanks Meter: 17 | hello thank you very much dream team I could get the w200 but with via via settool3 dream is more practical to me we should not press "READY", much faster the process. only now I get this failure when I connect the sound tp 2 ring and held it for a while, it stays as the process and then paste the error you see I do it many times and the result is the same as with three different cell thanks dream box |
Question about customization in Dream BOX | balar | DreamBox | 0 | 03-11-2010 16:30 |
question on not TP unlock bb5 | marekkaf | NoooX Box | 4 | 11-24-2008 13:54 |
tp dream box all the times connected | freeman2001 | DreamBox | 6 | 10-24-2008 12:03 |
N73 Magic TP, Dream BOX SE, Alpha SIM, FLY cable, new TP JTAG | Multi-COM | Main Sales Section | 0 | 04-18-2008 12:29 |
Test Point Cable By Dream Box Plus | FRABRAZIL | DreamBox | 3 | 05-11-2007 11:38 |
