Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > DreamBox
Old 06-26-2009, 20:22   #1 (permalink)
Member: 1047400
questions about Dreambox SE
Is this box if it costs three times more than setoolbox does not have the same characteristics?
Crusierbox plus? means that updates will no longer Dreambox more?
I hope that respond, and as I close the post yesterday ... saludos
P.D. Some video tutorials Easy unlock by patch (CID52 only)
Old 06-30-2009, 17:45   #2 (permalink)
GSM Dream's Avatar
Member: 214480
We doesn't have "How to use" video for this feature. It's easy to use - just follow the instructions.
Enable Firmware Patching
This function has to be used to patch the firmware during flashing the handset with "clear" (not patched) flash file. Also, it allows flashing the phone with already "patched" firmware.
In case of marking the option "Enable Firmware Patching" the following option "Auto-Patch : Remove SIM-Locks" becomes active and the "clear" flash file can be modified with the "Remove SIM-Locks" patch.
The specified above feature can be used for the handsets with CID52 only. If the phone’s CID version is lower, then it can be upgraded to the version 52 using "Upgrade to CID52" option of the "Misc" tab.
"Upgrade to CID52" option is available using "DCU-60" mode only.
The Following User Says Thank You to GSM Dream For This Useful Post:
Old 08-02-2009, 12:06   #3 (permalink)
freedomqn's Avatar
Member: 347720
Sonork: haidzam@yahoo.com
for db2020? db2012 ?and about pnx5320?
Old 08-03-2009, 15:11   #4 (permalink)
GSM Dream's Avatar
Member: 214480
Hello!
"Easy unlock by patch" works with DB2020 CID52 only.
question about superdongle data of n-95 8gb compue Universalbox 2 03-29-2010 15:16
One Question About Cruiser,pls Gubby_J Cruiser Suite 2 03-29-2010 12:46
about dreambox se cmk DreamBox 3 03-16-2008 21:45
question about buy dreambox se .::GT-GSM MAN::. DreamBox 1 03-07-2008 00:20
question about mtbox se mentari MT-BOX 1 05-09-2007 18:25
Page generated in 0.28220 seconds with 11 queries
