Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > DreamBox
Old 04-24-2008, 05:42   #1 (permalink)
Member: 76880
repair RED BLINK only HOW
Guide please need repair red blink flash error please wait etc. how
Br Docshuely
Old 04-24-2008, 06:28   #2 (permalink)
Member: 76880
here sample k800 red blink only:
User selected phone K800 using Security Bypass boot mode
1) Turn OFF the phone.
2) Connect the phone to DreamBox cable.
Boot Responce = 5A
Processor ID = 99000301FFFFFFFF (DB2020 / DB2030)
Timeout detected
Error : Please execute "Security Bypass" operation first
Error : Failed.
--- Security Bypass------------------------------------------------------------
Boot Responce = 5A
Timeout detected
Error : Failed.
HOW TO REPAIR THIS
docshuely
Old 04-24-2008, 06:42   #3 (permalink)
Member: 76880
k310
--- Reading Info---------------------------------------------------------------
User selected phone K310 using Normal boot mode
Boot Responce = 5A
Processor ID = 80400301FFFFFFFF (DB2012)
EROM Color = 4 : RED
EROM CID = 49
NOR Flash ID = 897E
OTP Status = LOCKED
OTP IMEI = 353784-01-910175-9
OTP CID = 49
EROM CID = 49
Error : DB201x CID < 50 is not supported
Error : Failed.
Old 04-24-2008, 06:43   #4 (permalink)
paedy's Avatar
Member: 119552
You Must Use Test Point Method First..
Klik Enter "Execute security Bypass Operation"
Use test point Picture at dreambox software..
Set sensitifity at 70....
For test point stage1 result must 98 (good test point)
For test point stage2 result between 58-60 ..
If execute Security Bypass operation Succeded then change method at security Bypass.
Full flash and write gdfs then Unlock and repair gdfs security blocks..
Last if necessary flash with normal method use firmware and filesystem and cda File..
Viola Your Phone working Normall..
Try and Try if use test point method ... This is very difficult at we use first time with dreambox..
Will you Pass test point method (specially side of ic flash) everything become easy..
Paedy
Old 04-24-2008, 06:54   #5 (permalink)
paedy's Avatar
Member: 119552
Originally Posted by jekjae View Post
k310
Boot Responce = 5A
EROM CID = 49
NOR Flash ID = 897E
OTP Status = LOCKED
OTP CID = 49
EROM CID = 49
Error : Failed.
Dreambox Just Support DB2012 it's mean K510,K310,K320 CID50
But Dreambox team always Give Supprise for dreambox user..
Waiting.....
And Patience untill they release Big supprise Again.
Paedy
Old 04-24-2008, 07:33   #6 (permalink)
Member: 76880
but what tp remove flash ic on k800 or how
Old 04-24-2008, 07:47   #7 (permalink)
Member: 515413
no..u can use TP with variant in side ic..u must have good microskop to see TP..
its not difficult to do TP...
br
Titan wonder
Old 04-24-2008, 07:51   #8 (permalink)
Member: 76880
k like bb5 box
thank for reply
Old 04-30-2008, 01:08   #9 (permalink)
FullFLASHgSMPH's Avatar
Member: 161739
Sonork: 100.1584054
u need also 2x microscop to do the testpoint timing nga lang mahirap kapain
Old 05-03-2008, 13:15   #10 (permalink)
jakoy's Avatar
Member: 14852
Sonork: 100.1608716
User selected phone K320 using Test Point boot mode
Stage 1 started
Boot Responce = 5A
Processor ID = 8040030101010101 (DB2012 R3A)
EROM CID = 50
NOR Flash ID = 897E
OTP Status = LOCKED
OTP IMEI = 356706-01-279357-8
OTP CID = 50
EROM CID = 50
Hint : Now the probe might be disconnected
Processing ... \
Error : Invalid GDFS structure and/or configuration.
Hint : Try to flash firmware.
what happen?
Old 05-03-2008, 13:27   #11 (permalink)
SANGURAN_BOX's Avatar
Member: 739429
Sonork: FIND TO GOOGLES
Stage 1 started
Boot Responce = 5A
EROM CID = 50
NOR Flash ID = 897E
OTP Status = LOCKED
OTP CID = 50
EROM CID = 50
Processing ... \
what happen?
hi jakoy@ flash ur phone to other device like cruiser. use high version firmware then try unlock again via tp..
good luck..
br
sanguran
Old 05-05-2008, 15:53   #12 (permalink)
Member: 241271
@jakoy
Try to reorganize GDFS (Power on the phone and change settings/contacts/theme e.t.c.) or flash firmware.
Our decision depends on the configuration GDFS. If DB2012 phone has "Invalid GDFS and/or configuration" and firmware flashing or GDFS reorganizing didn't help - nothing can be done.
How to repair gdfs, red blink and how to upgrade cid with ub in sony ericsson phones svchost Universalbox 1 04-29-2009 16:00
to repair red blink how FullFLASHgSMPH BlackBerry (RIM) 10 12-27-2008 18:10
Help. i want TP picture for K510 CID50 & how to repair Red Blink IkaMazini Cruiser Suite 1 10-26-2008 12:59
How to repair red blink in se phones? funcitystudio Universalbox 2 09-26-2008 11:06
Page generated in 0.31515 seconds with 11 queries
